Other Parts Discussed in Thread: IWR1443BOOST, IWR1443
I use a DCA1000+IWR1443BOOST to collect adc_data.
In the SensorConfig interface, the DCA1000 Ethernet interface cannot be connected.
I set the correct IP address and also turned off the firewall.
[19:02:39]
[19:02:39] ### Running Startup script: "I:\TI_software\mmwave_studio_01_00_00_00\mmWaveStudio\Scripts\Startup.lua" ###
[19:02:39] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[19:02:39] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[19:02:39] Scripter ignored: Attempt to UnBuild() again or before Build.
[19:02:39] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "I:\\TI_software\\mmwave_studio_01_00_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[19:02:39] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[19:02:39] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[19:02:39] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[19:02:39] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[19:02:39] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[19:02:39] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "I:\\TI_software\\mmwave_studio_01_00_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
[19:02:39] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[19:02:39] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[19:02:39] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[19:02:39] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[19:02:39] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[19:02:39] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[19:02:39] RSTD.Transmit("/")
[19:02:39] RSTD.SaveSettings(): Settings saved to "C:\Users\PeterPan\AppData\Roaming\RSTD\config.xml"
[19:02:39] RSTD.Build()
[19:02:39] RSTD.AL_Build()
[19:02:39] RSTD.AL_LoadXml()
[19:02:39] RSTD.AL_Init()
[19:02:39] RSTD.Clients_Build()
[19:02:39] GM: Init
[19:02:39] GM: Loaded 'I:\TI_software\mmwave_studio_01_00_00_00\mmWaveStudio\Clients\\LabClient.dll'
[19:02:39] GM: 1 Guest (s) init
[19:02:39] GM: 1 Module(s) init
[19:02:39] GM: 2 Tab (s) init
[19:02:39] RSTD.Client_LoadXml()
[19:02:39] [RadarAPI]: Starting Matlab Engine..
[19:02:46] [RadarAPI]: Matlab Engine Started!
[19:02:51] [RadarAPI]: ar1.LoadSettings('C:\Users\PeterPan\AppData\Roaming\RSTD\ar1gui.ini')
[19:02:51] TESTING = false
[19:02:51]
[19:02:51] ***Script completed successfully.***
[19:02:54] [RadarAPI]: Opening Gpio Control Port()
[19:02:54] [RadarAPI]: Status: Passed
[19:02:55] [RadarAPI]: Opening Board Control Port()
[19:02:55] [RadarAPI]: Status: Passed
[19:02:56] [RadarAPI]: ar1.FullReset()
[19:02:56] [RadarAPI]: Status: Passed
[19:02:57] [RadarAPI]: Closing Board Control Port()
[19:02:57] [RadarAPI]: Status: Passed
[19:02:57] [RadarAPI]: Closing Gpio Control Port()
[19:02:57] [RadarAPI]: ar1.SOPControl(2)
[19:03:01] [RadarAPI]: ar1.Connect(9,115200,1000)
[19:03:02] [RadarAPI]: ar1.Calling_IsConnected()
[19:03:03] [RadarAPI]: ar1.SelectChipVersion("XWR1443")
[19:03:03] [RadarAPI]: Status: Passed
[19:03:04] [RadarAPI]: ar1.SelectChipVersion("XWR1443")
[19:03:04] [RadarAPI]: Status: Passed
[19:03:04] [RadarAPI]: ar1.SaveSettings('C:\Users\PeterPan\AppData\Roaming\RSTD\ar1gui.ini')
[19:03:05] [RadarAPI]: ar1.DownloadBSSFw("I:\\TI_software\\mmwave_studio_01_00_00_00\\rf_eval_firmware\\radarss\\xwr12xx_xwr14xx_radarss_ES2.0.bin")
[19:03:06] [RadarAPI]: Downloading BSS ROM Legacy Binary..
[19:03:46] [RadarAPI]: ar1.DownloadMSSFw("I:\\TI_software\\mmwave_studio_01_00_00_00\\rf_eval_firmware\\masterss\\xwr12xx_xwr14xx_masterss_ES2.0.bin")
[19:03:46] [RadarAPI]: Downloading MSS Legacy Binary..
[19:04:08] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[19:04:08] [RadarAPI]: Status: Passed
[19:04:08] MSS power up done async event received!
[19:04:08] [RadarAPI]: ar1.SaveSettings('C:\Users\PeterPan\AppData\Roaming\RSTD\ar1gui.ini')
[19:04:09] BSS power up done async event received!
[19:04:09] [RadarAPI]: ar1.RfEnable()
[19:04:09] [RadarAPI]: Status: Passed
[19:04:16] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 2, 0)
[19:04:16] [RadarAPI]: Status: Passed
[19:04:18] [RadarAPI]: ar1.LPModConfig(0, 0)
[19:04:18] [RadarAPI]: Status: Passed
[19:04:20] [RadarAPI]: ar1.RfInit()
[19:04:20] Status: Failed, Error Type: PROTOCOL ERROR
[19:04:24] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[19:04:27] Status: Failed, Error Type: RESP TIMEOUT
[19:04:29] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[19:04:32] Status: Failed, Error Type: RESP TIMEOUT
[19:04:36] [RadarAPI]: ar1.LVDSLaneConfig(1, 1, 1, 1, 1, 1, 0, 0)
[19:04:39] Status: Failed, Error Type: RESP TIMEOUT
[19:04:44] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 30)
[19:04:47] Status: Failed, Error Type: RESP TIMEOUT
[19:04:51] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[19:04:54] Status: Failed, Error Type: RESP TIMEOUT
[19:04:55] [RadarAPI]: ar1.DisableTestSource(0)
[19:04:58] Status: Failed, Error Type: RESP TIMEOUT
[19:04:58] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 1)
[19:05:01] Status: Failed, Error Type: RESP TIMEOUT
[19:05:01] [RadarAPI]: MatlabProc Status: Failed
[19:05:03] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[19:05:03] [RadarAPI]: passed
[19:05:04] [RadarAPI]: StatusDCCard Event Registered
[19:05:04] [RadarAPI]: Status: Passed
[19:05:04] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[19:05:06] ConnectRFDCCard Status: RRFDCCARD_SUCCESS
[19:05:06] Ethernet Cable is disconnected Please check.....!!!
[19:18:49] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[19:18:49] [RadarAPI]: passed
