Other Parts Discussed in Thread: MMWAVE-STUDIO, UNIFLASH, IWR6843
Dear,
I have a bit more legal question on the TI code and hardware usage.
We bought several TI boards and plan to develop our products/code using it. So could you clarify couple of points please:
a) I believe there are no licences restrictions of using any TI tools required for that development (MMWAVE-STUDIO, CCS, Uniflash, complires, etc.)
b) Example code/algorithms from TI labs are really there for example, and it is not meant fro being reused for product development. Is this correct or not? Nevertheless that's all OK with us as we porting fully our own processing code into TI processing.
c) Having said 'b' , there are some hardware algorithm implementations in some SoC, e.g. IWR6843 chip has HWA with FFTs, CFAR, windowing implementations, etc. Since this is a part of chip we can reuse this implementation in our processing pipe with no restrictions.
d) Similar to 'c' applies to all other parts of radar's IC, meaning DMA, ARM, etc.
e) Now question regarding SDK and Industrial tool box:
- what are limitations there?
- SDK has clear indication of "The mmWave SDK is free and does not require any run-time royalties to TI.”", I couldn't find similar in Industrial toolbox.
- Since Labs are part of Industrial toolbox, is it possible to use example projects from Industrial toolbox to build on top of that? Can we reuse the project structure, compiler&linker settings, etc.?
Libraries, which are called, what are restrictions there? Just as an example, target tracker is also called as a library, can we use this library?
Please comment and provide some document points if possible so we can refer to?
Thank you
