Part Number: IWR6843ISK-ODS
Hello ,
Now I am facing an issue with mmWave Studio GUI. When 'Trigger frame' is precessed, error message (RESP TIMEOUT) appears, as shown in attached file.
Please kindly advise how to fix this issue.
Best regadrs,
Taka
Hello ,
Best regadrs,
Taka
Are you trying to follow the quick start procedure? http://www.ti.com/lit/pdf/spruik7 Have you been able to successfully capture data using this process?
Can you provide the full log of the output window instead of just the screenshot? It would also be helpful if you could post photos of your hardware and the board setup to check if there are any issues there.
Amanda
Hello Amanda,
Thank you for your advice. We have solved this issue.
Taka
