Other Parts Discussed in Thread: IWR6843
I am running mmWaveStudio 2.1.0.0, but while on the "Connection" tab, I load BSS and MSS images bin files from the 2.0.0.2 mmwave studio firmware directory because for some reason, loading the newer bin files from the 2.1.0.0 directory gives errors soon after. Other than that, as you can see from the below log file, all goes well until I get to the sensor config file and click on "SetUp DCA1000" button and get the attached bad FPGA version:
If I continue on and click on "DCA1000 ARM", "Trigger Frame" and "PostProc", I get capture files indicating nothing is captured but with error lists that include "ethernet connection failed"
GM: Constructor
GM: Wed Dec 04 14:17:41 2019
RSTD.Transmit("/Settings")
[14:17:41]
[14:17:41] ### Running Startup script: "C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Scripts\Startup.lua" ###
[14:17:41] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[14:17:41] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[14:17:41] Scripter ignored: Attempt to UnBuild() again or before Build.
[14:17:41] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[14:17:41] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[14:17:41] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[14:17:41] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[14:17:41] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[14:17:41] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[14:17:41] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
[14:17:41] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[14:17:41] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[14:17:41] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[14:17:41] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[14:17:41] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[14:17:41] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[14:17:41] RSTD.Transmit("/")
[14:17:41] RSTD.SaveSettings(): Settings saved to "C:\Users\Acer\AppData\Roaming\RSTD\config.xml"
[14:17:41] RSTD.Build()
[14:17:41] RSTD.AL_Build()
[14:17:41] RSTD.AL_LoadXml()
[14:17:41] RSTD.AL_Init()
[14:17:41] RSTD.Clients_Build()
[14:17:41] GM: Init
[14:17:41] GM: Loaded 'C:\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Clients\\LabClient.dll'
[14:17:41] GM: 1 Guest (s) init
[14:17:41] GM: 1 Module(s) init
[14:17:41] GM: 2 Tab (s) init
[14:17:41] RSTD.Client_LoadXml()
[14:17:41] [RadarAPI]: ar1.selectRadarMode(0)
[14:17:41] [RadarAPI]: Status: Passed
[14:17:41] Matlab Runtime Engine is installed
[14:17:41] [RadarAPI]: Starting Matlab Engine..
[14:17:45] [RadarAPI]: Matlab Engine Started!
[14:17:47] [RadarAPI]: ar1.selectCascadeMode(0)
[14:17:47] [RadarAPI]: Status: Passed
[14:17:47] [RadarAPI]: ar1.LoadSettings('C:\Users\Acer\AppData\Roaming\RSTD\ar1gui.ini')
[14:17:47] TESTING = false
[14:17:47] RstdNet: Port 2777: Listening..
[14:17:47]
[14:17:47] ***Script completed successfully.***
[14:17:52] [RadarAPI]: Opening Gpio Control Port()
[14:17:52] [RadarAPI]: Status: Passed
[14:17:53] [RadarAPI]: Opening Board Control Port()
[14:17:53] [RadarAPI]: Status: Passed
[14:17:54] [RadarAPI]: ar1.FullReset()
[14:17:54] [RadarAPI]: Status: Passed
[14:17:54] [RadarAPI]: Closing Board Control Port()
[14:17:54] [RadarAPI]: Closing Gpio Control Port()
[14:17:54] [RadarAPI]: ar1.SOPControl(2)
[14:17:58] [RadarAPI]: ar1.Connect(82,921600,1000)
[14:18:00] [RadarAPI]: Warning: Connected with baudrate 115200
[14:18:01] [RadarAPI]: Warning: Disconnected existing BaudRate
[14:18:02] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[14:18:03] [RadarAPI]: ar1.Calling_IsConnected()
[14:18:05] [RadarAPI]: ar1.SelectChipVersion("IWR6843")
[14:18:05] [RadarAPI]: Status: Passed
[14:18:05] [RadarAPI]: ar1.frequencyBandSelection("60G")
[14:18:05] Device Status : IWR6843/QM/SOP:2/ES:1
[14:18:05] [RadarAPI]: ar1.SaveSettings('C:\Users\Acer\AppData\Roaming\RSTD\ar1gui.ini')
[14:18:10] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_00_00_02\\rf_eval_firmware\\radarss\\xwr68xx_radarss.bin")
[14:18:10] [RadarAPI]: Downloading BSS ROM RPRC Binary..
