DCA1000EVM: Error at the end of Measurement
Part Number: DCA1000EVM
Other Parts Discussed in Thread: AWR1642BOOST
Hi, I was able to take data on mmWave Studio Version 2.1 but at the end it throws an error and I don't know what the error is for.
Weilung
GM: Constructor
GM: Mon Oct 28 15:15:22 2019
RSTD.Transmit("/Settings")
[15:15:22]
[15:15:22]  ### Running Startup script: "C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Scripts\Startup.lua" ###
[15:15:22]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[15:15:22]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[15:15:22]  Scripter ignored: Attempt to UnBuild() again or before Build.
[15:15:22]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[15:15:22]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[15:15:22]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[15:15:22]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[15:15:22]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[15:15:22]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[15:15:22]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
[15:15:22]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[15:15:22]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[15:15:22]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[15:15:22]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[15:15:22]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[15:15:22]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[15:15:22]  RSTD.Transmit("/")
[15:15:22]  RSTD.SaveSettings(): Settings saved to "C:\Users\weilu\AppData\Roaming\RSTD\config.xml"
[15:15:22]  RSTD.Build()
[15:15:22]  RSTD.AL_Build()
[15:15:22]  RSTD.AL_LoadXml()
[15:15:22]  RSTD.AL_Init()
[15:15:22]  RSTD.Clients_Build()
[15:15:23]  GM: Init
[15:15:23]  GM: Loaded 'C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Clients\\LabClient.dll'
[15:15:23]  GM: 1 Guest (s) init
[15:15:23]  GM: 1 Module(s) init
[15:15:23]  GM: 2 Tab   (s) init
[15:15:23]  RSTD.Client_LoadXml()
[15:15:23]  [RadarAPI]: ar1.selectRadarMode(0)
[15:15:23]  [RadarAPI]: Status: Passed
[15:15:23]  Matlab Runtime Engine is installed
[15:15:23]  [RadarAPI]: Starting Matlab Engine..
[15:15:30]  [RadarAPI]: Matlab Engine Started!
[15:15:33]  [RadarAPI]: ar1.selectCascadeMode(0)
[15:15:33]  [RadarAPI]: Status: Passed
[15:15:33]  [RadarAPI]: ar1.LoadSettings('C:\Users\weilu\AppData\Roaming\RSTD\ar1gui.ini')
[15:15:34]  TESTING = false
[15:15:34]  RstdNet: Port 2777: Listening..
[15:15:34]
[15:15:34]  ***Script completed successfully.***
[15:15:41]  [RadarAPI]: Opening Gpio Control Port()
[15:15:41]  [RadarAPI]: Status: Passed
[15:15:41]  [RadarAPI]: Opening Board Control Port()
[15:15:42]  [RadarAPI]: ar1.FullReset()
[15:15:42]  [RadarAPI]: Status: Passed
[15:15:43]  [RadarAPI]: Closing Board Control Port()
[15:15:43]  [RadarAPI]: Status: Passed
[15:15:43]  [RadarAPI]: Closing Gpio Control Port()
[15:15:43]  [RadarAPI]: ar1.SOPControl(2)
[15:15:44]  [RadarAPI]: ar1.Connect(9,921600,1000)
[15:15:46]  [RadarAPI]: Warning: Connected with baudrate 115200
[15:15:47]  [RadarAPI]: Warning: Disconnected existing BaudRate
[15:15:48]  [RadarAPI]: Warning: Trying to connect with baudrate 921600
[15:15:49]  [RadarAPI]: ar1.Calling_IsConnected()
[15:15:50]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
[15:15:50]  [RadarAPI]: Status: Passed
[15:15:50]  [RadarAPI]: ar1.deviceVariantSelection("XWR1642")
[15:15:50]  [RadarAPI]: ar1.frequencyBandSelection("77G")
[15:15:50]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[15:15:51]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[15:15:51]  [RadarAPI]: ar1.SaveSettings('C:\Users\weilu\AppData\Roaming\RSTD\ar1gui.ini')
[15:15:52]  [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
[15:15:53]  [RadarAPI]: Downloading BSS Patch RPRC Binary..
[15:15:55]  [RadarAPI]: ar1.GetBSSFwVersion()
[15:15:55]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[15:15:56]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
[15:15:56]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[15:15:57]  [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
[15:15:57]  [RadarAPI]: Downloading MSS RPRC Binary..
