HDC2010: How to validate the accuracy of HDC2010 Temperature sensor
Part Number: HDC2010
I am using HDC2010 Temperature & Humidity sensor.
I want to validate the accuracy of +/- 0.2 oC.
In our Temperature chamber I created a profile from +25 oC to -25 oC as below
1) 25 oC to 20 oC will be reached within 5 minutes ( 1 oC per 1 minute) and then at 20 oC wait for 10 minutes.
2) 20 oC to 15 oC will be reached within 5 minutes ( 1 oC per 1 minute) and then at 15 oC wait for 10 minutes.
Above steps will be continued till below
n-1) -15 oC to -20 oC will be reached within 5 minutes ( 1 oC per 1 minute) and then at -20 oC wait for 10 minutes.
n)    -20 oC to -25 oC will be reached within 5 minutes ( 1 oC per 1 minute) and then at -25 oC wait for 10 minutes.
Is above procedure is right or if there is any other alternate approach, please let me know. We have a stringent temperature accuracy requirement.
 Can you please share your test procedure with respect to Temperature & Humidity sensor accuracy.
Thanks & Regards
Vishnu Beema
