IWR1642: Cannot build the ppl lab ccs project in toolbox 2.3.0
Part Number: IWR1642
My customer is using the industry toolbox 2.3.0 for test on IWR1642 EVM ES1.0, imported the ppl lab project in ccs7.4 for build but failed with below issues report. I have already checked all the dependency software tools are same as requirement, changed to a new workspace with the same issues. I cannot understand below errors, pls help on it, thanks.
**** Build of configuration Debug for project pplcount_16xx_dss ****
"C:\\ti\\ccsv7\\utils\\bin\\gmake" -k -j 8 all -O
rm -f D:/test_workspace/pplcount_16xx_dss/xwr16xx_pplcount_dss.bin
makefile:199: recipe for target 'pre-build' failed
process_begin: CreateProcess(NULL, rm -f D:/test_workspace/pplcount_16xx_dss/xwr16xx_pplcount_dss.bin, ...) failed.
make (e=2): 系统找不到指定的文件。
gmake[1]: [pre-build] Error 2 (ignored)
'Building file: "../dss_mmw.cfg"'
'Invoking: XDCtools'
"C:/ti/xdctools_3_50_04_43_core/xs" --xdcpath="C:/ti/bios_6_53_02_00/packages;C:/ti/ccsv7/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR16XX:false:600 -r release -c "C:/ti/c6000_7.4.16" "../dss_mmw.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring dss_mmw.xe674 from package/cfg/dss_mmw_pe674.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making D:/test_workspace/pplcount_16xx_dss/src/sysbios/sysbios.ae674 ...
gmake[1]: Entering directory `D:/test_workspace/pplcount_16xx_dss/src/sysbios'
cle674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/BIOS.c ...
asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
are674 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj ti_tls_get_tp.obj c62_TaskSupport_asm.obj ...
gmake[1]: Leaving directory `D:/test_workspace/pplcount_16xx_dss/src/sysbios'
Build of libraries failed.
subdir_rules.mk:103: recipe for target 'build-1994956399-inproc' failed
process_begin: CreateProcess(NULL, C:/ti/c6000_7.4.16/bin/ar6x rq sysbios.ae674 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj ti_tls_get_tp.obj c62_TaskSupport_asm.obj, ...) failed.
make (e=2): cannot find the specified files。
gmake[1]: *** [sysbios.ae674] Error 2
gmake: *** [D:/test_workspace/pplcount_16xx_dss/src/sysbios/sysbios.ae674] Error 2
error: xdc.cfg.SourceDir: "C:/ti/xdctools_3_50_04_43_core/packages/xdc/cfg/SourceDir.xs", line 209: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2:
js: "C:/ti/xdctools_3_50_04_43_core/packages/xdc/cfg/Main.xs", line 160: Error: Configuration failed!
gmake.exe: *** [package/cfg/dss_mmw_pe674.xdl] Error 1
gmake.exe: *** Deleting file `package/cfg/dss_mmw_pe674.xdl'
gmake.exe: *** [package/cfg/dss_mmw_pe674.xdl] Deleting file `package/cfg/dss_mmw_pe674.h'
gmake.exe: *** [package/cfg/dss_mmw_pe674.xdl] Deleting file `package/cfg/dss_mmw_pe674.c'
js: "C:/ti/xdctools_3_50_04_43_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[2]: *** [build-1994956399-inproc] Error 1
gmake[1]: *** [build-1994956399] Error 2
gmake[1]: Target 'main-build' not remade because of errors.
gmake: *** [all] Error 2
subdir_rules.mk:100: recipe for target 'build-1994956399' failed
makefile:165: recipe for target 'all' failed
**** Build Finished ****
