AWR1843BOOST: Hardcoding config onto the device
Part Number: AWR1843BOOST
i'm running out of box demo which was in the Industrial toolbox.
I need to hardcode the config file onto the device so that when the device turns ON,it starts transmitting data over UART without waiting for config file which will be fed from using CLI.
is there any example demos available in SDK3.3
Vimal
  • Former Member
    0 Former Member
    Please see these threads for instructions and details. The process for SDK 3.3 would be almost exactly the same except you want to make the modifcations to the cli.c file in the SDK 3.3. For convenience, I've attached an example modified cli.c for SDK 3.3 here. Please follow the same procedures otherwise.
    https://e2e.ti.com/support/sensors/f/1023/p/708175/2616079#2616079
    https://e2e.ti.com/support/sensors/f/1023/p/837021/3110725#3110725
    Amanda
     *   @file  cli.c
     *   @brief
     *      CLI Utility implementation
     *  \par
     *  NOTE:
     *      (C) Copyright 2016 Texas Instruments, Inc.
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *************************** Include Files ********************************
    /* Standard Include Files. */
    #include <stdint.h>
    #include <stdlib.h>
    #include <stddef.h>
    #include <string.h>
    #include <stdio.h>
    /* BIOS/XDC Include Files. */
    #include <xdc/std.h>
    #include <ti/sysbios/knl/Task.h>
    /* mmWave SDK Include Files: */
    #include <ti/common/sys_common.h>
    #include <ti/drivers/uart/UART.h>
    #include <ti/utils/cli/cli.h>
    #include <ti/utils/cli/include/cli_internal.h>
     *************************** Hard-coded Configuation **********************
    #define USE_HARD_CODED_CONFIG
    #ifdef USE_HARD_CODED_CONFIG
    int32_t hardCodedConfigIndex;
    char * hardCodedConfigCommands[] =
    "sensorStop",
    "flushCfg",
    "dfeDataOutputMode 1",
    "channelCfg 15 7 0",
    "adcCfg 2 1",
    "adcbufCfg -1 0 1 1 1",
    "lowPower 0 0",
    "profileCfg 0 77 7 3 39 0 0 100 1 256 7200 0 0 30",
    "chirpCfg 0 0 0 0 0 0 0 1",
    "chirpCfg 1 1 0 0 0 0 0 4",
    "chirpCfg 2 2 0 0 0 0 0 2",
    "frameCfg 0 2 32 0 100 1 0",
    "guiMonitor -1 1 1 1 0 0 1",
    "cfarCfg -1 0 2 8 4 3 0 15.0 0",
    "cfarCfg -1 1 0 4 2 3 1 15.0 0",
    "multiObjBeamForming -1 1 0.5",
    "calibDcRangeSig -1 0 -5 8 256",
    "clutterRemoval -1 0",
    "compRangeBiasAndRxChanPhase 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0",
    "measureRangeBiasAndRxChanPhase 0 1. 0.2",
    "aoaFovCfg -1 -90 90 -90 90",
    "cfarFovCfg -1 0 0.25 8.64",
    "cfarFovCfg -1 1 -7.06 7.06",
    "extendedMaxVelocity -1 0",
    "CQRxSatMonitor 0 3 11 121 0",
    "CQSigImgMonitor 0 127 8",
    "analogMonitor 0 0",
    "lvdsStreamCfg -1 0 0 0",
    "sensorStart",
    #endif
     *************************** Global Variables *****************************
     * @brief   Global variable which tracks the CLI MCB
    CLI_MCB     gCLI;
     **************************** CLI Functions *******************************
     *  @b Description
     *  @n
     *      The function is the HELP generated by the CLI Module
     *  \ingroup CLI_UTIL_INTERNAL_FUNCTION
     *  @retval
     *      Not Applicable.
    static int32_t CLI_help (int32_t argc, char* argv[])
        uint32_t    index;
        /* Display the banner: */
        CLI_write ("Help: This will display the usage of the CLI commands\n");
        CLI_write ("Command: Help Description\n");
        /* Cycle through all the registered CLI commands: */
        for (index = 0; index < gCLI.numCLICommands; index++)
            /* Display the help string*/
            CLI_write ("%s: %s\n",
                        gCLI.cfg.tableEntry[index].cmd,
                       (gCLI.cfg.tableEntry[index].helpString == NULL) ?
