IWR6843ISK-ODS: Indoor False Detection Mitigation Demo
Part Number: IWR6843ISK-ODS
For Indoor False Detection Mitigation Lab http://dev.ti.com/tirex/explore/node?node=AHjMTXHq1kwKavqe2k-2bQ__VLyFKFf__LATEST
Does it support ODS antenna layout ?
If not, what should be modified in the firmware to support that ?
Is there any limitation for ODS due to antenna pattern that ODS is not supported ?
  • Hi Casey,
    The ODS antenna is not supported. To support the ODS antenna, you will need to modify the DSS firmware to work with the ODS antenna pattern, instead of the ISK antenna pattern. This will be quite difficult, as you will need to understand how the Capon Beamforming function works. I believe you would be better off using the 3D People Counting demo.
    Justin
