I just saw a post about phase noise in TI E2E Community. The link is below
I don't understand this sentence"For most of the close in signal coupling of TX to RX signal the phase noise component will almost cancel out since the down conversion at the RX also happens using the same LO as the TX. Hence we get the gain of the phase noise cancellation and the SNR is mostly limited by the noise figure of the RX chain."
Could you explain it in more detail?
Why the phase noise leakge signal component will almost cancel out?
And in our system We also found in our AWR1642 radar system that the phase noise is higher than the noise floor, How can we reduce the phase noise?We tried adjusting the parameters of the PLL, but found no registers to configure.
Thanks and regards.
