PGA300: External Temperature Sensor in PGA300
Part Number: PGA300
Hello:
I am using external temperature sensor in PGA300 application.
Quote from TI: "You should not place a resistor between INT+ and GND if you plan to use an external temperature sensor."
I HAVE TO place a resistor with GND to INT+, then connect RT1000 between INT+ and INT- in order to get RT1000 voltage output. Please verify this.
Thanks a lot!
