CCS/IWR6843ISK: Sensors forum
Part Number: IWR6843ISK
I have two IWR6843-ISK ES1.0 EVM and I use mmwave sdk 3.3 with toolbox 4.0.1 to build an application based on ppl counting demo. I added a cli function which does soft reset by writing the value in the system reset register. I flashed the bin file to IWR6843-ISK ES2.0 and it worked with any issue. However, it hangs and not loading ES1.0 when device power up. I found out that pressing RST button could make it work.
I have tried to flash the prebuild binary in the toolbox 4.0.1, 3.6.2, 3.4 as well as rebuild it with SDK 3.3, 3.2.0.4, 3.1. The issue is still there no matter what version of binary I used. I also followed the link below to recompile SDK 3.2. No luck on that.
https://e2e.ti.com/support/sensors/f/1023/t/833472?-FAQ-IWR6843AOPEVM-MMWAVE-SDK-3-2-x-startup-sequence-needs-to-be-updated-for-IWR6843-ES1-0-and-IWR6843AOPEVM-ES1-0
Hank
