AWR1642: Output power b/w AWR1243 and AWR1642
Part Number: AWR1642
Other Parts Discussed in Thread: AWR1243
Hello Support team.
I found that there is a different output power b/w AWR1243 and AWR1642.
AWR1243 output power is 12 dBm.
AWR1262 output powre is 12.5 dBm.
Old documents have same value 12 dBm at both AWR1243 and AWR1642.
I would like to know the reason why output power of AWR1642 has been changed.
And I would like to know the impact of this different. For example, measurement distance etc.
Br
KORO
  • Hello Koro,
    Inherently both the devices have similar RF configuration and similar o/p is expected from both. The datasheet mentions typical values and since there would be variation from devices to device ( a spread) there could be a slight difference in the value measurement for a particular device.
    Vivek
  • Hello Vivek-san
    Thanks a lot for your quick reply.
    It is very helpful for me.
    I understood.
    And the below point, I would like to know.
    I would like to know what point is different between 12dBm and 12.5dBm as output power.
    I believe that it may be different measurable distance.
    Is my understanding correct ?
    And is there any other different points ?
    Br
    KORO
  • Hello Koro,
    That is correct, a change in TX o/p impacts the detectable range.
    But like I said, 1243 and 1642 TX o/p performance is similar.
    Vivek
