Other Parts Discussed in Thread: TDA2
Hi Radar Team,
My customer ss having trouble saving the data to the SSD, and has tried both the GUI and the .lua script, see attached log of when he ran 'Cascade_Configuration_TestSource.lua' and 'Cascade_Capture.lua'
- It seems like all the correct LEDs are on
- There are four errors of 'MSS Boot Error status Async event recieved(0x1672C3)' found. Are they critical?
- He saw that the four green 'FRAIMING' in Framing Status section in the SensorConfig tap after he executed 'Cascade_Capture.lua'.
- Regarding TDA2, the directory was normally generated as it was set on /mnt/ssd/.
Barend
GM: Constructor GM: Mon Nov 25 15:01:28 2019 RSTD.Transmit("/Settings") [15:01:28] [15:01:28] ### Running Startup script: "C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Scripts\Startup.lua" ### [15:01:28] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1") [15:01:28] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss") [15:01:28] Scripter ignored: Attempt to UnBuild() again or before Build. [15:01:28] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll") [15:01:28] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE") [15:01:28] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE") [15:01:28] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE") [15:01:28] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE") [15:01:28] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE") [15:01:28] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\RunTime\\SAL.dll") [15:01:28] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "") [15:01:28] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE") [15:01:28] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1") [15:01:28] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE") [15:01:28] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE") [15:01:28] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false") [15:01:28] RSTD.Transmit("/") [15:01:28] RSTD.SaveSettings(): Settings saved to "C:\Users\chasu\AppData\Roaming\RSTD\config.xml" [15:01:28] RSTD.Build() [15:01:28] RSTD.SaveSettings(): Settings saved to "C:\Users\chasu\AppData\Roaming\RSTD\config.xml" [15:01:28] RSTD.Transmit("/") [15:01:28] RSTD.AL_Build() [15:01:28] RSTD.AL_LoadXml() [15:01:28] RSTD.Transmit("/") [15:01:28] RSTD.AL_Init() [15:01:28] RSTD.Clients_Build() [15:01:28] GM: Init [15:01:28] GM: Loaded 'C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Clients\\LabClient.dll' [15:01:28] GM: 1 Guest (s) init [15:01:28] GM: 1 Module(s) init [15:01:28] GM: 2 Tab (s) init [15:01:28] RSTD.Client_LoadXml() [15:01:28] [RadarAPI]: ar1.selectRadarMode(0) [15:01:28] [RadarAPI]: Status: Passed [15:01:28] Matlab Runtime Engine is installed [15:01:28] [RadarAPI]: Starting Matlab Engine.. [15:01:31] [RadarAPI]: Matlab Engine Started! [15:01:33] [RadarAPI]: ar1.selectCascadeMode(0) [15:01:33] [RadarAPI]: Status: Passed [15:01:33] [RadarAPI]: ar1.LoadSettings('C:\Users\chasu\AppData\Roaming\RSTD\ar1gui.ini') [15:01:33] TESTING = false [15:01:33] RstdNet: Port 2777: Listening.. [15:01:33] [15:01:33] ***Script completed successfully.*** [15:01:56] LuaLoad("C:/ti/mmwave_studio_02_01_00_00/mmWaveStudio/Scripts/Cascade/Cascade_Configuration_TestSource.lua") [15:01:58] Setting up Studio for Cascade started.. [15:01:58] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX") [15:01:58] [RadarAPI]: Status: Passed [15:01:58] [RadarAPI]: TDAStatusCallback Event Registered [15:01:58] [RadarAPI]: registerTDAStatusCallback Status: Passed [15:01:58] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15) [15:01:58] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:01:58] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:01:58] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45[15:01:58] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:01:59] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:01:59] [RadarAPI]: