IWR1642BOOST: .bin file conversion/interpretation
Part Number: IWR1642BOOST
Hi there,
I am using the matlab code below for my and I can't seem to open my results. I am doing experiment lab0001-driver-vital-signs.
I keep getting the error message on Matlab.
Error using fread
Invalid file identifier. Use fopen to generate a valid file identifier.
Error in main_readGUISavedBinary (line 64)
dataBin = fread(fid_bin,'uint8');
I can't seem to solve this issue. Does it have to do with the fact that my settings sets a .bin file as a notepad file?
If so, I can't seem to change it back.
Secondly, I am currently testing how the distance and angle between object and sensor affects the results.
Is the saved data an average of the whole experiment? Or will I be able to view it part by part?
Below is the codes that I used:
% (C) Copyright 2018 Texas Instruments, Inc.
% Redistribution and use in source and binary forms, with or without
% modification, are permitted provided that the following conditions
% are met:
% Redistributions of source code must retain the above copyright
% notice, this list of conditions and the following disclaimer.
% Redistributions in binary form must reproduce the above copyright
% notice, this list of conditions and the following disclaimer in the
% documentation and/or other materials provided with the
% distribution.
% Neither the name of Texas Instruments Incorporated nor the names of
% its contributors may be used to endorse or promote products derived
% from this software without specific prior written permission.
% THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
% "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
% LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
% A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
% OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
% SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
% LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
% DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
% THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
% (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
% OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
% Provide (a) The binary file saved from the PC-GUI
% AND (b) The corresponding Configuration file used to run the GUI
% Variables saved in the Workspace
% rangeProfile_cplx [rows x columns] : Contains the complex Range-FFT values from the
% range-bins corresponsing to the values specified
% in the cfg file. The rows contains the range bins while the
% columns are the chirps/frames. 1st chirp of each
% frame is saved.
% vitalSignsDemo_OutputStats: Contains Processed values Outputed from
% the EVM.
fclose all;close all;clear all;clc
% Directory name
dir_name = 'C:\DataDirectory\';
% Binary Data
file_name_bin = 'dataOutputFromEVM.bin';
% Configuration file used to collect the data
cliCfgFileDir = dir_name;
cliCfgFileName = 'xwr1642_profile_VitalSigns_20fps_Back.cfg';
global TOTAL_PAYLOAD_SIZE_BYTES;
file_path_bin = strcat(dir_name, file_name_bin);
fid_bin = fopen(file_path_bin,'rb');
fclose(fid_bin);
cliCfgFilePath = strcat(dir_name, cliCfgFileName);
ParamsStruct= parseCfgFile(cliCfgFilePath);
[TOTAL_PAYLOAD_SIZE_BYTES, indexVitalSignsOutput] = calculate_PayLoadSize(ParamsStruct);
