Other Parts Discussed in Thread: AWR1642
when I enable streaming of all data (range and Doppler heat-maps) the data UART can't seem to handle higher frame rates and I'm forced to reduce the frame rate to 1 or 2 FPS which is very low for my application.
I wanted to know if there is a way to increase the frame rate while keeping sama data streaming configuration?
I was thinking of maybe applying some form of data compression before streaming inside the AWR1642 firmware project so I can maybe get 10 FPS?
I'm also considering buying TI DCA1000 to capture data, but my concern is that I will endup with raw ADC captures, and will have to repeat the processing on the captured data, which is not trivial task I guess.
any recommendations?
Ahmed
