Other Parts Discussed in Thread: SYSBIOS, MATHLIB
I follow the link to add CLI_write() in DSS application and try to print the log to UART port. It fails to compile due to the memory is not available. Can you please help to check this error?
**** Clean-only build of configuration Debug for project ods_pplcount_dss_68xx ****
"I:\\ti\\ccs830\\ccsv8\\utils\\bin\\gmake" -k -j 4 clean -O
DEL /F "ods_pplcount_dss_68xx.hex" "configPkg\linker.cmd" "configPkg\compiler.opt" "ods_pplcount_dss_68xx.xe674"
DEL /F "dss_config_edma_util.oe674" "dss_data_path.oe674" "dss_main.oe674" "gen_twiddle_fft16x16.oe674" "gen_twiddle_fft32x32.oe674" "rx_ch_bias_measure.oe674"
DEL /F "dss_config_edma_util.d" "dss_data_path.d" "dss_main.d" "gen_twiddle_fft16x16.d" "gen_twiddle_fft32x32.d" "rx_ch_bias_measure.d"
RMDIR /S/Q "configPkg\"
找不到 I:\ti\workspace_v8\ods_pplcount_dss_68xx\Debug\ods_pplcount_dss_68xx.hex
找不到 I:\ti\workspace_v8\ods_pplcount_dss_68xx\Debug\ods_pplcount_dss_68xx.xe674
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project ods_pplcount_dss_68xx ****
"I:\\ti\\ccs830\\ccsv8\\utils\\bin\\gmake" -k -j 4 all -O
rm -f I:/ti/workspace_v8/ods_pplcount_dss_68xx/ods_pplcount_dss_68xx.bin
makefile:190: recipe for target 'pre-build' failed
process_begin: CreateProcess(NULL, rm -f I:/ti/workspace_v8/ods_pplcount_dss_68xx/ods_pplcount_dss_68xx.bin, ...) failed.
make (e=2): 系統找不到指定的檔案。
gmake[1]: [pre-build] Error 2 (ignored)
Building file: "../dss_mmw.cfg"
Invoking: XDCtools
"I:/ti/xdctools_3_50_04_43_core/xs" --xdcpath="I:/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR16XX:false:600 -r release -c "I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5" "../dss_mmw.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring dss_mmw.xe674 from package/cfg/dss_mmw_pe674.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making I:/ti/workspace_v8/ods_pplcount_dss_68xx/src/sysbios/sysbios.ae674 ...
gmake[1]: Entering directory `I:/ti/workspace_v8/ods_pplcount_dss_68xx/src/sysbios'
gmake[1]: Nothing to be done for `all'.
gmake[1]: Leaving directory `I:/ti/workspace_v8/ods_pplcount_dss_68xx/src/sysbios'
Build of libraries done.
cle674 package/cfg/dss_mmw_pe674.c ...
Finished building: "../dss_mmw.cfg"
Building file: "../gen_twiddle_fft16x16.c"
Invoking: C6000 Compiler
"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 --include_path="I:/ti/workspace_v8/ods_pplcount_dss_68xx" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common/gtrack" --include_path="I:/ti/mmwave_sdk_03_01_01_02/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=_LITTLE_ENDIAN --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="gen_twiddle_fft16x16.d_raw" --cmd_file="configPkg/compiler.opt" "../gen_twiddle_fft16x16.c"
Finished building: "../gen_twiddle_fft16x16.c"
Building file: "../gen_twiddle_fft32x32.c"
"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 --include_path="I:/ti/workspace_v8/ods_pplcount_dss_68xx" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common/gtrack" --include_path="I:/ti/mmwave_sdk_03_01_01_02/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=_LITTLE_ENDIAN --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="gen_twiddle_fft32x32.d_raw" --cmd_file="configPkg/compiler.opt" "../gen_twiddle_fft32x32.c"
Finished building: "../gen_twiddle_fft32x32.c"
Building file: "../dss_config_edma_util.c"
"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 --include_path="I:/ti/workspace_v8/ods_pplcount_dss_68xx" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common/gtrack" --include_path="I:/ti/mmwave_sdk_03_01_01_02/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=_LITTLE_ENDIAN --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_config_edma_util.d_raw" --cmd_file="configPkg/compiler.opt" "../dss_config_edma_util.c"
Finished building: "../dss_config_edma_util.c"
Building file: "../rx_ch_bias_measure.c"
"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 --include_path="I:/ti/workspace_v8/ods_pplcount_dss_68xx" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common/gtrack" --include_path="I:/ti/mmwave_sdk_03_01_01_02/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=_LITTLE_ENDIAN --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="rx_ch_bias_measure.d_raw" --cmd_file="configPkg/compiler.opt" "../rx_ch_bias_measure.c"
Finished building: "../rx_ch_bias_measure.c"
Building file: "../dss_main.c"
"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 --include_path="I:/ti/workspace_v8/ods_pplcount_dss_68xx" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common/gtrack" --include_path="I:/ti/mmwave_sdk_03_01_01_02/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=_LITTLE_ENDIAN --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_main.d_raw" --cmd_file="configPkg/compiler.opt" "../dss_main.c"
Finished building: "../dss_main.c"
Building file: "../dss_data_path.c"
"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 --include_path="I:/ti/workspace_v8/ods_pplcount_dss_68xx" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common" --include_path="I:/ti/mmwave_industrial_toolbox_3_3_0/labs/lab0020_pplcount_Overhead/src/common/gtrack" --include_path="I:/ti/mmwave_sdk_03_01_01_02/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=_LITTLE_ENDIAN --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_data_path.d_raw" --cmd_file="configPkg/compiler.opt" "../dss_data_path.c"