[15:15:59]  [RadarAPI]: ar1.GetMSSFwVersion()
[15:15:59]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[15:16:02]  [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[15:16:02]  [RadarAPI]: Status: Passed
[15:16:02]  MSS power up done async event received!
[15:16:04]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
[15:16:04]  [RadarAPI]: Status: Passed
[15:16:04]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[15:16:04]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[15:16:04]  [RadarAPI]: ar1.RfEnable()
[15:16:04]  BSS power up done async event received!
[15:16:05]  [RadarAPI]: ar1.GetMSSFwVersion()
[15:16:05]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[15:16:05]  [RadarAPI]: ar1.GetBSSFwVersion()
[15:16:05]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[15:16:06]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
[15:16:06]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[15:16:09]  [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0)
[15:16:09]  [RadarAPI]: Status: Passed
[15:16:12]  [RadarAPI]: ar1.LPModConfig(0, 1)
[15:16:12]  [RadarAPI]: Status: Passed
[15:16:13]  [RadarAPI]: ar1.RfInit()
[15:16:13]  [RadarAPI]: Status: Passed
[15:16:13]  RF Init async event received!
[15:16:13]  [RadarAPI]: Time stamp, Temperture: 9325,32; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 1, 1;
[15:16:20]  [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[15:16:20]  [RadarAPI]: Status: Passed
[15:16:21]  [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[15:16:21]  [RadarAPI]: Status: Passed
[15:16:22]  [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[15:16:22]  [RadarAPI]: Status: Passed
[15:16:29]  [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 6250, 0, 0, 30)
[15:16:29]  [RadarAPI]: Status: Passed
[15:16:30]  [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[15:16:30]  [RadarAPI]: Status: Passed
[15:16:32]  Test Source Already Disabled...!!!
[15:16:32]  [RadarAPI]: ar1.DisableTestSource(0)
[15:16:32]  [RadarAPI]: Status: Passed
[15:16:32]  [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[15:16:33]  [RadarAPI]: ar1.GetCaptureCardDllVersion()
[15:16:34]  [RadarAPI]: Sending dll_version command to DCA1000
[15:16:34]  DLL Version : 1.0
[15:16:34]  [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[15:16:34]  [RadarAPI]: Status: Passed
[15:16:35]  [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[15:16:35]  [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[15:16:35]  [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[15:16:35]  [RadarAPI]: Sending fpga command to DCA1000
[15:16:35]  FPGA Configuration command : Success
[15:16:35]  [RadarAPI]: Sending record command to DCA1000
[15:16:35]  Configure Record command : Success
[15:16:35]  [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[15:16:35]  [RadarAPI]: Sending fpga_version command to DCA1000
[15:16:35]
[15:16:35]  FPGA Version : 2.7 [Record]
[15:16:35]
[15:16:39]  [RadarAPI]: ar1.CaptureCardConfig_StartRecord("C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[15:16:39]  [RadarAPI]: Sending start_record command to DCA1000
[15:16:41]  [RadarAPI]: ar1.StartFrame()
[15:16:43]  [RadarAPI]:
[15:16:43]  Start Record command : Success
[15:16:43]
[15:16:43]  Record is completed
[15:16:43]
[15:16:43]  Record stop is done successfully
[15:16:45]  Status: Failed, Error Type: RESP TIMEOUT
    Do you see adc_data*.bin file getting generated at 'PostProc' directory with this experiment?
    And could you check the RunTime\trace.txt file for SPI log if ar1.StartFrame() is getting response message from the Device?
    Paste last few lines from trace.txt file here to review the status.
    Jitendra
    I see a file called adc_data_Raw_0.bin.
    [15:16:41:086]: Sensor Start Device map = 1
    [15:16:41:087]: Device [0] [WR]0x1234 0x4321 0x0281 0x0016 0x5000 0x0000 0x0001 0xAD67 0x0140 0x0008 0x0001 0x0000 0xB4D5
    [15:16:42:094]: Device [0] [WR]0x1234 0x4321 0x0281 0x0016 0x5003 0x0000 0x0001 0xAD64 0x0140 0x0008 0x0001 0x0000 0xED57
    [15:16:43:099]: Device [0] [WR]0x1234 0x4321 0x0281 0x0016 0x5003 0x0000 0x0001 0xAD64 0x0140 0x0008 0x0001 0x0000 0xED57
    [15:16:44:109]: Device [0] [WR]0x1234 0x4321 0x0281 0x0016 0x5003 0x0000 0x0001 0xAD64 0x0140 0x0008 0x0001 0x0000 0xED57
    This all I see.
