Greetings,
I was trying to quantify the performance metrics of the cascade radar, so I was running the radar_object_detect use case on Processor SDK. I was choosing DSP or EVE for 2D FFT and I was recording the output FPS from performance statistics 'p'. What I found out was when I selected eve for 2D FFT for 128 doppler bins, the OS crashed and it gave me a different error message depending on the frame periodicity selected.
I'm changing the chirp parameters from the file "chains_common_cascade_ar12xx_config_mimo.c" I'm uploading my evaluation sheet. The error messages are color-coded to the corresponding range/doppler and the periodicity cell. TI RADAR performance chart(FPS).xlsx
Is anything above 64 on 2D FFT not supported by EVE? If it is, what changes need to be made in the source code to support it?
Thank you for your help.
