CCS/IWR6843: Replacing Roger material
Part Number: IWR6843
We would like to make samlple PCB using IWR68xx based PCB desigin.
Would the following material be fine(acceptable)?
       We have not evaluated the antenna performance/design with RO4350BLOPRO material so you will need to evaluate it yourself and design the antenna accordingly.
    For FR4 material replacement you may want to consider controlled impedance (100 Ohm differential) for the LVDS lines.
    Thanks and regards,
    CHETHAN KUMAR Y.B.
