I set up the function like this:
rxRangeMsgObjectParams.msgIdType = CANFD_MCANXidType_29_BIT; rxRangeMsgObjectParams.startMsgIdentifier = 0x1D3; rxRangeMsgObjectParams.endMsgIdentifier = 0x1D5; rxMsgObjHandle3 = CANFD_createRxRangeMsgObject(canHandle, &rxRangeMsgObjectParams, &errCode);
I do not get any error mesages. When I send messages to the EVM in the range above the callback funtion is not called.
Normal rx objects works with no problems defined as below:
rxMsgObjectParams.direction = CANFD_Direction_RX; rxMsgObjectParams.msgIdType = CANFD_MCANXidType_29_BIT;//CANFD_MCANXidType_11_BIT;//CANFD_MCANXidType_29_BIT; rxMsgObjectParams.msgIdentifier = 0x1D1; rxMsgObjHandle = CANFD_createMsgObject(canHandle, &rxMsgObjectParams, &errCode);
One weird thing is that if I send an can message to the EVM that is not set up as an object, the callback function is still called but with an empty handle.
If I send a can message that is set up in the range the callback funtion is not called at all. It is like the functinality of the range function is inverted.
/* Standard Include Files. */ #include <stdint.h> #include <stdlib.h> #include <stddef.h> #include <string.h> #include <stdio.h> #include <math.h> /* BIOS/XDC Include Files. */ #include <xdc/std.h> #include <xdc/cfg/global.h> #include <xdc/runtime/IHeap.h> #include <xdc/runtime/System.h> #include <xdc/runtime/Error.h> #include <xdc/runtime/Memory.h> #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Task.h> #include <ti/sysbios/knl/Event.h> #include <ti/sysbios/knl/Semaphore.h> #include <ti/sysbios/knl/Clock.h> #include <ti/sysbios/heaps/HeapBuf.h> #include <ti/sysbios/heaps/HeapMem.h> #include <ti/sysbios/knl/Event.h> #include <ti/sysbios/family/arm/v7a/Pmu.h> #include <ti/sysbios/family/arm/v7r/vim/Hwi.h> #include <ti/sysbios/utils/Load.h> #include <ti/common/mmwave_error.h> /* mmWave SDK Include Files: */ #include <ti/common/sys_common.h> #include <ti/common/mmwave_sdk_version.h> #include <ti/drivers/soc/soc.h> #include <ti/drivers/esm/esm.h> #include <ti/drivers/pinmux/pinmux.h> #include <ti/drivers/crc/crc.h> #include <ti/drivers/gpio/gpio.h> #include <ti/drivers/mailbox/mailbox.h> #include <ti/control/mmwave/mmwave.h> #include <ti/control/dpm/dpm.h> #include <ti/datapath/dpc/objectdetection/objdethwa/objectdetection.h> #include <ti/drivers/osal/DebugP.h> #include <ti/drivers/uart/UART.h> #include <ti/utils/cli/cli.h> #include <ti/utils/mathutils/mathutils.h> #include <ti/utils/cycleprofiler/cycle_profiler.h> #include <ti/demo/utils/mmwdemo_rfparser.h> #include <ti/demo/xwr64xx/mmw/mmw_output.h> #include <ti/drivers/canfd/canfd.h> #include <ti/demo/xwr64xx/mmw/mmw.h> /************************************************************************** *************************** Global Definitions *************************** **************************************************************************/ volatile uint32_t gTxDoneFlag = 0, gRxDoneFlag = 0, gParityErrFlag = 0; volatile uint32_t gTxPkts = 0, gRxPkts = 0, gErrStatusInt = 0; volatile uint32_t iterationCount = 0U; uint32_t dataLength = 0U; uint32_t msgLstErrCnt = 