Part Number: OPT8241-CDK-EVM
IF we use default firmware setting and remove U15,U24,U1,U2,R90,U9,U21,U22 , the OPT8241-CDK-EVM SB Board can work well indoors ? thank you ^_____^
Hi
The components referred above are used to give a bias to the sensor which improves the demodulation contrast. Unless your overall system is very bad, this will be independent of the ambient conditions. For arriving at operating conditions required for your use case, we suggest you try out with the system estimator tool available in the below page.
http://www.ti.com/product/OPT8241/toolssoftware
Nithin
