CCS/IWR6843ISK-ODS: Estimator values
Part Number: IWR6843ISK-ODS
Hi ,I want to verify the values i get on the estimator.
here's the screenshot
6242.Validate.pdf
The required configuration is:
IWR6843ODS
3Tx, 4Rx
max range 20[m]
range resolution:15[cm]
maximum velocity 23.04 Km/Hr =6m/sec
velocity resolution 0.36km/hr = 0.1 m/sec
I've loaded with a bit different configuration than this regarding the velocities because the resulting values are different:
1. as appear at the screenshot ,there are 64 doppler bins, when each bin has 0.1 [m/sec]
    Therefore ,the maximum velocity is 64*0.1=6.4m/sec =6.4*3.6=23.04 Km/Hr
    pay attention that at the estimator, the required max velocity is 10.8 Km/Hr
    Why is it so ?
    Maybe the 23.04/2=11.520 is close to 10.8 Km/hr ?
2.Range=0.9*Fs*c/(2*Slope)=0.9*3000e3*3e8/(2*7.97e12)=50[m]
   While i requested 20[m]
3.Range resolution=c/(2*B)
   B=Tchirp*Frequency_slope=1.057e9[Hz]
   Range resolution=c/(2*B)= 0.14191[m]
   While at the estimator output the range resolution appears as 0.11[m]
4. Tchirp
   Tchirp=B/Frequency_slope=1.057e9/7.97e12=132.63e-6[sec]
   Therefore, Tchirp is actually according to this calculation and from the estimator GUI is the ramp end time.
4. Vmax=(c/f)/(4*Tchirp)=(c/60e9)/(4*132.62e-6)=9.4254[m/sec]
    This contradicts the resulting max velocity as appears from the velocity_resolutionXnumber_of_doppler_bins =64*0.1=6.4[m/sec]
    Also,the Vmax = 9.4254[m/sec] = 33.931 [Km/Hr]
Please follow the calculations,
I've read other posts that showed such difference:
https://e2e.ti.com/support/sensors/f/1023/t/691077?AWR1443BOOST-Data-capture-and-the-configuration-file
    "configGenerator": {
        "createdBy": "mmWaveSensingEstimator",
        "createdOn": "2019-07-23T11:04:35.708Z",
        "isConfigIntermediate": 0
    "currentVersion": {
        "jsonCfgVersion": {
            "major": 0,
            "minor": 4,
            "patch": 0
        "DFPVersion": {
            "major": 1,
            "minor": 2,
            "patch": 0
        "SDKVersion": {
            "major": 3,
            "minor": 0,
            "patch": 0
        "mmwavelinkVersion": {
            "major": 1,
            "minor": 2,
            "patch": 0
    "lastBackwardCompatibleVersion": {
        "DFPVersion": {
            "major": 1,
            "minor": 1,
            "patch": 0
        "SDKVersion": {
            "major": 2,
            "minor": 0,
            "patch": 0
            "major": 1,
            "minor": 1,
            "patch": 0
    "systemConfig": {
        "summary": "",
        "sceneParameters": {
            "ambientTemperature_degC": 20,
            "maxDetectableRange_m": 20,
            "rangeResolution_cm": 15,
            "maxVelocity_kmph": 10.8,
            "velocityResolution_kmph": 0.54,
            "measurementRate": 10,
            "typicalDetectedObjectRCS": 1
    "regulatoryRestrictions": {
        "frequencyRangeBegin_GHz": 77,
        "frequencyRangeEnd_GHz": 81,
        "maxBandwidthAllowed_MHz": 4000,
        "maxTransmitPowerAllowed_dBm": 12
    "processingChainConfig": {
        "detectionChain": {
            "name": "",
            "detectionLoss": 1,
            "systemLoss": 1,
            "implementationMargin": 2,
            "detectionSNR": 12,
            "theoreticalRxAntennaGain": 9,
            "theoreticalTxAntennaGain": 9
    "mmWaveDevices": [
            "mmWaveDeviceId": 0,
            "rfConfig": {
                "summary": "",
                "waveformType": "singleFrameChirp",
                "MIMOScheme": "TDM",
                "rlChanCfg_t": {
                    "rxChannelEn": "0xF",
                    "txChannelEn": "0x7"
                "rlAdcOutCfg_t": {
                    "fmt": {
                        "b2AdcBits": 2,
                        "b8FullScaleReducFctr": 0,
                        "b2AdcOutFmt": 2
                "rlLowPowerModeCfg_t": {},
                "rlProfiles": [
                        "rlProfileCfg_t": {
                            "profileId": 0,
                            "pfVcoSelect": "0x0",
                            "pfCalLutUpdate": "0x0",
                            "startFreqConst_GHz": 60,
                            "idleTimeConst_usec": 5,
                            "adcStartTimeConst_usec": 6.4,
                            "rampEndTime_usec": 132.73333333333332,
                            "txOutPowerBackoffCode": "0x0",
                            "txPhaseShifter": "0x0",
                            "freqSlopeConst_MHz_usec": 7.966160774230957,
                            "txStartTime_usec": 1,
                            "numAdcSamples": 376,
                            "digOutSampleRate": 10000,
                            "hpfCornerFreq1": 0,
                            "hpfCornerFreq2": 0,
                            "rxGain_dB": "0x1E"
                "rlChirps": [
                        "rlChirpCfg_t": {
                            "chirpStartIdx": 0,
                            "chirpEndIdx": 0,
                            "profileId": 0,
                            "startFreqVar_MHz": 0,
                            "freqSlopeVar_KHz_usec": 0,
                            "idleTimeVar_usec": 0,
                            "adcStartTimeVar_usec": 0,
                            "txEnable": "0x1"
                "rlRfCalMonTimeUntConf_t": {
                    "calibMonTimeUnit": 1
                "rlRfCalMonFreqLimitConf_t": {
                    "freqLimitLow_GHz": 77,
                    "freqLimitHigh_GHz": 81
                "rlRfInitCalConf_t": {
                    "calibEnMask": "0x1FF0"
                "rlRunTimeCalibConf_t": {
                    "oneTimeCalibEnMask": "0x0",
                    "periodicCalibEnMask": "0x0",
                    "calibPeriodicity": 10,
                    "reportEn": 1,
                    "txPowerCalMode": 0
                "rlFrameCfg_t": {
                    "chirpEndIdx": 0,
                    "chirpStartIdx": 0,
                    "numLoops": 41,
                    "numFrames": 0,
                    "framePeriodicity_msec": 16.933
            "rawDataCaptureConfig": {
                "rlDevDataFmtCfg_t": {
                    "iqSwapSel": 0,
                    "chInterleave": 1
            "monitoringConfig": {}
Thank you
Gil
  • Former Member
    0 Former Member
    Your screenshot is cutoff.
    There will be differences between what your input value and the resulting configuration from the sensing estimator as it is not a fully bounded problem. The resulting configuration is calculated based on your inputs but cannot match exactly.
    If you want to see the formulas you can view the source code for the estimator.
    Amanda
