Hi i wanted to decrease field of view can i ?
Hi Adnan,
Typically field of view of mmWave sensor is governed by Antenna configuration. However you could reduce the field of view after post processing (i.e Range, Velocity, Angle estimation) depending upon your application. Based on the post processed data you could choose to use data corresponding to your choice of field of view. Processing chain would use full field of view of Antenna.
However, native field of view is decided by antenna configuration. At sensor level if you want to change the field of view then antennas have to be redesigned.
Thanks and regards,
CHETHAN KUMAR Y.B.
