TMP451: TMP451
Part Number: TMP451
The above mentioned temperature sensor have two sensor pins such as THERM(pin 4) and THERM2/ALERT (pin 6). Can i use one pin only and kept the other pin as just pulled up ?
or can i connect both the pins together and pull up by a single resistor?
  • Hi Jefin,
    You can use one, both, or neither of the pins depending on what you would like to do in your application. Tying both the pins together through one pull-up resistor would "wired OR" the outputs. Therefore, if one of the pins goes Low your output would be Low.
