Other Parts Discussed in Thread: AWR1843BOOST, , IWR6843, AWR1843
Can you let me know if it is possible to synchronise the timing of the chirps on the IWR6843ISK boards or AWR1843BOOST boards.
I was thinking that this might be possible using the SYNC_OUT pin (AR_SYNC_OUT_SOP) from one board connected to the SYNC_IN pin (AR_SYNC_IN) on another board as described in http://www.ti.com/lit/an/swra574a/swra574a.pdf
I know that the IWR6843 and AWR1843 do not support cascade operation but I know that they have SYNC_OUT/SYNC_IN pins and was wanting to know if these can be used for timing synchronisation between boards/chips?
Well I look forward to hearing from you.
Best regards
Jonathan
