Other Parts Discussed in Thread: 4428
Hi Sir
I tried to import the AWR1243 IBIS model into Altium designer under SI sub menu but failed. Could you advice what could possible go wrong ?
Is there any TI document talk about this ?
thanks
BR
Jack Ho
Hi Chung,
I recommend that you discuss the use of IBIS models with Altium Designer with Altium support directly. Can you please explain exactly what "failed" when you tried to apply the model?
Thank you,
-Randy
Hi Sir
This is the error message I got in IbisErrors.txt when I tried import IBIS model. It does not look like the caused reason is from Altium side to me.
thanks
BR
Jack Ho
ERROR (line 6) - File name opened 'awr1243_csi_3v3_fcbga161.ibs' not the same as File_name 'awr12csi3v3_fcbga161.ibs'.
WARNING (line 19) - IBIS files should not contain tab characters.
ERROR (line 220) -
 Found illegal non-7-bit ASCII character (code a0). Converting to space.
NOTE (line 452) - Pulldown Maximum data is non-monotonic
NOTE (line 453) - Pulldown Typical data is non-monotonic
NOTE (line 456) - Pulldown Minimum data is non-monotonic
NOTE (line 1843) - Pulldown Maximum data is non-monotonic
NOTE (line 1844) - Pulldown Typical data is non-monotonic
NOTE (line 1847) - Pulldown Minimum data is non-monotonic
NOTE (line 3035) - Pulldown Maximum data is non-monotonic
NOTE (line 3036) - Pulldown Typical data is non-monotonic
NOTE (line 3039) - Pulldown Minimum data is non-monotonic
NOTE (line 4424) - Pulldown Maximum data is non-monotonic
NOTE (line 4425) - Pulldown Typical data is non-monotonic
NOTE (line 4428) - Pulldown Minimum data is non-monotonic
NOTE (line 5590) - Pulldown Maximum data is non-monotonic
NOTE (line 5591) - Pulldown Typical data is non-monotonic
NOTE (line 5594) - Pulldown Minimum data is non-monotonic
NOTE (line 6765) - Pulldown Maximum data is non-monotonic
NOTE (line 6766) - Pulldown Typical data is non-monotonic
NOTE (line 6769) - Pulldown Minimum data is non-monotonic
NOTE (line 8151) - Pulldown Maximum data is non-monotonic
NOTE (line 8152) - Pulldown Typical data is non-monotonic
NOTE (line 8155) - Pulldown Minimum data is non-monotonic
NOTE (line 9518) - Pulldown Maximum data is non-monotonic
NOTE (line 9519) - Pulldown Typical data is non-monotonic
NOTE (line 9522) - Pulldown Minimum data is non-monotonic
NOTE (line 10727) - Pulldown Maximum data is non-monotonic
NOTE (line 10728) - Pulldown Typical data is non-monotonic
NOTE (line 10731) - Pulldown Minimum data is non-monotonic
NOTE (line 12094) - Pulldown Maximum data is non-monotonic
NOTE (line 12095) - Pulldown Typical data is non-monotonic
NOTE (line 12098) - Pulldown Minimum data is non-monotonic
NOTE (line 13277) - Pulldown Maximum data is non-monotonic
NOTE (line 13278) - Pulldown Typical data is non-monotonic
NOTE (line 13281) - Pulldown Minimum data is non-monotonic
NOTE (line 14456) - Pulldown Maximum data is non-monotonic
NOTE (line 14457) - Pulldown Typical data is non-monotonic
NOTE (line 14460) - Pulldown Minimum data is non-monotonic
WARNING - Model Model_36: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_36: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_36: POWER Clamp : Maximum value never becomes zero
NOTE (line 18157) - Pulldown Maximum data is non-monotonic
NOTE (line 18158) - Pulldown Typical data is non-monotonic
NOTE (line 18161) - Pulldown Minimum data is non-monotonic
NOTE (line 18244) - Pullup Maximum data is non-monotonic
NOTE (line 18250) - Pullup Typical data is non-monotonic
NOTE (line 18257) - Pullup Minimum data is non-monotonic
NOTE (line 20901) - Pulldown Maximum data is non-monotonic
NOTE (line 20902) - Pulldown Typical data is non-monotonic
NOTE (line 20905) - Pulldown Minimum data is non-monotonic
NOTE (line 20988) - Pullup Maximum data is non-monotonic
NOTE (line 20994) - Pullup Typical data is non-monotonic
NOTE (line 21001) - Pullup Minimum data is non-monotonic
NOTE (line 23212) - Pulldown Maximum data is non-monotonic