  • Or I mean it's what I see for the last few lines.
    Based on this log, device is not responding to frame start command.
    Could you provide answers to these questions?
    1. Is it AWR1642BOOST EVM Board or custom board?
    2. Do you always see this error or earlier it was working with another version of studio?
    3. If you clear adc_data*.bin and try this same experiment again then do you see this file generated with some data in it?
    Jitendra
    1. It is the AWR1642BOOST board.
    2. It was working with another version of mmWave studio and it was also working with this version before.
    3. I have been running it without the adc_data*.bin file each time and it never generated a new file.
  • I ran it again and it didn't give me an error but it also didn't produce an adc_data.bin file.
    GM: Constructor
    GM: Thu Oct 31 13:40:37 2019
    [13:40:39]
    [13:40:39]  ### Running Startup script: "C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Scripts\Startup.lua" ###
    [13:40:39]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
    [13:40:39]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
    [13:40:39]  Scripter ignored: Attempt to UnBuild() again or before Build.
    [13:40:39]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
    [13:40:39]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
    [13:40:39]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
    [13:40:39]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
    [13:40:39]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
    [13:40:39]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
    [13:40:39]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
    [13:40:39]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
    [13:40:39]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
    [13:40:39]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
    [13:40:39]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
    [13:40:39]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
    [13:40:39]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
    [13:40:39]  RSTD.Transmit("/")
    [13:40:39]  RSTD.SaveSettings(): Settings saved to "C:\Users\weilu\AppData\Roaming\RSTD\config.xml"
    [13:40:40]  RSTD.Build()
    [13:40:40]  RSTD.SaveSettings(): Settings saved to "C:\Users\weilu\AppData\Roaming\RSTD\config.xml"
    [13:40:40]  RSTD.Transmit("/")
    [13:40:40]  RSTD.AL_Build()
    [13:40:40]  RSTD.AL_LoadXml()
    [13:40:40]  RSTD.AL_Init()
    [13:40:40]  RSTD.Clients_Build()
    [13:40:40]  GM: Init
    [13:40:40]  GM: Loaded 'C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Clients\\LabClient.dll'
    [13:40:40]  GM: 1 Guest (s) init
    [13:40:40]  GM: 1 Module(s) init
    [13:40:40]  GM: 2 Tab   (s) init
    [13:40:40]  RSTD.Client_LoadXml()
    [13:40:41]  [RadarAPI]: ar1.selectRadarMode(0)
    [13:40:41]  [RadarAPI]: Status: Passed
    [13:40:41]  Matlab Runtime Engine is installed
    [13:40:41]  [RadarAPI]: Starting Matlab Engine..
    [13:41:29]  [RadarAPI]: Matlab Engine Started!
    [13:41:33]  [RadarAPI]: ar1.selectCascadeMode(0)
    [13:41:33]  [RadarAPI]: Status: Passed
    [13:41:33]  [RadarAPI]: ar1.LoadSettings('C:\Users\weilu\AppData\Roaming\RSTD\ar1gui.ini')
    [13:41:34]  TESTING = false
    [13:41:34]  RstdNet: Port 2777: Listening..
    [13:41:34]
    [13:41:34]  ***Script completed successfully.***
    [13:43:34]  [RadarAPI]: Opening Gpio Control Port()
    [13:43:34]  [RadarAPI]: Status: Passed
    [13:43:35]  [RadarAPI]: Opening Board Control Port()
    [13:43:35]  [RadarAPI]: Status: Passed
    [13:43:36]  [RadarAPI]: ar1.FullReset()
    [13:43:36]  [RadarAPI]: Status: Passed
    [13:43:36]  [RadarAPI]: Closing Board Control Port()
    [13:43:36]  [RadarAPI]: Closing Gpio Control Port()
    [13:43:36]  [RadarAPI]: ar1.SOPControl(2)
    [13:44:46]  [RadarAPI]: ar1.Connect(9,921600,1000)
    [13:44:48]  [RadarAPI]: Warning: Connected with baudrate 115200
    [13:44:49]  [RadarAPI]: Warning: Disconnected existing BaudRate
    [13:44:50]  [RadarAPI]: Warning: Trying to connect with baudrate 921600
    [13:44:51]  [RadarAPI]: ar1.Calling_IsConnected()
    [13:44:52]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
    [13:44:52]  [RadarAPI]: Status: Passed
    [13:44:52]  [RadarAPI]: ar1.deviceVariantSelection("XWR1642")
    [13:44:52]  [RadarAPI]: ar1.frequencyBandSelection("77G")
    [13:44:52]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
    [13:44:52]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
    [13:44:53]  [RadarAPI]: ar1.SaveSettings('C:\Users\weilu\AppData\Roaming\RSTD\ar1gui.ini')
    [13:46:18]  [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
    [13:46:19]  [RadarAPI]: Downloading BSS Patch RPRC Binary..
