Other Parts Discussed in Thread: AWR1642
My customer found the NERR_OUT LED glows after CPU reset in CCS. I also tried on AWR1843BOOST revC and I can reproduce it. The problem may not happen every time, but can reproduce easily.
When the boards power on, the LED of NERR_OUT is off. It will turn on after clicking CPU reset in CCS. Below is the ESM register info when NEER_OUT LED glows. You can see ESMSR2=0x4.
I checked the TRM and found the error is MSS_ESM Group 2 MSS_TCMA_PARITY_ERR( Error Signal: Parity Error on Control signals for MSS_TCMA).
Would you pls kindly advise why CPU reset in CCS causes this error?
After above steps, I also tried to disconnect the R4F core and reset the board by pressing the reset button (LED of NERR_OUT turns off). Then connect the R4F , then do CPU reset in CCS and I found there will no ESM error and the LED of NERR_OUT keeps off.
Do you have any idea on this phenomena? Why after warm reset, the CPU reset in CCS will not cause an internal error?