                        "No help available" :
                        gCLI.cfg.tableEntry[index].helpString);
        /* Is the mmWave Extension enabled? */
        if (gCLI.cfg.enableMMWaveExtension == 1U)
            /* YES: Pass the control to the extension help handler. */
            CLI_MMWaveExtensionHelp ();
        return 0;
     *  @b Description
     *  @n
     *      This is the CLI Execution Task
     *  @retval
     *      Not Applicable.
    static void CLI_task(UArg arg0, UArg arg1)
        uint8_t                 cmdString[256];
        char*                   tokenizedArgs[CLI_MAX_ARGS];
        char*                   ptrCLICommand;
        char                    delimitter[] = " \r\n";
        uint32_t                argIndex;
        CLI_CmdTableEntry*      ptrCLICommandEntry;
        int32_t                 cliStatus;
        uint32_t                index;
        /* Do we have a banner to be displayed? */
        if (gCLI.cfg.cliBanner != NULL)
            /* YES: Display the banner */
            CLI_write (gCLI.cfg.cliBanner);
        hardCodedConfigIndex = 0;
        CLI_write ("Wait some time for system to initialize...\n");
        Task_sleep(100);
        CLI_write ("Performing hard-coded config\n");
    #endif
        /* Loop around forever: */
        while (1)
            /* Demo Prompt: */
            CLI_write (gCLI.cfg.cliPrompt);
            /* Reset the command string: */
            memset ((void *)&cmdString[0], 0, sizeof(cmdString));
            /* Run hard-coded commands, one at a time until '!!!END_OF_HARD_CODED_COMMANDS' is reached: */
            if (hardCodedConfigCommands[hardCodedConfigIndex][0] != '!')
                //CLI_write (hardCodedConfigCommands[hardCodedConfigIndex]);
                CLI_write ("Command\n");
                memcpy((void *)&cmdString[0], (void *)hardCodedConfigCommands[hardCodedConfigIndex], strlen(hardCodedConfigCommands[hardCodedConfigIndex]));
                hardCodedConfigIndex++;
            /* Accept commands from UART after all hard-coded commands done: */
            else
                /* Read the command message from the UART: */
                UART_read (gCLI.cfg.cliUartHandle, &cmdString[0], (sizeof(cmdString) - 1));
    #else
    #endif
            /* Reset all the tokenized arguments: */
            memset ((void *)&tokenizedArgs, 0, sizeof(tokenizedArgs));
            argIndex      = 0;
            ptrCLICommand = (char*)&cmdString[0];
            /* comment lines found - ignore the whole line*/
            if (cmdString[0]=='%') {
                CLI_write ("Skipped\n");
                continue;
            /* Set the CLI status: */
            cliStatus = -1;
            /* The command has been entered we now tokenize the command message */
            while (1)
                /* Tokenize the arguments: */
                tokenizedArgs[argIndex] = strtok(ptrCLICommand, delimitter);
                if (tokenizedArgs[argIndex] == NULL)
                    break;
                /* Increment the argument index: */
                argIndex++;
                if (argIndex >= CLI_MAX_ARGS)
                    break;
                /* Reset the command string */
                ptrCLICommand = NULL;
            /* Were we able to tokenize the CLI command? */
            if (argIndex == 0)
                continue;
                ptrCLICommandEntry = &gCLI.cfg.tableEntry[index];
                /* Do we have a match? */
                if (strcmp(ptrCLICommandEntry->cmd, tokenizedArgs[0]) == 0)
                    /* YES: Pass this to the CLI registered function */
                    cliStatus = ptrCLICommandEntry->cmdHandlerFxn (argIndex, tokenizedArgs);
                    if (cliStatus == 0)
                        CLI_write ("Done\n");
                    else
                        CLI_write ("Error %d\n", cliStatus);
                    break;
            /* Did we get a matching CLI command? */
            if (index == gCLI.numCLICommands)
                /* NO matching command found. Is the mmWave extension enabled? */
                    /* Yes: Pass this to the mmWave extension handler */
                    cliStatus = CLI_MMWaveExtensionHandler (argIndex, tokenizedArgs);
                /* Was the CLI command found? */
                if (cliStatus == -1)
                    /* No: The command was still not found */
                    CLI_write ("'%s' is not recognized as a CLI command\n", tokenizedArgs[0]);
     *  @b Description
     *  @n
     *      Logging function which can log the messages to the CLI console
     *  @param[in]  format
     *      Format string
     *  \ingroup CLI_UTIL_EXTERNAL_FUNCTION
     *  @retval
     *      Not Applicable.
    void CLI_write (const char* format, ...)
