IWR1642BOOST: I have a question about modifying the gtrack algorithm
Part Number: IWR1642BOOST
Hi, I want to modify the gtrack algorithm, but I find the algorithm is used by lib. So how can I do to recompile the algorithm. Thanks!
  • Former Member
    0 Former Member
    The source code for the gtrack algorithm is located in the sdk at C:\ti\mmwave_sdk_03_01_01_02\packages\ti\alg\gtrack.
    To build the gtrack module (as well as the SDK or other modules), please refer to the mmwave_sdk_user_guide located in the docs folder of the mmWave SDK
    1) Please follow the instructions in section 4. 5. 2. Setting up build environment
    2) Then follow the instructions in 4. 5. 3. Building demo but instead of building the mmw demo navigate to the above gtrack src path and build the library.
    Amanda