0U; uint32_t gDisplayStats = 0; uint8_t rxData[64U]; uint32_t txDataLength, rxDataLength; CANFD_MCANFrameType frameType = CANFD_MCANFrameType_CLASSIC; static void MCANAppInitParams(CANFD_MCANInitParams* mcanCfgParams); CANFD_Handle canHandle; CANFD_MsgObjHandle txMsgObjHandle; CANFD_MCANMsgObjCfgParams txMsgObjectParams; extern MmwDemo_MCB gMmwMCB; /************************************************************************** *************************** CAN Driver Initialize Function *********************** **************************************************************************/ static void MCANAppErrStatusCallback(CANFD_Handle handle, CANFD_Reason reason, CANFD_ErrStatusResp* errStatusResp); static void MCANAppCallback(CANFD_MsgObjHandle handle, CANFD_Reason reason); //CANFD_MsgObjHandle rxMsgObjHandle,rxMsgObjHandle2; void Can_Initalize(void) { int32_t errCode = 0; int32_t retVal = 0; CANFD_MCANInitParams mcanCfgParams; CANFD_MCANBitTimingParams mcanBitTimingParams; CANFD_MCANMsgObjCfgParams rxMsgObjectParams; CANFD_MCANRxMsgObjRangeCfgParams rxRangeMsgObjectParams; CANFD_MsgObjHandle rxMsgObjHandle,rxMsgObjHandle2,rxMsgObjHandle3; gTxDoneFlag = 0; gRxDoneFlag = 0; /* Setup the PINMUX to bring out the XWR16xx CAN pins */ Pinmux_Set_OverrideCtrl(SOC_XWR68XX_PINE14_PADAE, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL); Pinmux_Set_FuncSel(SOC_XWR68XX_PINE14_PADAE, SOC_XWR68XX_PINE14_PADAE_CANFD_TX); Pinmux_Set_OverrideCtrl(SOC_XWR68XX_PIND13_PADAD, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL); Pinmux_Set_FuncSel(SOC_XWR68XX_PIND13_PADAD, SOC_XWR68XX_PIND13_PADAD_CANFD_RX); /* Configure the divide value for MCAN source clock */ SOC_setPeripheralClock(gMmwMCB.socHandle, SOC_MODULE_MCAN, SOC_CLKSOURCE_VCLK, 4U, &errCode); /* Initialize peripheral memory */ SOC_initPeripheralRam(gMmwMCB.socHandle, SOC_MODULE_MCAN, &errCode); MCANAppInitParams(&mcanCfgParams); /* Initialize the CANFD driver */ canHandle = CANFD_init(&mcanCfgParams, &errCode); if (canHandle == NULL) { System_printf( "Error: CANFD Module Initialization failed [Error code %d]\n", errCode); return; } /* Configuring 1Mbps and 5Mbps as nominal and data bit-rate respectively Prop seg: 8 Ph seg 1: 6 Ph Seg2 : 5 Sync jump: 1 BRP(Baud rate Prescaler): 2 Nominal Bit rate = (40)/(((8+6+5)+1)*BRP) = 1Mhz Timing Params for Data Bit rate: Prop seg: 2 Ph seg 1: 2 Ph Seg2 : 3 Sync jump: 1 BRP(Baud rate Prescaler): 1 Nominal Bit rate = (40)/(((2+2+3)+1)*BRP) = 5Mhz */ mcanBitTimingParams.nomBrp = 0x2U; mcanBitTimingParams.nomPropSeg = 0x8U; mcanBitTimingParams.nomPseg1 = 0x6U; mcanBitTimingParams.nomPseg2 = 0x5U; mcanBitTimingParams.nomSjw = 0x1U; mcanBitTimingParams.dataBrp = 0x1U; mcanBitTimingParams.dataPropSeg = 0x2U; mcanBitTimingParams.dataPseg1 = 0x2U; mcanBitTimingParams.dataPseg2 = 0x3U; mcanBitTimingParams.dataSjw = 0x1U; /* Configure the CAN driver */ retVal = CANFD_configBitTime(canHandle, &mcanBitTimingParams, &errCode); if (retVal < 0) { System_printf( "Error: CANFD Module configure bit time failed [Error code %d]\n", errCode); return; } /* Setup the transmit message object */ txMsgObjectParams.direction = CANFD_Direction_TX; txMsgObjectParams.msgIdType = CANFD_MCANXidType_29_BIT; txMsgObjectParams.msgIdentifier = 0xD1; txMsgObjHandle = CANFD_createMsgObject(canHandle, &txMsgObjectParams, &errCode); if (txMsgObjHandle == NULL) { System_printf( "Error: CANFD create Tx message object failed [Error code %d]\n", errCode); return; } /* Setup the receive message object */ rxMsgObjectParams.direction = CANFD_Direction_RX; rxMsgObjectParams.msgIdType = CANFD_MCANXidType_29_BIT;//CANFD_MCANXidType_11_BIT;//CANFD_MCANXidType_29_BIT; rxMsgObjectParams.msgIdentifier = 0x1D1; rxMsgObjHandle = CANFD_createMsgObject(canHandle, &rxMsgObjectParams, &errCode); if (rxMsgObjHandle == NULL) { System_printf( "Error: CANFD create Rx message object failed [Error code %d]\n", errCode); return; } rxMsgObjectParams.msgIdentifier = 0x1D2; rxMsgObjHandle2 = CANFD_createMsgObject(canHandle, &rxMsgObjectParams, &errCode); if (rxMsgObjHandle2 == NULL) { System_printf( "Error: CANFD create Rx message object failed [Error code %d]\n", errCode); return; } rxRangeMsgObjectParams.msgIdType = CANFD_MCANXidType_29_BIT; rxRangeMsgObjectParams.startMsgIdentifier = 0x1D3; rxRangeMsgObjectParams.endMsgIdentifier = 0x1D5; rxMsgObjHandle3 = CANFD_createRxRangeMsgObject(canHandle, &rxRangeMsgObjectParams, &errCode); if (rxMsgObjHandle3 == NULL) { System_printf( "Error: CANFD create range Rx message object failed [Error code %d]\n", errCode); return; } } /************************************************************************** ******************** CAN Parameters initialize Function ***************** **************************************************************************/ static void MCANAppInitParams(CANFD_MCANInitParams* mcanCfgParams) { /*Intialize MCAN Config Params*/ memset(mcanCfgParams, sizeof(CANFD_MCANInitParams), 0); mcanCfgParams->fdMode = 0x1U; mcanCfgParams->brsEnable = 0x1U; mcanCfgParams->txpEnable = 0x0U; mcanCfgParams->efbi = 0x0U; mcanCfgParams->pxhddisable = 0x0U; mcanCfgParams->darEnable = 0x1U; mcanCfgParams->wkupReqEnable = 0x1U; mcanCfgParams->autoWkupEnable = 0x1U; mcanCfgParams->emulationEnable = 0x0U; mcanCfgParams->emulationFAck = 0x0U; mcanCfgParams->clkStopFAck = 0x0U; mcanCfgParams->wdcPreload = 0x0U; mcanCfgParams->tdcEnable = 0x1U; mcanCfgParams->tdcConfig.tdcf = 0U; mcanCfgParams->tdcConfig.tdco = 8U; mcanCfgParams->monEnable = 0x0U; mcanCfgParams->asmEnable = 0x0U; mcanCfgParams->tsPrescalar = 0x0U; mcanCfgParams->tsSelect = 0x0U; mcanCfgParams->timeoutSelect = CANFD_MCANTimeOutSelect_CONT; mcanCfgParams->timeoutPreload = 0x0U; mcanCfgParams->timeoutCntEnable = 0x0U; mcanCfgParams->filterConfig.rrfe = 0x1U; mcanCfgParams->filterConfig.rrfs = 0x1U; mcanCfgParams->filterConfig.anfe = 0x1U; mcanCfgParams->filterConfig.anfs = 0x1U; mcanCfgParams->msgRAMConfig.lss = 127U; mcanCfgParams->msgRAMConfig.lse = 64U; mcanCfgParams->msgRAMConfig.txBufNum = 32U; mcanCfgParams->msgRAMConfig.txFIFOSize = 0U; mcanCfgParams->msgRAMConfig.txBufMode = 0U; mcanCfgParams->msgRAMConfig.txEventFIFOSize = 0U; mcanCfgParams->msgRAMConfig.txEventFIFOWaterMark = 