        va_list     arg;
        char        logMessage[256];
        int32_t     sizeMessage;
        /* Format the message: */
        va_start (arg, format);
        sizeMessage = vsnprintf (&logMessage[0], sizeof(logMessage), format, arg);
        va_end (arg);
        /* If CLI_write is called before CLI init has happened, return */
        if (gCLI.cfg.cliUartHandle == NULL)
            return;
        /* Log the message on the UART CLI console: */
        if (gCLI.cfg.usePolledMode == true)
            /* Polled mode: */
            UART_writePolling (gCLI.cfg.cliUartHandle, (uint8_t*)&logMessage[0], sizeMessage);
        else
            /* Blocking Mode: */
            UART_write (gCLI.cfg.cliUartHandle, (uint8_t*)&logMessage[0], sizeMessage);
     *  @b Description
     *  @n
     *      This is the function which is used to initialize and setup the CLI
     *  @param[in]  ptrCLICfg
     *      Pointer to the CLI configuration
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    int32_t CLI_open (CLI_Cfg* ptrCLICfg)
        Task_Params     taskParams;
        uint32_t        index;
        /* Sanity Check: Validate the arguments */
        if (ptrCLICfg == NULL)
            return -1;
        /* Initialize the CLI MCB: */
        memset ((void*)&gCLI, 0, sizeof(CLI_MCB));
        /* Copy over the configuration: */
        memcpy ((void *)&gCLI.cfg, (void *)ptrCLICfg, sizeof(CLI_Cfg));
        /* Cycle through and determine the number of supported CLI commands: */
        for (index = 0; index < CLI_MAX_CMD; index++)
            /* Do we have a valid entry? */
            if (gCLI.cfg.tableEntry[index].cmd == NULL)
                /* NO: This is the last entry */
                break;
            else
                /* YES: Increment the number of CLI commands */
                gCLI.numCLICommands = gCLI.numCLICommands + 1;
            /* YES: Initialize the CLI Extension: */
            if (CLI_MMWaveExtensionInit (ptrCLICfg) < 0)
                return -1;
        /* Do we have a CLI Prompt specified?  */
        if (gCLI.cfg.cliPrompt == NULL)
            gCLI.cfg.cliPrompt = "CLI:/>";
        /* The CLI provides a help command by default:
         * - Since we are adding this at the end of the table; a user of this module can also
         *   override this to provide its own implementation. */
        gCLI.cfg.tableEntry[gCLI.numCLICommands].cmd           = "help";
        gCLI.cfg.tableEntry[gCLI.numCLICommands].helpString    = NULL;
        gCLI.cfg.tableEntry[gCLI.numCLICommands].cmdHandlerFxn = CLI_help;
        /* Increment the number of CLI commands: */
        gCLI.numCLICommands++;
        /* Initialize the task parameters and launch the CLI Task: */
        Task_Params_init(&taskParams);
        taskParams.priority  = gCLI.cfg.taskPriority;
        taskParams.stackSize = 4*1024;
        gCLI.cliTaskHandle = Task_create(CLI_task, &taskParams, NULL);
        return 0;
     *  @b Description
     *  @n
     *      This is the function which is used to close the CLI module
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    int32_t CLI_close (void)
        /* Shutdown the CLI Task */
        Task_delete(&gCLI.cliTaskHandle);
        /* Cleanup the memory */
        return 0;
  • Hi Amanda,
    i have followed the steps mentioned in the above link.i'm using out of box demo from industrial toolbox 4.1V.
    i'm not getting any data in the cli port and also cli is also not working.
    Vimal
  • Former Member
    0 Former Member in reply to Vimal Prasath
    Hello Vimal,
    I'm sorry - the wrong file must've been attached it's missing the last line needed for the hardcoded config to work. I've attached the version that I've tested and the hard coded config works without issue. You should see data on the terminal immediately after setting your COM port settings.
    Amanda
     *   @file  cli.c
     *   @brief
     *  \par
     *  NOTE:
     *  are met:
     *    distribution.
    #include <stdint.h>
    #include <stdlib.h>
    #include <stddef.h>
    #include <string.h>
    #include <stdio.h>
    "sensorStop",
    "flushCfg",
    "adcCfg 2 1",
    "lowPower 0 0",
    "sensorStart",
    "!!!END_OF_HARD_CODED_COMMANDS"
    #endif
    CLI_MCB     gCLI;
     *  @b Description
     *  @n
     *  @retval
     *      Not Applicable.
        uint32_t    index;
        return 0;
     *  @b Description
     *  @n
     *  @retval
     *      Not Applicable.
        uint32_t                argIndex;
        int32_t                 cliStatus;
        uint32_t                index;
        Task_sleep(100);
    #endif
        while (1)
            /* Demo Prompt: */
            else
    #else
    #endif
            argIndex      = 0;
                continue;
            cliStatus = -1;
            while (1)
                    break;
                argIndex++;
                    break;
            if (argIndex == 0)
                continue;
                    if (cliStatus == 0)
                    else
                    break;
     *  @b Description
     *  @n
     *  @param[in]  format
     *      Format string
     *  @retval
     *      Not Applicable.
        va_list     arg;
        va_end (arg);
            return;
            /* Polled mode: */
        else
     *  @b Description
     *  @n
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
        uint32_t        index;
            return -1;
                break;
            else
                return -1;
        return 0;
     *  @b Description
     *  @n
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
        return 0;
  • Thanks,
    It is working.