NOTE (line 23213) - Pulldown Typical data is non-monotonic
NOTE (line 23216) - Pulldown Minimum data is non-monotonic
NOTE (line 23299) - Pullup Maximum data is non-monotonic
NOTE (line 23305) - Pullup Typical data is non-monotonic
NOTE (line 23312) - Pullup Minimum data is non-monotonic
NOTE (line 25952) - Pulldown Maximum data is non-monotonic
NOTE (line 25953) - Pulldown Typical data is non-monotonic
NOTE (line 25956) - Pulldown Minimum data is non-monotonic
NOTE (line 26039) - Pullup Maximum data is non-monotonic
NOTE (line 26045) - Pullup Typical data is non-monotonic
NOTE (line 26052) - Pullup Minimum data is non-monotonic
WARNING - Model Model_40: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_40: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_40: POWER Clamp : Maximum value never becomes zero
NOTE (line 28278) - Pulldown Maximum data is non-monotonic
NOTE (line 28279) - Pulldown Typical data is non-monotonic
NOTE (line 28282) - Pulldown Minimum data is non-monotonic
NOTE (line 28365) - Pullup Maximum data is non-monotonic
NOTE (line 28371) - Pullup Typical data is non-monotonic
NOTE (line 28378) - Pullup Minimum data is non-monotonic
NOTE (line 30609) - Pulldown Maximum data is non-monotonic
NOTE (line 30610) - Pulldown Typical data is non-monotonic
NOTE (line 30613) - Pulldown Minimum data is non-monotonic
NOTE (line 30696) - Pullup Maximum data is non-monotonic
NOTE (line 30702) - Pullup Typical data is non-monotonic
NOTE (line 30709) - Pullup Minimum data is non-monotonic
WARNING - Model Model_48: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_48: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_48: POWER Clamp : Maximum value never becomes zero
NOTE (line 33343) - Pulldown Maximum data is non-monotonic
NOTE (line 33344) - Pulldown Typical data is non-monotonic
NOTE (line 33347) - Pulldown Minimum data is non-monotonic
NOTE (line 33430) - Pullup Maximum data is non-monotonic
NOTE (line 33436) - Pullup Typical data is non-monotonic
NOTE (line 33443) - Pullup Minimum data is non-monotonic
NOTE (line 36062) - Pulldown Maximum data is non-monotonic
NOTE (line 36063) - Pulldown Typical data is non-monotonic
NOTE (line 36066) - Pulldown Minimum data is non-monotonic
NOTE (line 36149) - Pullup Maximum data is non-monotonic
NOTE (line 36155) - Pullup Typical data is non-monotonic
NOTE (line 36162) - Pullup Minimum data is non-monotonic
NOTE (line 38435) - Pulldown Maximum data is non-monotonic
NOTE (line 38436) - Pulldown Typical data is non-monotonic
NOTE (line 38439) - Pulldown Minimum data is non-monotonic
NOTE (line 38522) - Pullup Maximum data is non-monotonic
NOTE (line 38528) - Pullup Typical data is non-monotonic
NOTE (line 38535) - Pullup Minimum data is non-monotonic
NOTE (line 41140) - Pulldown Maximum data is non-monotonic
NOTE (line 41141) - Pulldown Typical data is non-monotonic
NOTE (line 41144) - Pulldown Minimum data is non-monotonic
NOTE (line 41227) - Pullup Maximum data is non-monotonic
NOTE (line 41233) - Pullup Typical data is non-monotonic
NOTE (line 41240) - Pullup Minimum data is non-monotonic
WARNING - Model Model_52: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_52: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_52: POWER Clamp : Maximum value never becomes zero
NOTE (line 43464) - Pulldown Maximum data is non-monotonic
NOTE (line 43465) - Pulldown Typical data is non-monotonic
NOTE (line 43468) - Pulldown Minimum data is non-monotonic
NOTE (line 43551) - Pullup Maximum data is non-monotonic
NOTE (line 43557) - Pullup Typical data is non-monotonic
NOTE (line 43564) - Pullup Minimum data is non-monotonic
NOTE (line 45815) - Pulldown Maximum data is non-monotonic
NOTE (line 45816) - Pulldown Typical data is non-monotonic
NOTE (line 45819) - Pulldown Minimum data is non-monotonic
NOTE (line 45902) - Pullup Maximum data is non-monotonic
NOTE (line 45908) - Pullup Typical data is non-monotonic
