Other Parts Discussed in Thread: TDC1000
I am trying to use the TDC1000-TDC7200EVM in a flow level sensing application. I have read the snaa220b, and have read through the register portion of the data sheet for both the TDC1000 and the TDC7200. I set the configuration registers. The register setting which i tried I am attaching here.
After doing the changes in the register setting I poured the water into the Vessel but I was not able to see any change in the TDC value. Every time with and without water it was sowing the constand value (~40 μs) .
Is there another configuration that will work?
I have tried RegisterFiles-TDC1000_RegFile_WaterFlow_1MHz_Audiowell_20141218 & RegisterFiles-TDC1000_RegFile_WaterFlow_1MHz_Shenzen_20141218 & RegisterFiles-TDC1000_RegFile_WaterFlow_1MHz_MorganCeramics_20141218. Nothing is working.
Please any help would be appreciated!
Jyoti Sharma
TDC1000_Config0 41 TDC1000_Config1 41 TDC1000_Config2 00 TDC1000_Config3 0F TDC1000_Config4 5F TDC1000_TOF-1 40 TDC1000_TOF-0 1E TDC1000_Error_Flags 00 TDC1000_Timeout 5B TDC1000_Clock_Rate 01 TDC1000_Conts_Trigger 01 TRIGGER_UPDATE_FREQ 0004 TDC_AVG/STDEV_NUM_ELEMS 000A SAVE_GRAPH_DATA_TO_FILE 00 TDC_Y-SCALE_IN_ns 00 Y-SCALE_CENTER 0032 ZOOM_IN_X-SCALE 0032 MEASURE_RTD1 00 RTD_AVG/STDEV_NUM_ELEMS 000A TEMP_RTD_SELECT 00 TEMP_RTD_MODE 01 TEMP_AVG/STDEV_NUM_ELEMS 000A SAVE_TEMP_DATA 00 SAVE_YMAX_DATA 000000000000005B SAVE_YMIN_DATA FFFFFFFFFFFFFFF7 TDC1000-HV_DRV_EN1 00 TDC1000-HV_DRV_EN2 00 HV_DRV_EN1_Period 001E HV_DRV_EN2_Period 001E CLK_SOURCE_SELECT 00 CLK_FREQ_(1-16MHz) 8.000000
TDC1000_Config0 41 TDC1000_Config1 41 TDC1000_Config2 00 TDC1000_Config3 0D TDC1000_Config4 5F TDC1000_TOF-1 40 TDC1000_TOF-0 1E TDC1000_Error_Flags 00 TDC1000_Timeout 23 TDC1000_Clock_Rate 01 TDC1000_Conts_Trigger 01 TRIGGER_UPDATE_FREQ 0004 TDC_AVG/STDEV_NUM_ELEMS 000A SAVE_GRAPH_DATA_TO_FILE 00 TDC_Y-SCALE_IN_ns 00 Y-SCALE_CENTER 0032 ZOOM_IN_X-SCALE 0032 MEASURE_RTD1 00 RTD_AVG/STDEV_NUM_ELEMS 000A TEMP_RTD_SELECT 00 TEMP_RTD_MODE 01 TEMP_AVG/STDEV_NUM_ELEMS 000A SAVE_TEMP_DATA 00 SAVE_YMAX_DATA 0000000000000059 SAVE_YMIN_DATA FFFFFFFFFFFFFFF5 TDC1000-HV_DRV_EN1 00 TDC1000-HV_DRV_EN2 00 HV_DRV_EN1_Period 001E HV_DRV_EN2_Period 001E CLK_SOURCE_SELECT 00 CLK_FREQ_(1-16MHz) 8.000000
