Other Parts Discussed in Thread: DRV5023, , DRV5033
Hello
I have an application of flow rate sensing. A magnet moves continuously over an array of 4 hall sensors in series, to generate pulses which are proportional to flow rate. However, if the sensor latches in a voltage state and stays in an LPM, I might miss a pulse. My flow rates vary from 0.1 hz to 50 hz. if the sensor is in an LPM when my magnet moves, a missed pulse would mean incorrect reading.
Is there a way around this? I looked at the alternate DRV5023, but I need a low power hall. The DRV5023 consumes current of around 2-4 mA which I cannot afford. Is there an alternate solution?
Best Regards
Shubhankar
