Hi
We are using AWR1243P chips to achieve cascading !
In order to make the master work normally , the master must use its own looped back LO and DIG_SYNC lines to trigger the frame. Am I right?
If I just just use its own looped back DIG_SYNC but without use its LO (we don't use master to radiate) ,can the master works normally? (I have found that In this case the master seems can't do the frame trigger and
there's no chrip signal output from FM_CW_SYNCOUT just a point Freq signal)