    [13:46:20]  [RadarAPI]: ar1.GetBSSFwVersion()
    [13:46:20]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
    [13:46:21]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
    [13:46:21]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
    [13:47:28]  [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
    [13:47:28]  [RadarAPI]: Downloading MSS RPRC Binary..
    [13:47:30]  [RadarAPI]: ar1.GetMSSFwVersion()
    [13:47:30]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
    [13:47:33]  [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
    [13:47:33]  [RadarAPI]: Status: Passed
    [13:47:33]  MSS power up done async event received!
    [13:47:34]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
    [13:47:34]  [RadarAPI]: Status: Passed
    [13:47:34]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
    [13:47:34]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
    [13:47:35]  [RadarAPI]: ar1.RfEnable()
    [13:47:35]  [RadarAPI]: Status: Passed
    [13:47:35]  BSS power up done async event received!
    [13:47:35]  [RadarAPI]: ar1.GetMSSFwVersion()
    [13:47:35]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
    [13:47:36]  [RadarAPI]: ar1.GetBSSFwVersion()
    [13:47:36]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
    [13:47:36]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
    [13:47:36]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
    [13:47:40]  [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0)
    [13:47:40]  [RadarAPI]: Status: Passed
    [13:47:43]  [RadarAPI]: ar1.LPModConfig(0, 1)
    [13:47:43]  [RadarAPI]: Status: Passed
    [13:47:47]  [RadarAPI]: ar1.RfInit()
    [13:47:47]  [RadarAPI]: Status: Passed
    [13:47:47]  RF Init async event received!
    [13:47:47]  [RadarAPI]: Time stamp, Temperture: 12413,31; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 1, 1;
    [13:47:49]  [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
    [13:47:49]  [RadarAPI]: Status: Passed
    [13:47:50]  [RadarAPI]: ar1.LvdsClkConfig(1, 1)
    [13:47:50]  [RadarAPI]: Status: Passed
    [13:47:51]  [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
    [13:47:51]  [RadarAPI]: Status: Passed
    [13:47:59]  [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 6250, 0, 0, 30)
    [13:47:59]  [RadarAPI]: Status: Passed
    [13:48:01]  [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
    [13:48:01]  [RadarAPI]: Status: Passed
    [13:48:01]  Test Source Already Disabled...!!!
    [13:48:01]  [RadarAPI]: ar1.DisableTestSource(0)
    [13:48:01]  [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
    [13:48:03]  [RadarAPI]: ar1.GetCaptureCardDllVersion()
    [13:48:03]  [RadarAPI]: Sending dll_version command to DCA1000
    [13:48:03]  DLL Version : 1.0
    [13:48:03]  [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
    [13:48:03]  [RadarAPI]: Status: Passed
    [13:48:04]  [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
    [13:48:04]  [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
    [13:48:04]  [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
    [13:48:04]  [RadarAPI]: Sending fpga command to DCA1000
    [13:48:05]  [RadarAPI]:
    [13:48:05]  FPGA Configuration command : Success
    [13:48:05]  [RadarAPI]: Sending record command to DCA1000
    [13:48:05]  Configure Record command : Success
    [13:48:05]  [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
    [13:48:05]  [RadarAPI]: Sending fpga_version command to DCA1000
    [13:48:05]
    [13:48:05]  FPGA Version : 2.7 [Record]
    [13:48:05]
    [13:48:06]  [RadarAPI]: ar1.CaptureCardConfig_StartRecord("C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
    [13:48:06]  [RadarAPI]: Sending start_record command to DCA1000
    [13:48:07]  [RadarAPI]: ar1.StartFrame()
    [13:48:07]  [RadarAPI]: Status: Passed
    [13:48:07]  Frame start async event received!
    [13:48:08]  [RadarAPI]: Frame Ended
    [13:49:27]  [RadarAPI]:
    [13:49:27]  Frame End async event received!
