Other Parts Discussed in Thread: LDC1101
i want to measure a metal composition change with the LDC1612.
My question is then : Can the LDC1612 measure an equivalent of the Rp or proximity data as the LDC1000 did?
If not, Can the LDC1612 measure the energy loss or a target metal composition change? Indeed, measuring fs is dependent of Q so is dependent of the energy loss just as Rp was, right? (with a difference sensitivity maybe). So measuring fs variation, I should be able to measure metal composition change, right?
I want to use the LDC1612 to measure a change of metal composition (as the Rp of the former LD1000 did).
Thanks in advance for your answer,
David