"../dss_data_path.c", line 2726: warning #179-D: variable "txOrder" was declared but never referenced
"../dss_data_path.c", line 4236: warning #552-D: variable "firstMaxVal" was set but never used
"../dss_data_path.c", line 2649: warning #179-D: function "MmwDemo_rxChanPhaseBiasCompensationAzimElev" was declared but never referenced
Finished building: "../dss_data_path.c"
Building target: "ods_pplcount_dss_68xx.xe674"
Invoking: C6000 Linker
"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=_LITTLE_ENDIAN --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 -z -m"ods_pplcount_dss_68xx.map" --heap_size=0x800 --stack_size=0x800 -i"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/lib" -i"I:/ti/workspace_v8/ods_pplcount_dss_68xx" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/control/mmwave/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/control/mmwavelink/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/drivers/crc/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/drivers/mailbox/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/drivers/osal/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/drivers/soc/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/drivers/uart/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/drivers/edma/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/drivers/adcbuf/lib" -i"I:/ti/mmwave_sdk_03_01_01_02/packages/ti/alg/mmwavelib/lib" -i"C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/lib" -i"C:/ti/mathlib_c674x_3_1_2_1/packages/ti/mathlib/lib" -i"I:/ti/ccs830/ccsv8/tools/compiler/ti-cgt-c6000_8.2.5/include" --reread_libs --disable_auto_rts --diag_warning=225 --diag_wrap=off --display_error_number --warn_sections --xml_link_info="xwr16xx_mmw_dss_linkInfo.xml" --ram_model --unused_section_elimination=on -o "ods_pplcount_dss_68xx.xe674" "./dss_config_edma_util.oe674" "./dss_data_path.oe674" "./dss_main.oe674" "./gen_twiddle_fft16x16.oe674" "./gen_twiddle_fft32x32.oe674" "./rx_ch_bias_measure.oe674" "../c674x_linker.cmd" "../dss_mmw_linker.cmd" -l"configPkg/linker.cmd" -llibosal_xwr16xx.ae674 -llibsoc_xwr16xx.ae674 -llibcrc_xwr16xx.ae674 -llibuart_xwr16xx.ae674 -llibmailbox_xwr16xx.ae674 -llibmmwavelink_xwr16xx.ae674 -llibmmwave_xwr16xx.ae674 -lmathlib.ae674 -ldsplib.ae64P -llibedma_xwr16xx.ae674 -llibadcbuf_xwr16xx.ae674 -llibmmwavealg_xwr16xx.ae674 -lrts6740_elf.lib -llibc.a
<Linking>
"../dss_mmw_linker.cmd", line 48: warning #10068-D: no matching section
"../c674x_linker.cmd", line 87: error #10099-D: program will not fit into available memory. placement with alignment fails for section ".switch" size 0x1e4 . Available memory ranges:
L2SRAM_UMAP0 size: 0x20000 unused: 0x20 max hole: 0x7
L2SRAM_UMAP1 size: 0x20000 unused: 0x0 max hole: 0x0
"../c674x_linker.cmd", line 93: error #10099-D: program will not fit into available memory. placement with alignment fails for section ".neardata" size 0x14 . Available memory ranges:
"../c674x_linker.cmd", line 88: error #10099-D: program will not fit into available memory. run placement with alignment fails for section ".cio" size 0x127 . Available memory ranges:
warning #10370-D: Possible codesize or performance degradation. Section ".text:MmwDemo_interFrameProcessing:dss_data_path.oe674" has calls to rts routines, but rts is placed out of range from call site at 0xe01440, or in a different section. To optimize codesize, either 1) place rts closer to call site, or 2) place rts in same section, or 3) compile with --disable_push_pop.
warning #10370-D: Possible codesize or performance degradation. Section ".text:MmwDemo_interFrameProcessing:dss_data_path.oe674" has calls to rts routines, but rts is placed out of range from call site at 0xe026b8, or in a different section. To optimize codesize, either 1) place rts closer to call site, or 2) place rts in same section, or 3) compile with --disable_push_pop.
warning #10370-D: Possible codesize or performance degradation. Section ".text:SOC_init:libsoc_xwr16xx.ae674<soc.oe674>" has calls to rts routines, but rts is placed out of range from call site at 0x20002fb0, or in a different section. To optimize codesize, either 1) place rts closer to call site, or 2) place rts in same section, or 3) compile with --disable_push_pop.
warning #10370-D: Possible codesize or performance degradation. Section ".text:SOC_init:libsoc_xwr16xx.ae674<soc.oe674>" has calls to rts routines, but rts is placed out of range from call site at 0x20002ea0, or in a different section. To optimize codesize, either 1) place rts closer to call site, or 2) place rts in same section, or 3) compile with --disable_push_pop.
"../dss_mmw_linker.cmd", line 58: error #10099-D: program will not fit into available memory. placement with alignment fails for section ".ovly" size 0x10 . Available memory ranges:
L2SRAM_UMAP0 size: 0x20000 unused: 0xf max hole: 0x7
error #10010: errors encountered during linking; "ods_pplcount_dss_68xx.xe674" not built
>> Compilation failure
makefile:165: recipe for target 'ods_pplcount_dss_68xx.xe674' failed
gmake[2]: *** [ods_pplcount_dss_68xx.xe674] Error 1
makefile:161: recipe for target 'main-build' failed
gmake[1]: *** [main-build] Error 2
makefile:156: recipe for target 'all' failed
gmake: *** [all] Error 2
Thanks.
C.W