0U; mcanCfgParams->msgRAMConfig.rxFIFO0size = 0U; mcanCfgParams->msgRAMConfig.rxFIFO0OpMode = 0U; mcanCfgParams->msgRAMConfig.rxFIFO0waterMark = 0U; mcanCfgParams->msgRAMConfig.rxFIFO1size = 64U; mcanCfgParams->msgRAMConfig.rxFIFO1waterMark = 64U; mcanCfgParams->msgRAMConfig.rxFIFO1OpMode = 64U; mcanCfgParams->eccConfig.enable = 1; mcanCfgParams->eccConfig.enableChk = 1; mcanCfgParams->eccConfig.enableRdModWr = 1; mcanCfgParams->errInterruptEnable = 1U; mcanCfgParams->dataInterruptEnable = 1U; mcanCfgParams->appErrCallBack = MCANAppErrStatusCallback; mcanCfgParams->appDataCallBack = MCANAppCallback; } static void MCANAppCallback(CANFD_MsgObjHandle handle, CANFD_Reason reason) { int32_t errCode, retVal; uint32_t id; CANFD_MCANFrameType rxFrameType; CANFD_MCANXidType rxIdType; if (reason == CANFD_Reason_TX_COMPLETION) { { gTxPkts++; gTxDoneFlag = 1; return; } } if (reason == CANFD_Reason_RX) { { /* Reset the receive buffer */ memset(&rxData, 0, sizeof(rxData)); dataLength = 0; retVal = CANFD_getData(handle, &id, &rxFrameType, &rxIdType, &rxDataLength, &rxData[0], &errCode); if (retVal < 0) { // System_printf ("Error: CAN receive data for iteration %d failed [Error code %d]\n", iterationCount, errCode); return; } if (rxFrameType != frameType) { // System_printf ("Error: CAN received incorrect frame type Sent %d Received %d for iteration %d failed\n", frameType, rxFrameType, iterationCount); return; } /* Validate the data */ gRxPkts++; gRxDoneFlag = 1; return; } } if (reason == CANFD_Reason_TX_CANCELED) { { gTxPkts++; gTxDoneFlag = 1; gRxDoneFlag = 1; return; } } } static void MCANAppErrStatusCallback(CANFD_Handle handle, CANFD_Reason reason, CANFD_ErrStatusResp* errStatusResp) { /*Record the error count */ gErrStatusInt++; return; } int32_t MCANApp_transmitDataBuffer(uint32_t msg_id, CANFD_MCANFrameType frameType, uint32_t dataLength, const uint8_t* txmsg) { int32_t errCode; static int32_t retVal; int32_t index = 0; uint32_t len = dataLength; if(frameType == CANFD_MCANFrameType_FD) { Task_sleep(1); while(len > 64U) { retVal = CANFD_transmitData (txMsgObjHandle, msg_id, CANFD_MCANFrameType_FD, 64U, &txmsg[index], &errCode); index = index + 64U; len = len - 64U; Task_sleep(1); } retVal = CANFD_transmitData (txMsgObjHandle, msg_id, CANFD_MCANFrameType_FD, len, &txmsg[index], &errCode); } else { while(len > 8U) { retVal = CANFD_transmitData (txMsgObjHandle, msg_id, CANFD_MCANFrameType_CLASSIC, 8U, &txmsg[index], &errCode); if (retVal < 0) { continue; } index = index + 8U; len = len - 8U; } retVal = CANFD_transmitData (txMsgObjHandle, msg_id, CANFD_MCANFrameType_CLASSIC, len, &txmsg[index], &errCode); /* while(retVal < 0) { retVal = CANFD_transmitData (txMsgObjHandle, msg_id, CANFD_MCANFrameType_CLASSIC, len, &txmsg[index], &errCode); }*/ } return 0; } void MCANApp_testTask(UArg arg0, UArg arg1) { /* int32_t retVal; DPM_Buffer resultBuffer; DPC_ObjectDetection_ExecuteResultExportedInfo exportInfo; DPC_ObjectDetection_ExecuteResult *result;*/ uint8_t txmsg[8] = {0,1,2,3,4,5,6,7}; while (1) { // MCANApp_transmitDataBuffer(1001, CANFD_MCANFrameType_CLASSIC, 8, txmsg); Task_sleep(1000); } }
