HI together,
here on e2e and I believe in some whitepapers it says that elevation angle is +/- 15 degrees and azimuth is +/- 60 degrees. However, in the User Guide we're only given an antenna pattern (Figure 11). So, how is the FOV defined? By the 0 dB crossings? Usually - when referring to beampatterns - the 3dB / FWHM bandwidth is a common figure to give.
Best regards
