Good evening:
I am trying to reproduce the results described in the Application Report SNOA925 for the FDC1004EVM
As a first step I am making sure I understand the level calculation and its correction.
Using the data in Table 3, OOP Approach Experimental Results, I am able to calculate the level shown for the "Baseline'Results and my result agree with the table.
What I do not understand is how to apply the "first order linear correction algorithm applied with a gain and offset setting of 1.23 and -0.6" described in Section 4.3.1 of the report. Is this correction applied to the level calculation, to the Level Meas capacitance or to both the Level Capacitance and to the Reference Capacitance. Could you please help me with an explicit calculation/formula for applying this correction and provide a table of your calculated results using the Baseline results from Table 3. There is no table in the Application Report listing the corrected calculated values.
