IWR6843ISK-ODS: What is EOP mode 2 dev mode
Part Number: IWR6843ISK-ODS
The lua script of continuous Tx script for  certification putting the device into EOP(2), what is that EOP 2 mode ?
The bootloader flow only describe  EOP=1,3,5 (functional mode, debug mode, flashing mode)
  • Hi Casey,
    Could you point out which line this appears or post a screenshot?
    Cheers,
    Akash
  • mmwave_industrial_toolbox_4_2_0./certification/RED supporting documents/Lua Scripts/IWR68xx_4GHz_Sweep_profile.lua
    if (0 == ar1.SOPControl(2)) then
    WriteToLog("SOP Reset Success\n", "green")
    else
    WriteToLog("SOP Reset Failure\n", "red")
    end
    RSTD.Sleep(1000)
    if (0 == ar1.PowerOn(1, 1000, 0, 0)) then
    WriteToLog("PowerOn Success\n", "green")
    else
    WriteToLog("PowerOn Failure\n", "red")
    session:destroy();
    end
    RSTD.Sleep(1000)
    else
    end
    else
    session:destroy();
    end
    RSTD.Sleep(1000)
  • mmwave_industrial_toolbox_4_2_0/./certification/RED supporting documents/Lua Scripts/IWR68xx_4GHz_Sweep_profile.lua
    else
    end
    else
    session:destroy();
    end
    This is the mode for the MMWAVESTUDIO. Development mode, I believe it is same as debug mode.
    SOP 0 =1, SOP 1= 1, SOP 2 = 0
    BR,
    Charles O
