HDC2080: Humidity Only mode was deleted in latest datasheet change
Part Number: HDC2080
Hi Team,
Could you tell me the background why the Humidity only mode is deleted from MEAS_CONF[1:0]?
My customer utilizes the mode in their application.
Takashi Onawa
  • Dear Onawa-san,
    Thanks for posting. Nothing was changed in the IC, so the customer should not have any real issue. I will need to ask about the reason/background on why it was removed in the datasheet and get back to you in a day or so.
  • Hello Onawa-san,
    During Humidity conversion, the temperature conversion will happen for RH calculation. So it is logical we correct the data sheet to show the same. The customer can continue to use the setting without any issues and it will have the same result as Temp+Humidity setting for conversion. Hope that clarifies.