NUM_SAMPLES_EVM = TOTAL_PAYLOAD_SIZE_BYTES;
numChirpsFile = length(dataBin)/NUM_SAMPLES_EVM;
dataAll = reshape(dataBin,[NUM_SAMPLES_EVM numChirpsFile]);
dataEVM = dataAll;
samplingInterval = 1e-3*ParamsStruct.frameCfg.framePeriodicity; % Frame Periodicity
Fs = 1/samplingInterval; % Sampling Rate
timeAxis = samplingInterval:samplingInterval:size(dataEVM,2)*samplingInterval;
rangeBinSize_meter = ParamsStruct.dataPath.rangeBinSize_meter;
rangeStartMeters = ParamsStruct.vitalSignsParams.rangeStartMeters;
rangeEndMeters = ParamsStruct.vitalSignsParams.rangeEndMeters;
rangeAxis = rangeStartMeters:rangeBinSize_meter:rangeEndMeters;
INDEX_RANGE_PROFILE_START = indexVitalSignsOutput.INDEX_RANGE_PROFILE_START;
numRangeBinsSentUART = ParamsStruct.dataPath.numRangeBinProcessed;
rangeProfile = dataEVM(INDEX_RANGE_PROFILE_START:(INDEX_RANGE_PROFILE_START + 4*numRangeBinsSentUART)-1,:);
% Convert uint8 to uint16
rangeProfile = rangeProfile(1:2:end,:)+ rangeProfile(2:2:end,:)*2^8;
% Convert from the 2's complement Form
for col=1:size(rangeProfile,2)
for i=1:size(rangeProfile,1)
if (rangeProfile(i,col) >2^15)
rangeProfile(i,col) = rangeProfile(i,col) - 2^16;
end
end
end
% Convert to Complex Format
rangeProfile_cplx = rangeProfile(1:2:end,:) + j*rangeProfile(2:2:end,:);
% Extract the Phase from a range-bin of interest
row_index = 12;
ant1_Ph = angle(rangeProfile_cplx(row_index,:));
ant1_UnWrapPh = unwrap(ant1_Ph);
figure(1);clf
subplot(311);imagesc(abs(rangeProfile_cplx));
xlabel('Frame Number');ylabel('Range Bins')
title('Magnitude of the Range Profiles')
subplot(312);
plot(abs(rangeProfile_cplx(:,10))); grid on
title('A selected column of the Range Profile')
subplot(313);plot(ant1_UnWrapPh);
ylabel('Radians')
title({strcat('rangeIndex = ',num2str(row_index)), 'Phase'})
grid on
%% Extract Paremeters from the EVM output
vitalSignsDemo_OutputStats = parseDataEVM(dataEVM, indexVitalSignsOutput);
outGlobalCount = vitalSignsDemo_OutputStats.outGlobalCount;
outPhase = vitalSignsDemo_OutputStats.outPhase;
outBreathWfm = vitalSignsDemo_OutputStats.outBreathWfm;
outHeartWfm = vitalSignsDemo_OutputStats.outHeartWfm;
outHeartRate_FFT = vitalSignsDemo_OutputStats.outHeartRate_FFT;
outBreathRate_FFT = vitalSignsDemo_OutputStats.outBreathRate_FFT;
outBreathRate_Peak = vitalSignsDemo_OutputStats.outBreathRate_Peak;
outHeartRate_Peak = vitalSignsDemo_OutputStats.outHeartRate_Peak;
outConfidenceMetricHeart = vitalSignsDemo_OutputStats.outConfidenceMetricHeart;
outConfidenceMetricBreath = vitalSignsDemo_OutputStats.outConfidenceMetricBreath;
outEnergyBreath = vitalSignsDemo_OutputStats.outEnergyBreath;
outEnergyHeart = vitalSignsDemo_OutputStats.outEnergyHeart;
figure(2);
plot(outPhase);grid on
title('Phase values (from the EVM)')
figure(9);
subplot(211);plot(outGlobalCount);title('Frame Number saved from the EVM')
subplot(212);plot(diff(outGlobalCount)); title('If not zero indicates that frames have been missed in saving the data')
%% Parses the data from the EVM to extract out the relevant outputs in vitalSignsDemo_OutputStats
% dataEVM: Data saved from the EVM
% indexVitalSignsOutput: Index positions of the vital signs Demo Output.
% These index positions are hardcoded in the
% firmware on the EVM (subjected to change in later versions)
