IWR6843AOPEVM: A timeout occurred before the Terminator was reached.
Part Number: IWR6843AOPEVM
Other Parts Discussed in Thread: IWR6843AOP
I am following the demo lab "Area Scanner v1.x Overview" (http://dev.ti.com/tirex/explore/node?node=AKh-b7R2LuJ-q2HeG2Gi8Q__VLyFKFf__LATEST) with IWR6843AOP board, and the flashing step was successful. But when running the lab, something wrong happened. The main visualizer appeared, COM port connection was successful but failed to load the config (.cfg) file. The error codes were as follow:
Starting UI for mmWave Area Scanner Demo ....
comportnum_str =
'COM4'
comportnum_str =
'COM3'
Opening configuration file C:\ti\mmwave_industrial_toolbox_4_0_0\labs\area_scanner\68xx_area_scanner_v1\chirp_configs\mmw_area_scanner_68xxAOP.cfg ...
tlSize =
8
Sending configuration from C:\ti\mmwave_industrial_toolbox_4_0_0\labs\area_scanner\68xx_area_scanner_v1\chirp_configs\mmw_area_scanner_68xxAOP.cfg file to IWR16xx ...
警告: 意外警告: A timeout occurred before the Terminator was reached.
警告: 读取失败: The specified amount of data was not returned within the Timeout period.。
% Created for SDK ver:03.02
And the IWR6843AOP had been set to functional mode (S3 off). Do you know what I should do to fix that issue?
Thanks!
Chengzhe