ConnectTDACaptureCard Status: Passed [15:01:59] TDA Capture Card Status : CONNECTED! [15:01:59] ConnectTDA Successful [15:01:59] [RadarAPI]: ar1.selectCascadeMode(1) [15:01:59] [RadarAPI]: Status: Passed [15:01:59] selectCascadeMode Successful [15:01:59] Setting up Studio for Cascade ended.. [15:01:59] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:00] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:00] [RadarAPI]: ar1.FullReset(1) [15:02:00] [RadarAPI]: Status: Passed [15:02:00] [RadarAPI]: ar1.SOPControl_mult(1,4) [15:02:00] [RadarAPI]: Status: Passed [15:02:00] Master : SOP Reset Successful [15:02:00] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0) [15:02:00] [RadarAPI]: Status: Passed [15:02:00] [DeviceId-0] MSS power up done async event received! [15:02:00] Master : SPI Connection Successful [15:02:00] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_01_02_05_01\\firmware\\xwr12xx_metaImage.bin) [15:02:03] [DeviceId-0] MSS Boot Error status Async event recieved(0x1672C3) [15:02:04] Master : FW Download Successful [15:02:04] [RadarAPI]: ar1.SelectChipVersion("AR1243") [15:02:04] [RadarAPI]: Status: Passed [15:02:04] [RadarAPI]: ar1.SelectChipVersion("AR1243") [15:02:04] [RadarAPI]: Status: Passed [15:02:04] [RadarAPI]: ar1.deviceVariantSelection("XWR1243") [15:02:04] [RadarAPI]: Status: Passed [15:02:04] [RadarAPI]: ar1.frequencyBandSelection("77G") [15:02:04] [RadarAPI]: ar1.SelectChipVersion("XWR1243") [15:02:04] [RadarAPI]: Status: Passed [15:02:04] Device Status : XWR1243/ASIL-B/SOP:4/ES:3 [15:02:04] [RadarAPI]: ar1.RfEnable_mult(1) [15:02:04] [RadarAPI]: Status: Passed [15:02:04] [DeviceId-0] BSS power up done async event received! [15:02:05] Master : RF Power Up Successful [15:02:05] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 1) [15:02:05] [RadarAPI]: Status: Passed [15:02:05] Master : Channel & ADC Configuration Successful [15:02:05] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:05] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:06] [RadarAPI]: ar1.FullReset(2) [15:02:06] [RadarAPI]: Status: Passed [15:02:06] [RadarAPI]: ar1.SOPControl_mult(2,4) [15:02:06] [RadarAPI]: Status: Passed [15:02:06] Device 2 : SOP Reset Successful [15:02:06] [RadarAPI]: ar1.AddDevice(2) [15:02:06] [DeviceId-1] MSS power up done async event received! [15:02:06] [RadarAPI]: Status: Passed [15:02:06] Device 2 : SPI Connection Successful [15:02:06] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:06] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:07] [RadarAPI]: ar1.FullReset(4) [15:02:07] [RadarAPI]: Status: Passed [15:02:07] [RadarAPI]: ar1.SOPControl_mult(4,4) [15:02:07] [RadarAPI]: Status: Passed [15:02:07] Device 3 : SOP Reset Successful [15:02:07] [RadarAPI]: ar1.AddDevice(4) [15:02:07] [DeviceId-2] MSS power up done async event received! [15:02:07] [RadarAPI]: Status: Passed [15:02:07] Device 3 : SPI Connection Successful [15:02:07] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:07] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:02:08] [RadarAPI]: ar1.FullReset(8) [15:02:08] [RadarAPI]: Status: Passed [15:02:08] [RadarAPI]: ar1.SOPControl_mult(8,4) [15:02:08] [RadarAPI]: Status: Passed [15:02:08] Device 4 : SOP Reset Successful [15:02:08] [RadarAPI]: ar1.AddDevice(8) [15:02:08] [DeviceId-3] MSS power up done async event received! [15:02:08] [RadarAPI]: Status: Passed [15:02:08] Device 4 : SPI Connection Successful [15:02:08] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(14, C:\\ti\\mmwave_dfp_01_02_05_01\\firmware\\xwr12xx_metaImage.bin) [15:02:11] [DeviceId-1] MSS Boot Error status Async event recieved(0x1672AD) [15:02:11] [DeviceId-2] MSS Boot Error status Async event recieved(0x1672AD) [15:02:11] [DeviceId-3] MSS Boot Error status Async event recieved(0x1672AD) [15:02:11] Slaves : FW Download Successful [15:02:12] [RadarAPI]: ar1.SelectChipVersion("AR1243") [15:02:12] [RadarAPI]: Status: Passed [15:02:12] [RadarAPI]: ar1.SelectChipVersion("XWR1243") [15:02:12] [RadarAPI]: Status: Passed [15:02:12] Slave1 Device Status : XWR1243/ASIL-B/SOP:4/ES:3 [15:02:12] [RadarAPI]: ar1.SelectChipVersion("AR1243") [15:02:12] [RadarAPI]: Status: Passed [15:02:12] [RadarAPI]: ar1.SelectChipVersion("XWR1243") [15:02:12] [RadarAPI]: Status: Passed [15:02:12] Slave2 Device Status : XWR1243/ASIL-B/SOP:4/ES:3 [15:02:12] [RadarAPI]: ar1.SelectChipVersion("AR1243") [15:02:12] [RadarAPI]: Status: Passed [15:02:12] [RadarAPI]: ar1.SelectChipVersion("XWR1243") [15:02:12] [RadarAPI]: Status: Passed [15:02:12] Slave3 Device Status : XWR1243/ASIL-B/SOP:4/ES:3 [15:02:12] [RadarAPI]: ar1.RfEnable_mult(14) [15:02:12] [RadarAPI]: Status: Passed [15:02:12] [DeviceId-2] BSS power up done async event received! [15:02:12] [DeviceId-3] BSS power up done async event received! [15:02:12] [DeviceId-1] BSS power up done async event received! [15:02:15] Slaves : RF Power Up Successful [15:02:15] [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 2) [15:02:15] [RadarAPI]: Status: Passed [15:02:15] Slaves : Channel & ADC Configuration Successful [15:02:15] [RadarAPI]: ar1.RfLdoBypassConfig_mult(15, 0xF) [15:02:15] [RadarAPI]: Status: Passed [15:02:15] LDO Bypass Successful [15:02:15] [RadarAPI]: ar1.LPModConfig_mult(15, 0,0) [15:02:15] [RadarAPI]: Status: Passed [15:02:15] Low Power Mode Configuration Successful [15:02:15] [RadarAPI]: ar1.SetMiscConfig_mult(15,1) [15:02:15] [RadarAPI]: Status: Passed [15:02:15] Misc Control Configuration Successful [15:02:15] [RadarAPI]: ar1.RfInitCalibConfig_mult(15, 1, 1, 1, 1, 1, 1, 1, 65537) [15:02:15] [RadarAPI]: Status: Passed [15:02:15] RF Init Calibration Successful [15:02:15] [RadarAPI]: ar1.RfInit_mult(15) [15:02:16] [DeviceId-1] RF Init async event received! [15:02:16] [DeviceId-2] RF Init async event received! [15:02:16] [DeviceId-0] RF Init async event received! [15:02:16] [DeviceId-3] RF Init async event received! [15:02:16] [RadarAPI]: Time stamp, Temperture: 3469,43; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1; [15:02:16] [RadarAPI]: Time stamp, Temperture: 3469,43; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1; [15:02:16] [RadarAPI]: Time stamp, Temperture: 3469,43; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1; [15:02:16] [RadarAPI]: Time stamp, Temperture: 3469,43; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1; [15:02:16] [RadarAPI]: Status: Passed [15:02:16] RF Init Successful [15:02:16] [RadarAPI]: ar1.DataPathConfig_mult(15, 0, 1, 0) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Data Path Configuration Successful [15:02:16] [RadarAPI]: ar1.LvdsClkConfig_mult(15, 1,1) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Clock Configuration Successful [15:02:16] [RadarAPI]: ar1.CSI2LaneConfig_mult(15, 1, 0, 2, 0, 4, 0, 5,0,3,0) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] CSI2 Configuration Successful [15:02:16] [RadarAPI]: ar1.SetTestSource_mult(1, 4, 3, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0,0) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Device 1 : Test Source Configuration Successful [15:02:16] [RadarAPI]: ar1.SetTestSource_mult(2, 3, 4, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0,0) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Device 2 : Test Source Configuration Successful [15:02:16] [RadarAPI]: ar1.SetTestSource_mult(4, 12, 5, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0,0) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Device 3 : Test Source Configuration Successful [15:02:16] [RadarAPI]: ar1.SetTestSource_mult(8, 5, 12, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0,0) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Device 4 : Test Source Configuration Successful [15:02:16] [RadarAPI]: ar1.ProfileConfig_mult(15, 0, 77, 5, 6, 40, 0, 0, 0, 0, 0, 0, 78.986, 0, 256, 8000, 0, 0, 48) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Profile