Hi Sir,
Per tidu835, pls give some advice about the distance between the magnet and sensor? or pls tell us the distance in this reference. The magnet used in this design, how much is the magnetic strength?
Hi Sir,
Hello Sara,
I am not sure of the exact distance, but looking into this design further, it turns out that the magnet is no longer available from the manufacturer, so either way you would need to re-calculate the distance for your specific magnet. On a general note, excess magnetic field is not bad for the sensor, so you can put the magnet fairly close if desired.
