is the reflection of the the 60GHz signal damping in humid air? Do you have any experiences or measurements?
Regards, Holger
Regards, Holger
HI Holger,
Please check the following thread where similar discussion exists. We have not done any comparative measurements.
Vaibhav
Hi, Holger:
Please see the video for mmwave performance over the rain. https://training.ti.com/sense-world-ti-mmwave-see-through-rain-and-walls-and-detect-small-objects?cu=1128486
Zigang
I want to know if you could measure humidity in a room with our radar sensor.
HI, Holger:
We have not done any experiment to measure humidity using radar. As mentioned in www.its.bldrdoc.gov/.../85-171_ocr.pdf
Gaseous oxygen and water vapor, suspended water droplets are considered to be the principal absorbers for the radar frequency. The propagation loss and delay will be related to humidity and oxygen. One thing they can try is to setup radar with a fixed target, then record the signal with different humidity level. One challenge I can see is how we can separate humidity effect from other variations like oxygen level, board temperature change and etc.
Zigang
I think you have to read the humidity level out of the SNR information. Right? Is the SNR information sensitive enough? What resolution can be expected?
Regards, Holger
Hi, Holger:
I believe that humidity will impact signal level. If the noise level is constant, then SNR can be used. But again, we never did any test. I am not sure what resolution to expect.
Zigang