% vitalSignsDemo_OutputStats : Output structure containing different output values
function [vitalSignsDemo_OutputStats] = parseDataEVM(dataEVM, indexVitalSignsOutput)
vitalSignsDemo_OutputStats = [];
INDEX_GLOBAL_COUNT = indexVitalSignsOutput.INDEX_GLOBAL_COUNT;
INDEX_RANGE_BIN_PHASE = indexVitalSignsOutput.INDEX_RANGE_BIN_PHASE;
INDEX_RANGE_BIN_VALUE = indexVitalSignsOutput.INDEX_RANGE_BIN_VALUE;
INDEX_PHASE = indexVitalSignsOutput.INDEX_PHASE;
INDEX_BREATHING_WAVEFORM = indexVitalSignsOutput.INDEX_BREATHING_WAVEFORM;
INDEX_HEART_WAVEFORM = indexVitalSignsOutput.INDEX_HEART_WAVEFORM;
INDEX_BREATHING_RATE_FFT = indexVitalSignsOutput.INDEX_BREATHING_RATE_FFT;
INDEX_HEART_RATE_EST_FFT = indexVitalSignsOutput.INDEX_HEART_RATE_EST_FFT;
INDEX_BREATHING_RATE_PEAK = indexVitalSignsOutput.INDEX_BREATHING_RATE_PEAK;
INDEX_HEART_RATE_EST_PEAK = indexVitalSignsOutput.INDEX_HEART_RATE_EST_PEAK;
INDEX_CONFIDENCE_METRIC_BREATH = indexVitalSignsOutput.INDEX_CONFIDENCE_METRIC_BREATH;
INDEX_CONFIDENCE_METRIC_HEART = indexVitalSignsOutput.INDEX_CONFIDENCE_METRIC_HEART;
INDEX_ENERGYWFM_BREATH = indexVitalSignsOutput.INDEX_ENERGYWFM_BREATH;
INDEX_ENERGYWFM_HEART = indexVitalSignsOutput.INDEX_ENERGYWFM_HEART;
for ii=1:size(dataEVM,2)
temp16 = typecast(uint8([dataEVM(:,ii)]),'uint16');
temp32 = typecast(uint8([dataEVM(:,ii)]),'uint32');
tempFloat = typecast(uint8([dataEVM(:,ii)]),'single');
globalCountTemp = dataEVM([INDEX_GLOBAL_COUNT: INDEX_GLOBAL_COUNT+3],ii);
outGlobalCount = typecast(uint8([globalCountTemp]),'uint32');
vitalSignsDemo_OutputStats.outGlobalCount(ii) = outGlobalCount;
vitalSignsDemo_OutputStats.outPhase(ii) = tempFloat(INDEX_PHASE);
vitalSignsDemo_OutputStats.outBreathWfm(ii) = tempFloat(INDEX_BREATHING_WAVEFORM );
vitalSignsDemo_OutputStats.outHeartWfm(ii) = tempFloat(INDEX_HEART_WAVEFORM );
vitalSignsDemo_OutputStats.outHeartRate_FFT(ii) = tempFloat(INDEX_HEART_RATE_EST_FFT );
vitalSignsDemo_OutputStats.outBreathRate_FFT(ii) = tempFloat(INDEX_BREATHING_RATE_FFT );
vitalSignsDemo_OutputStats.outBreathRate_Peak(ii)= tempFloat(INDEX_BREATHING_RATE_PEAK );
vitalSignsDemo_OutputStats.outHeartRate_Peak(ii) = tempFloat(INDEX_HEART_RATE_EST_PEAK );
vitalSignsDemo_OutputStats.outConfidenceMetricHeart(ii) = tempFloat(INDEX_CONFIDENCE_METRIC_HEART );
vitalSignsDemo_OutputStats.outConfidenceMetricBreath(ii) = tempFloat(INDEX_CONFIDENCE_METRIC_BREATH );
vitalSignsDemo_OutputStats.outEnergyBreath(ii) = tempFloat(INDEX_ENERGYWFM_BREATH);
vitalSignsDemo_OutputStats.outEnergyHeart(ii) = tempFloat(INDEX_ENERGYWFM_HEART);
end
end
function [INDEX_OUT] = TRANSLATE_INDEX(LENGTH_OFFSET, INDEX_IN)
INDEX_OUT = (LENGTH_OFFSET + INDEX_IN*4)/4;
end
function [TOTAL_PAYLOAD_SIZE_BYTES, indexVitalSignsOutput] = calculate_PayLoadSize(ParamsStruct)
LENGTH_MAGIC_WORD_BYTES = 8; % Length of Magic Word appended to the UART packet from the EVM
LENGTH_DEBUG_DATA_OUT_BYTES = 128; % VitalSignsDemo_OutputStats size
LENGTH_HEADER_BYTES = 40; % Header + Magic Word
LENGTH_TLV_MESSAGE_HEADER_BYTES = 8;
MMWDEMO_OUTPUT_MSG_SEGMENT_LEN = 32;
%Calculate monitoring packet size
numRangeBinProcessed = ParamsStruct.dataPath.numRangeBinProcessed;
TOTAL_PAYLOAD_SIZE_BYTES = LENGTH_HEADER_BYTES;
TOTAL_PAYLOAD_SIZE_BYTES = TOTAL_PAYLOAD_SIZE_BYTES+...