    [13:49:27]  Start Record command : Success
    [13:49:27]
    [13:49:27]  Record Process :
    [13:49:27]  Timeout Error! System disconnected
    [13:49:27]
    [13:49:27]  Record stop is done successfully
  • And also the last few lines from the trace file is this:
    [13:48:07:782]: Device [0] Host IRQ Low
    [13:48:07:786]: Device [0] [RD]0xDCBA 0xABCD
    [13:48:07:786]: Device [0] [RD]0x2032 0x0012 0x000C 0x0000 0x0001 0xDFAE
    [13:48:07:787]: Device [0] [RD]0x100B 0x0004
    [13:48:07:787]: Device [0] [RD]0x11DB
    [13:48:08:084]: Device [0] Host IRQ High
    [13:48:08:086]: Device [0] [WR]0x5678 0x8765 0xFFFF 0xFFFF 0xFFFF 0xFFFF 0xFFFF 0xFFFF
    [13:48:08:090]: Device [0] Host IRQ Low
    [13:48:08:094]: Device [0] [RD]0xDCBA 0xABCD
    [13:48:08:096]: Device [0] [RD]0x2032 0x0012 0x000C 0x0000 0x0001 0xDFAE
    [13:48:08:097]: Device [0] [RD]0x100F 0x0004
    [13:48:08:097]: Device [0] [RD]0xDB2A
  • Hi Jitendra,
    Do you have any suggestions for resolving this issue?
    It looks like the DCA1000 is getting reset. Could you verify the 5V supply to the DCA1000? What is the current capacity of the power supply you are using? Could you try a different power supply for the DCA1000?
    Vivek
    I was running the DCA1000 with a 3A or a 5A power supply depending on which lab I was in. I have tried multiple power supplies but the results are still the same.
    After the 'DCA100ARM' command (ar1.CaptureCardConfig_StartRecord("C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)) , can you add 2sec  delay before the Frame start command is called?
    In the lua script you can add a delay using  RSTD.Sleep(2000) command.
    Vivek
    Did this resolve the issue?
    vivek
  • Hello, I didn't get to try that because now I am getting a different error where it says the ethernet is disconnected
    GM: Constructor
    GM: Mon Nov 25 14:13:40 2019
    [14:13:40]
    [14:13:40]  ### Running Startup script: "C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Scripts\Startup.lua" ###
    [14:13:40]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
    [14:13:40]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
    [14:13:40]  Scripter ignored: Attempt to UnBuild() again or before Build.
    [14:13:40]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\Clients\\\\LabClient.dll")
    [14:13:40]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
    [14:13:40]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
    [14:13:41]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
    [14:13:41]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
    [14:13:41]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
    [14:13:41]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\RunTime\\SAL.dll")
    [14:13:41]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
    [14:13:41]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
    [14:13:41]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
    [14:13:41]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
    [14:13:41]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
    [14:13:41]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
    [14:13:41]  RSTD.Transmit("/")
    [14:13:41]  RSTD.SaveSettings(): Settings saved to "C:\Users\weilu\AppData\Roaming\RSTD\config.xml"
    [14:13:41]  RSTD.Build()
    [14:13:41]  RSTD.AL_Build()
    [14:13:41]  RSTD.AL_LoadXml()
    [14:13:41]  RSTD.AL_Init()
    [14:13:41]  RSTD.Clients_Build()
    [14:13:41]  GM: Init
    [14:13:41]  GM: Loaded 'C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Clients\\LabClient.dll'
    [14:13:41]  GM: 1 Guest (s) init
    [14:13:41]  GM: 1 Module(s) init
    [14:13:41]  GM: 2 Tab   (s) init
    [14:13:41]  RSTD.Client_LoadXml()
    [14:13:41]  [RadarAPI]: Starting Matlab Engine..
    [14:13:44]  [RadarAPI]: Matlab Engine Started!