Configuration successful [15:02:16] [RadarAPI]: ar1.ChirpConfig_mult(15, 0, 11, 0, 0, 0, 0, 0, 1, 1,0) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Chirp 0 Configuration successful [15:02:16] [RadarAPI]: ar1.EnableTestSource_mult(15,1) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Enabling Test Source Configuration successful [15:02:16] Test Source Already Enabled...!!! [15:02:16] [RadarAPI]: ar1.EnableTestSource_mult(1,1) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] [RadarAPI]: ar1.FrameConfig_mult(1, 0, 11, 10, 64, 100, 0, 0, 1) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] Master : Frame Configuration successful [15:02:16] Test Source Already Enabled...!!! [15:02:16] [RadarAPI]: ar1.EnableTestSource_mult(14,1) [15:02:16] [RadarAPI]: Status: Passed [15:02:16] [RadarAPI]: ar1.FrameConfig_mult(14, 0, 11, 10, 64, 100, 0, 0, 2) [15:02:17] [RadarAPI]: Status: Passed [15:02:17] Slaves : Frame Configuration successful [15:02:17] [15:02:17] ***Script completed successfully.*** [15:03:27] LuaLoad("C:/ti/mmwave_studio_02_01_00_00/mmWaveStudio/Scripts/Cascade/Cascade_Capture.lua") [15:03:28] Loops Remaining : 2 [15:03:28] Starting TDA ARM... [15:03:28] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, capture_data_1, 0) [15:03:28] Device 0 - Configuring TDA with Width : 2048 and Height : 768 [15:03:28] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed [15:03:28] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Device 1 - Configuring TDA with Width : 2048 and Height : 768 [15:03:28] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed [15:03:28] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Device 2 - Configuring TDA with Width : 2048 and Height : 768 [15:03:28] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed [15:03:28] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Device 3 - Configuring TDA with Width : 2048 and Height : 768 [15:03:28] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed [15:03:28] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Sending Frame Periodicity of 100 to TDA.. [15:03:28] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA [15:03:28] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Sending Capture Directory with name /mnt/ssd/capture_data_1 to TDA.. [15:03:28] [RadarAPI]: Status: Passed. Capture Directory sent to TDA [15:03:28] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Sending File Allocation of 0 files to TDA.. [15:03:28] [RadarAPI]: Status: Passed. File Allocation sent to TDA [15:03:28] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA.. [15:03:28] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA [15:03:28] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:28] Sending Number of frames to capture with value of 0 to TDA.. [15:03:28] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA [15:03:28] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:29] [RadarAPI]: Status: Passed for notifying TDA about Creating Application [15:03:29] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:29] [RadarAPI]: Status: Passed for notifying TDA about Start Frame [15:03:29] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:29] TDA ARM Successful [15:03:30] Starting Frame Trigger sequence... [15:03:30] [RadarAPI]: ar1.StartFrame_mult(8) [15:03:30] [RadarAPI]: Status: Passed [15:03:30] Device 4 : Start Frame Successful [15:03:30] [DeviceId-3] Frame start async event received! [15:03:30] [RadarAPI]: ar1.StartFrame_mult(4) [15:03:30] [RadarAPI]: Status: Passed [15:03:30] Device 3 : Start Frame Successful [15:03:30] [RadarAPI]: ar1.StartFrame_mult(2) [15:03:30] [DeviceId-2] Frame start async event received! [15:03:30] [RadarAPI]: Status: Passed [15:03:30] Device 2 : Start Frame Successful [15:03:30] [RadarAPI]: ar1.StartFrame_mult(1) [15:03:30] [DeviceId-1] Frame start async event received! [15:03:30] [RadarAPI]: Status: Passed [15:03:30] Device 