AWR1243: Programming the AWR1243 to Transmit CW from TDA3
Part Number: AWR1243
I submitted an E2E ticket to request support in this link to the TDA3 team:
http://e2e.ti.com/support/processors/f/791/p/832932/3085897#3085897
The instruction given by the TDA3 team is to follow the Doc in the AWR1xxx_Interface_Control.pdf. The steps to carry out the implementation is quite involved and very complicated to simply enable CW. I would like to find out if the AWR team has existing code sample written to enable CW from TDA3 side. The application environment is as follows:
We initially boot up the TDA3 and initialize the AWR1243 into chirp base configuration. Upon user request to switch to CW, we would like to turn off TX chirping mode and begin transmitting CW mode. We do not care about processing the CW returned data as that's not our goal. Our goal is to turn on CW transmission so we can measure the power level of our antenna easier as the transmit signal is simply a single frequency tone.
--Khai