LENGTH_TLV_MESSAGE_HEADER_BYTES + (4*numRangeBinProcessed);
LENGTH_TLV_MESSAGE_HEADER_BYTES+LENGTH_DEBUG_DATA_OUT_BYTES;
% Padding
if (mod(TOTAL_PAYLOAD_SIZE_BYTES,MMWDEMO_OUTPUT_MSG_SEGMENT_LEN)~=0)
paddingFactor = ceil(TOTAL_PAYLOAD_SIZE_BYTES/ MMWDEMO_OUTPUT_MSG_SEGMENT_LEN);
TOTAL_PAYLOAD_SIZE_BYTES = MMWDEMO_OUTPUT_MSG_SEGMENT_LEN*paddingFactor;
end
LENGTH_OFFSET_BYTES = LENGTH_HEADER_BYTES - LENGTH_MAGIC_WORD_BYTES + LENGTH_TLV_MESSAGE_HEADER_BYTES
%% This structure defines the index location of various outputs in radar packet
% Note: The index Is subjected to change
LENGTH_OFFSET = LENGTH_OFFSET_BYTES + LENGTH_TLV_MESSAGE_HEADER_BYTES;
indexVitalSignsOutput.INDEX_GLOBAL_COUNT = 21; % Start Byte Number of Global Frame Count in the Header
indexVitalSignsOutput.INDEX_RANGE_BIN_PHASE = TRANSLATE_INDEX(LENGTH_OFFSET,1);
indexVitalSignsOutput.INDEX_RANGE_BIN_VALUE = TRANSLATE_INDEX(LENGTH_OFFSET,2)
indexVitalSignsOutput.INDEX_PHASE = TRANSLATE_INDEX(LENGTH_OFFSET,5)
indexVitalSignsOutput.INDEX_BREATHING_WAVEFORM = TRANSLATE_INDEX(LENGTH_OFFSET,6)
indexVitalSignsOutput.INDEX_HEART_WAVEFORM = TRANSLATE_INDEX(LENGTH_OFFSET,7)
indexVitalSignsOutput.INDEX_HEART_RATE_EST_FFT = TRANSLATE_INDEX(LENGTH_OFFSET,8)
indexVitalSignsOutput.INDEX_HEART_RATE_EST_FFT_4Hz = TRANSLATE_INDEX(LENGTH_OFFSET,9)
indexVitalSignsOutput.INDEX_HEART_RATE_EST_xCorr = TRANSLATE_INDEX(LENGTH_OFFSET,10)
indexVitalSignsOutput.INDEX_HEART_RATE_EST_PEAK = TRANSLATE_INDEX(LENGTH_OFFSET,11)
indexVitalSignsOutput.INDEX_BREATHING_RATE_FFT = TRANSLATE_INDEX(LENGTH_OFFSET,12)
indexVitalSignsOutput.INDEX_BREATHING_RATE_xCorr = TRANSLATE_INDEX(LENGTH_OFFSET,13)
indexVitalSignsOutput.INDEX_BREATHING_RATE_PEAK = TRANSLATE_INDEX(LENGTH_OFFSET,14)
indexVitalSignsOutput.INDEX_CONFIDENCE_METRIC_BREATH = TRANSLATE_INDEX(LENGTH_OFFSET,15)
indexVitalSignsOutput.INDEX_CONFIDENCE_METRIC_HEART = TRANSLATE_INDEX(LENGTH_OFFSET,17)
indexVitalSignsOutput.INDEX_CONFIDENCE_METRIC_HEART_4Hz = TRANSLATE_INDEX(LENGTH_OFFSET,18)
indexVitalSignsOutput.INDEX_CONFIDENCE_METRIC_HEART_xCorr = TRANSLATE_INDEX(LENGTH_OFFSET,19)
indexVitalSignsOutput.INDEX_ENERGYWFM_BREATH = TRANSLATE_INDEX(LENGTH_OFFSET,20)
indexVitalSignsOutput.INDEX_ENERGYWFM_HEART = TRANSLATE_INDEX(LENGTH_OFFSET,21)
indexVitalSignsOutput.INDEX_MOTION_DETECTION = TRANSLATE_INDEX(LENGTH_OFFSET,22)
indexVitalSignsOutput.INDEX_RESERVED_2 = TRANSLATE_INDEX(LENGTH_OFFSET,21)
indexVitalSignsOutput.INDEX_RESERVED_3 = TRANSLATE_INDEX(LENGTH_OFFSET,22)
indexVitalSignsOutput.INDEX_RESERVED_4 = TRANSLATE_INDEX(LENGTH_OFFSET,23)
indexVitalSignsOutput.INDEX_RANGE_PROFILE_START = (LENGTH_HEADER_BYTES + LENGTH_DEBUG_DATA_OUT_BYTES ...
+ 2*LENGTH_TLV_MESSAGE_HEADER_BYTES) + 1
end
Thank you.
Amy