    [14:13:46]  [RadarAPI]: ar1.LoadSettings('C:\Users\weilu\AppData\Roaming\RSTD\ar1gui.ini')
    [14:13:46]  TESTING = false
    [14:13:46]
    [14:13:46]  ***Script completed successfully.***
    [14:13:52]  [RadarAPI]: Opening Gpio Control Port()
    [14:13:52]  [RadarAPI]: Status: Passed
    [14:13:53]  [RadarAPI]: Opening Board Control Port()
    [14:13:53]  [RadarAPI]: Status: Passed
    [14:13:54]  [RadarAPI]: ar1.FullReset()
    [14:13:54]  [RadarAPI]: Status: Passed
    [14:13:55]  [RadarAPI]: Closing Board Control Port()
    [14:13:55]  [RadarAPI]: Status: Passed
    [14:13:55]  [RadarAPI]: Closing Gpio Control Port()
    [14:13:55]  [RadarAPI]: ar1.SOPControl(2)
    [14:13:57]  [RadarAPI]: ar1.Connect(9,921600,1000)
    [14:13:59]  [RadarAPI]: Warning: Connected with baudrate 115200
    [14:14:00]  [RadarAPI]: Warning: Disconnected existing BaudRate
    [14:14:00]  [RadarAPI]: Warning: Trying to connect with baudrate 921600
    [14:14:02]  [RadarAPI]: ar1.Calling_IsConnected()
    [14:14:03]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
    [14:14:03]  [RadarAPI]: Status: Passed
    [14:14:03]  [RadarAPI]: RS232 is not connected ..!!!!
    [14:14:03]  [RadarAPI]: ar1.frequencyBandSelection("77G")
    [14:14:03]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
    [14:14:03]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
    [14:14:04]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
    [14:14:04]  [RadarAPI]: Status: Passed
    [14:14:04]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
    [14:14:04]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
    [14:14:04]  [RadarAPI]: ar1.SaveSettings('C:\Users\weilu\AppData\Roaming\RSTD\ar1gui.ini')
    [14:14:08]  [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_00_00_02\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
    [14:14:08]  [RadarAPI]: Downloading BSS Patch RPRC Binary..
    [14:14:10]  [RadarAPI]: ar1.GetBSSFwVersion()
    [14:14:10]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
    [14:14:10]  [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_00_00_02\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
    [14:14:11]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
    [14:14:11]  [RadarAPI]: BSSPatchFwVersion:(00.00.00.00 (00/00/00))
    [14:14:11]  [RadarAPI]: Downloading MSS RPRC Binary..
    [14:14:14]  [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
    [14:14:14]  [RadarAPI]: Status: Passed
    [14:14:14]  MSS power up done async event received!
    [14:14:14]  [RadarAPI]: ar1.RfEnable()
    [14:14:15]  BSS power up done async event received!
    [14:14:15]  [RadarAPI]: Status: Passed
    [14:14:15]  [RadarAPI]: ar1.GetBSSFwVersion()
    [14:14:15]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
    [14:14:16]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
    [14:14:16]  [RadarAPI]: BSSPatchFwVersion:(01.02.00.03 (24/10/18))
    [14:14:16]  [RadarAPI]: Warning: BSS patch firmware version Mismatch!
    [14:14:17]  [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 2, 0)
    [14:14:17]  [RadarAPI]: Status: Passed
    [14:14:18]  [RadarAPI]: ar1.LPModConfig(0, 1)
    [14:14:18]  [RadarAPI]: Status: Passed
    [14:14:19]  [RadarAPI]: ar1.RfInit()
    [14:14:19]  RF Init async event received!
    [14:14:19]  [RadarAPI]: Status: Passed
    [14:14:19]  [RadarAPI]: Time stamp, Temperture: 4329,31; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 1, 1;
    [14:14:24]  [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
    [14:14:24]  [RadarAPI]: Status: Passed
    [14:14:25]  [RadarAPI]: ar1.LvdsClkConfig(1, 1)
    [14:14:25]  [RadarAPI]: Status: Passed
    [14:14:25]  [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
    [14:14:31]  [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 6250, 0, 0, 30)
    [14:14:31]  [RadarAPI]: Status: Passed
    [14:14:32]  [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
    [14:14:32]  [RadarAPI]: Status: Passed
    [14:14:33]  Test Source Already Disabled...!!!
    [14:14:33]  [RadarAPI]: Status: Passed
    [14:14:33]  [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 1)
    [14:14:34]  [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
    [14:14:34]  [RadarAPI]: passed
    [14:14:35]  [RadarAPI]: StatusDCCard Event Registered
    [14:14:35]  [RadarAPI]: Status: Passed
    [14:14:35]  [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
    [14:14:37]  ConnectRFDCCard Status: RRFDCCARD_SUCCESS
    [14:14:37]  Ethernet Cable is disconnected Please check.....!!!
  • Hello ,
    Did you change anything in the setup from your previous attempts and this one? Previously I see that the DCA1000 connection was all going through successfully. Is the supply used for DCA1000 correct now? Is the power switch control on the DCA1000 set to the correct position?
    regards,
    vivek
    Any update on this issue? Are you still facing the same issue?
    Vivek