1 : Start Frame Successful [15:03:30] Capturing AWR device data to the TDA SSD... [15:03:30] [DeviceId-0] Frame start async event received! [15:03:31] [RadarAPI]: Frame Ended [15:03:31] [DeviceId-0] Frame End async event received! [15:03:31] [DeviceId-2] Frame End async event received! [15:03:31] [DeviceId-3] Frame End async event received! [15:03:31] [DeviceId-1] Frame End async event received! [15:03:31] Status: Passed for notifying TDA about Stop Frame [15:03:31] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:33] Capture sequence completed... [15:03:35] Loops Remaining : 1 [15:03:35] Starting TDA ARM... [15:03:35] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, capture_data_1, 0) [15:03:35] Device 0 - Configuring TDA with Width : 2048 and Height : 768 [15:03:35] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed [15:03:35] Device 1 - Configuring TDA with Width : 2048 and Height : 768 [15:03:35] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed [15:03:35] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] Device 2 - Configuring TDA with Width : 2048 and Height : 768 [15:03:35] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed [15:03:35] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] Device 3 - Configuring TDA with Width : 2048 and Height : 768 [15:03:35] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed [15:03:35] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] Sending Frame Periodicity of 100 to TDA.. [15:03:35] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA [15:03:35] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] Sending Capture Directory with name /mnt/ssd/capture_data_1 to TDA.. [15:03:35] [RadarAPI]: Status: Passed. Capture Directory sent to TDA [15:03:35] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] Sending File Allocation of 0 files to TDA.. [15:03:35] [RadarAPI]: Status: Passed. File Allocation sent to TDA [15:03:35] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA.. [15:03:35] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA [15:03:35] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] Sending Number of frames to capture with value of 0 to TDA.. [15:03:35] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA [15:03:35] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:35] [RadarAPI]: Status: Passed for notifying TDA about Creating Application [15:03:35] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:36] [RadarAPI]: Status: Passed for notifying TDA about Start Frame [15:03:36] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:36] TDA ARM Successful [15:03:37] Starting Frame Trigger sequence... [15:03:37] [RadarAPI]: ar1.StartFrame_mult(8) [15:03:37] [RadarAPI]: Status: Passed [15:03:37] [DeviceId-3] Frame start async event received! [15:03:37] Device 4 : Start Frame Successful [15:03:37] [RadarAPI]: ar1.StartFrame_mult(4) [15:03:37] [RadarAPI]: Status: Passed [15:03:37] [DeviceId-2] Frame start async event received! [15:03:37] Device 3 : Start Frame Successful [15:03:37] [RadarAPI]: ar1.StartFrame_mult(2) [15:03:37] [RadarAPI]: Status: Passed [15:03:37] [DeviceId-1] Frame start async event received! [15:03:37] Device 2 : Start Frame Successful [15:03:37] [RadarAPI]: ar1.StartFrame_mult(1) [15:03:37] [RadarAPI]: Status: Passed [15:03:37] [DeviceId-0] Frame start async event received! [15:03:37] Device 1 : Start Frame Successful [15:03:37] Capturing AWR device data to the TDA SSD... [15:03:38] [RadarAPI]: Frame Ended [15:03:38] [DeviceId-0] Frame End async event received! [15:03:38] [DeviceId-1] Frame End async event received! [15:03:38] [DeviceId-3] Frame End async event received! [15:03:38] [DeviceId-2] Frame End async event received! [15:03:38] Status: Passed for notifying TDA about Stop Frame [15:03:38] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [15:03:40] Capture sequence completed... [15:03:42] [15:03:42] ***Script completed successfully.***