[14:18:16] [RadarAPI]: ar1.GetBSSFwVersion()
[14:18:16] [RadarAPI]: BSSFwVersion:(06.00.05.00 (01/08/18))
[14:18:19] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_00_00_02\\rf_eval_firmware\\masterss\\xwr68xx_masterss.bin")
[14:18:20] [RadarAPI]: Downloading MSS RPRC Binary..
[14:18:22] [RadarAPI]: ar1.GetMSSFwVersion()
[14:18:22] [RadarAPI]: MSSFwVersion:(01.02.00.00 (29/08/18))
[14:18:27] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[14:18:27] [RadarAPI]: Status: Passed
[14:18:27] MSS power up done async event received!
[14:18:55] [RadarAPI]: ar1.SelectChipVersion("IWR6843")
[14:18:55] [RadarAPI]: Status: Passed
[14:18:55] Device Status : IWR6843/QM/SOP:2/ES:1
[14:18:55] [RadarAPI]: ar1.RfEnable()
[14:18:55] BSS power up done async event received!
[14:18:56] [RadarAPI]: ar1.GetMSSFwVersion()
[14:18:56] [RadarAPI]: MSSFwVersion:(01.02.00.00 (29/08/18))
[14:18:56] [RadarAPI]: ar1.GetBSSFwVersion()
[14:18:56] [RadarAPI]: BSSFwVersion:(06.00.05.00 (01/08/18))
[14:19:04] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0)
[14:19:05] [RadarAPI]: Status: Passed
[14:19:06] [RadarAPI]: ar1.LPModConfig(0, 0)
[14:19:06] [RadarAPI]: Status: Passed
[14:19:08] [RadarAPI]: ar1.RfInit()
[14:19:08] [RadarAPI]: Status: Passed
[14:19:08] RF Init async event received!
[14:19:08] [RadarAPI]: Time stamp, Temperture: 12683,39; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 0, 0; HPFcutoff Status, Update: 0, 0; LPFcutoff Status, Update: 0, 0; PeakDetector Status, Update: 0, 0; TxPower Status, Update: 0, 0; RxGain Status, Update: 0, 0; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 0, 0;
[14:19:12] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[14:19:12] [RadarAPI]: Status: Passed
[14:19:14] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[14:19:15] [RadarAPI]: Status: Passed
[14:19:16] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[14:19:16] [RadarAPI]: Status: Passed
[14:19:27] [RadarAPI]: ar1.ProfileConfig(0, 60, 100, 6, 60, 0, 0, 0, 0, 0, 0, 11.008, 0, 256, 10000, 0, 131072, 30)
[14:19:27] [RadarAPI]: Status: Passed
[14:19:50] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[14:19:50] [RadarAPI]: Status: Passed
[14:19:51] Test Source Already Disabled...!!!
[14:19:51] [RadarAPI]: ar1.DisableTestSource(0)
[14:19:51] [RadarAPI]: Status: Passed
[14:19:51] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[14:19:54] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[14:19:54] [RadarAPI]: Sending dll_version command to DCA1000
[14:19:56] [RadarAPI]:
[14:19:56] DLL Version : 1.0
[14:19:56] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[14:19:56] [RadarAPI]: Status: Passed
[14:20:01] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[14:20:01] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[14:20:01] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[14:20:02] [RadarAPI]: Sending fpga command to DCA1000
[14:20:12] [RadarAPI]:
[14:20:12] FPGA Configuration :
[14:20:12] Timeout Error! System disconnected
[14:20:12] [RadarAPI]: Sending record command to DCA1000
[14:20:23] [RadarAPI]:
[14:20:23] Configure Record :
[14:20:23] Timeout Error! System disconnected
[14:20:23] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[14:20:23] [RadarAPI]: Sending fpga_version command to DCA1000
[14:20:34] [RadarAPI]:
[14:20:34]
[14:20:34] Unable to read FPGA Version. [error -5]
[14:20:34]
