AWR1642: mmWave studio compatibility in WIN10 Pro 1809
Part Number: AWR1642
Hi team,
My PC(TI-Laptop) had upgraded to Win 10 Pro 1809 several days ago. After upgrade to new version OS. mmwave radar studio cannot work normally. mmwave studio can run successful on my PC before OS upgrade.
Did you have any similar situation? how to solve it?
I had already try re-install MCR_R2017a_win64_installer.exe and mmwave_studio_02_00_00_02_win32.exe.
Then deleted "C:\Users\XXX\AppData\Roaming\RSTD", but nothing happen.
The output information is listed below:
GM: Constructor
GM: Tue Apr 16 10:19:51 2019
RSTD.SaveSettings(): Settings saved to "C:\Users\xxx\AppData\Roaming\RSTD\config.xml"
RSTD.Transmit("/Settings")
### Running Startup script: "C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Scripts\Startup.lua" ###
RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[16/04 10:19:51]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[10:19:51]  Scripter ignored: Attempt to UnBuild() again or before Build.
[10:19:51]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\Clients\\\\LabClient.dll")
[10:19:51]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[10:19:51]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[10:19:51]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[10:19:51]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[10:19:51]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[10:19:51]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\RunTime\\SAL.dll")
[10:19:51]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[10:19:51]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[10:19:51]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[10:19:51]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[10:19:51]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[10:19:51]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[10:19:51]  RSTD.Transmit("/")
[10:19:51]  RSTD.SaveSettings(): Settings saved to "C:\Users\xxx\AppData\Roaming\RSTD\config.xml"
[10:19:51]  RSTD.Build()
[10:19:51]  RSTD.AL_Build()
[10:19:51]  RSTD.AL_LoadXml()
[10:19:51]  RSTD.AL_Init()
[10:19:51]  RSTD.Clients_Build()
[10:19:51]  GM: Init
[10:19:51]  GM: Loaded 'C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Clients\\LabClient.dll'
[10:19:51]  GM: 1 Guest (s) init
[10:19:51]  GM: 1 Module(s) init
[10:19:51]  GM: 2 Tab   (s) init
[10:19:51]  RSTD.Client_LoadXml()
[10:19:51]  [RadarAPI]: Starting Matlab Engine..
[10:19:57]  [RadarAPI]: Matlab Engine Started!
[10:19:58]
[10:19:58]  &&&&&&&&&&&&&&&&&&&&
[10:19:58]  ***Script FAILED!***
[10:19:58]  Exception message is:
[10:19:58]  Object reference not set to an instance of an object.