TDC1000_Config0 44 TDC1000_Config1 41 TDC1000_Config2 88 TDC1000_Config3 0C TDC1000_Config4 5F TDC1000_TOF-1 40 TDC1000_TOF-0 1E TDC1000_Error_Flags 00 TDC1000_Timeout 23 TDC1000_Clock_Rate 01 TDC1000_Conts_Trigger 01 TRIGGER_UPDATE_FREQ 0004 TDC_AVG/STDEV_NUM_ELEMS 000A SAVE_GRAPH_DATA_TO_FILE 01 TDC_Y-SCALE_IN_ns 00 Y-SCALE_CENTER 0032 ZOOM_IN_X-SCALE 0032 MEASURE_RTD1 00 RTD_AVG/STDEV_NUM_ELEMS 000A TEMP_RTD_SELECT 00 TEMP_RTD_MODE 01 TEMP_AVG/STDEV_NUM_ELEMS 000A SAVE_TEMP_DATA 00 SAVE_YMAX_DATA 0000000000000059 SAVE_YMIN_DATA FFFFFFFFFFFFFFF5 TDC1000-HV_DRV_EN1 00 TDC1000-HV_DRV_EN2 00 HV_DRV_EN1_Period 001E HV_DRV_EN2_Period 001E CLK_SOURCE_SELECT 00 CLK_FREQ_(1-16MHz) 8.000000
TDC1000_Config0 41 TDC1000_Config1 45 TDC1000_Config2 12 TDC1000_Config3 0C TDC1000_Config4 1F TDC1000_TOF-1 83 TDC1000_TOF-0 1F TDC1000_Error_Flags 00 TDC1000_Timeout 21 TDC1000_Clock_Rate 00 TDC1000_Conts_Trigger 01 TRIGGER_UPDATE_FREQ 0002 TDC_AVG/STDEV_NUM_ELEMS 0044 SAVE_GRAPH_DATA_TO_FILE 00 TDC_Y-SCALE_IN_ns 00 Y-SCALE_CENTER 00FF ZOOM_IN_X-SCALE 00FF MEASURE_RTD1 00 RTD_AVG/STDEV_NUM_ELEMS 00FF TEMP_RTD_SELECT 00 TEMP_RTD_MODE 00 TEMP_AVG/STDEV_NUM_ELEMS 0000 SAVE_TEMP_DATA 00 SAVE_YMAX_DATA 000000008CCCCCCC SAVE_YMIN_DATA 000000007FFFFFFF TDC1000-HV_DRV_EN1 00 TDC1000-HV_DRV_EN2 00 HV_DRV_EN1_Period 0032 HV_DRV_EN2_Period 0032 CLK_SOURCE_SELECT 00 CLK_FREQ_(1-16MHz) 8.000000
TDC1000_Config0 43 TDC1000_Config1 45 TDC1000_Config2 12 TDC1000_Config3 0C TDC1000_Config4 1F TDC1000_TOF-1 80 TDC1000_TOF-0 1F TDC1000_Error_Flags 00 TDC1000_Timeout 21 TDC1000_Clock_Rate 02 TDC1000_Conts_Trigger 00 TRIGGER_UPDATE_FREQ 0002 TDC_AVG/STDEV_NUM_ELEMS 0044 SAVE_GRAPH_DATA_TO_FILE 00 TDC_Y-SCALE_IN_ns 00 Y-SCALE_CENTER 00FF ZOOM_IN_X-SCALE 00FF MEASURE_RTD1 00 RTD_AVG/STDEV_NUM_ELEMS 00FF TEMP_RTD_SELECT 00 TEMP_RTD_MODE 00 TEMP_AVG/STDEV_NUM_ELEMS 0000 SAVE_TEMP_DATA 00 SAVE_YMAX_DATA 0000000000000000 SAVE_YMIN_DATA FFFFFFFFFFFFFFF7 TDC1000-HV_DRV_EN1 01 TDC1000-HV_DRV_EN2 01 HV_DRV_EN1_Period 0032 HV_DRV_EN2_Period 0032 CLK_SOURCE_SELECT 00 CLK_FREQ_(1-16MHz) 8.000000
TDC1000_Config0 44 TDC1000_Config1 41 TDC1000_Config2 00 TDC1000_Config3 0F TDC1000_Config4 5F TDC1000_TOF-1 40 TDC1000_TOF-0 1E TDC1000_Error_Flags 00 TDC1000_Timeout 43 TDC1000_Clock_Rate 01 TDC1000_Conts_Trigger 01 TRIGGER_UPDATE_FREQ 0004 TDC_AVG/STDEV_NUM_ELEMS 000A SAVE_GRAPH_DATA_TO_FILE 00 TDC_Y-SCALE_IN_ns 00 Y-SCALE_CENTER 0032 ZOOM_IN_X-SCALE 0032 MEASURE_RTD1 00 RTD_AVG/STDEV_NUM_ELEMS 000A TEMP_RTD_SELECT 00 TEMP_RTD_MODE 01 TEMP_AVG/STDEV_NUM_ELEMS 000A SAVE_TEMP_DATA 00 SAVE_YMAX_DATA 0000000000000059 SAVE_YMIN_DATA FFFFFFFFFFFFFFF5 TDC1000-HV_DRV_EN1 00 TDC1000-HV_DRV_EN2 00 HV_DRV_EN1_Period 001E HV_DRV_EN2_Period 001E CLK_SOURCE_SELECT 00 CLK_FREQ_(1-16MHz) 8.000000
