Hi Guys,
My customer is using the IWR1642 in their product, and they had some questions:
We are using the following onboard antenna in a new application:
I want to mount this PCB and onboard antenna in an enclosure and have a few questions:
- What is the field of view of the antenna?
- What are the ideal dimensions of the radome?
- Is there an ideal distance the board/antenna should be away from the enclosure/radome?
- What material do you recommend to use for the radome?
- What should the thickness of the radome be in order to not cause any interference?
Brian