NOTE (line 45915) - Pullup Minimum data is non-monotonic
WARNING - Model Model_60: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_60: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_60: POWER Clamp : Maximum value never becomes zero
NOTE (line 48519) - Pulldown Maximum data is non-monotonic
NOTE (line 48520) - Pulldown Typical data is non-monotonic
NOTE (line 48523) - Pulldown Minimum data is non-monotonic
NOTE (line 48606) - Pullup Maximum data is non-monotonic
NOTE (line 48612) - Pullup Typical data is non-monotonic
NOTE (line 48619) - Pullup Minimum data is non-monotonic
NOTE (line 51253) - Pulldown Maximum data is non-monotonic
NOTE (line 51254) - Pulldown Typical data is non-monotonic
NOTE (line 51257) - Pulldown Minimum data is non-monotonic
NOTE (line 51340) - Pullup Maximum data is non-monotonic
NOTE (line 51346) - Pullup Typical data is non-monotonic
NOTE (line 51353) - Pullup Minimum data is non-monotonic
NOTE (line 53552) - Pulldown Maximum data is non-monotonic
NOTE (line 53553) - Pulldown Typical data is non-monotonic
NOTE (line 53556) - Pulldown Minimum data is non-monotonic
NOTE (line 53639) - Pullup Maximum data is non-monotonic
NOTE (line 53645) - Pullup Typical data is non-monotonic
NOTE (line 53652) - Pullup Minimum data is non-monotonic
NOTE (line 56261) - Pulldown Maximum data is non-monotonic
NOTE (line 56262) - Pulldown Typical data is non-monotonic
NOTE (line 56265) - Pulldown Minimum data is non-monotonic
NOTE (line 56348) - Pullup Maximum data is non-monotonic
NOTE (line 56354) - Pullup Typical data is non-monotonic
NOTE (line 56361) - Pullup Minimum data is non-monotonic
WARNING - Model Model_64: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_64: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_64: POWER Clamp : Maximum value never becomes zero
NOTE (line 58572) - Pulldown Maximum data is non-monotonic
NOTE (line 58573) - Pulldown Typical data is non-monotonic
NOTE (line 58576) - Pulldown Minimum data is non-monotonic
NOTE (line 58659) - Pullup Maximum data is non-monotonic
NOTE (line 58665) - Pullup Typical data is non-monotonic
NOTE (line 58672) - Pullup Minimum data is non-monotonic
NOTE (line 60857) - Pulldown Maximum data is non-monotonic
NOTE (line 60858) - Pulldown Typical data is non-monotonic
NOTE (line 60861) - Pulldown Minimum data is non-monotonic
NOTE (line 60944) - Pullup Maximum data is non-monotonic
NOTE (line 60950) - Pullup Typical data is non-monotonic
NOTE (line 60957) - Pullup Minimum data is non-monotonic
WARNING - Model Model_72: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_72: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_72: POWER Clamp : Maximum value never becomes zero
NOTE (line 63585) - Pulldown Maximum data is non-monotonic
NOTE (line 63586) - Pulldown Typical data is non-monotonic
NOTE (line 63589) - Pulldown Minimum data is non-monotonic
NOTE (line 63672) - Pullup Maximum data is non-monotonic
NOTE (line 63678) - Pullup Typical data is non-monotonic
NOTE (line 63685) - Pullup Minimum data is non-monotonic
NOTE (line 66290) - Pulldown Maximum data is non-monotonic
NOTE (line 66291) - Pulldown Typical data is non-monotonic
NOTE (line 66294) - Pulldown Minimum data is non-monotonic
NOTE (line 66377) - Pullup Maximum data is non-monotonic
NOTE (line 66383) - Pullup Typical data is non-monotonic
NOTE (line 66390) - Pullup Minimum data is non-monotonic
NOTE (line 68638) - Pulldown Maximum data is non-monotonic
NOTE (line 68639) - Pulldown Typical data is non-monotonic
NOTE (line 68642) - Pulldown Minimum data is non-monotonic
NOTE (line 68725) - Pullup Maximum data is non-monotonic
NOTE (line 68731) - Pullup Typical data is non-monotonic
NOTE (line 68738) - Pullup Minimum data is non-monotonic
NOTE (line 71344) - Pulldown Maximum data is non-monotonic
NOTE (line 71345) - Pulldown Typical data is non-monotonic
NOTE (line 71348) - Pulldown Minimum data is non-monotonic
NOTE (line 71431) - Pullup Maximum data is non-monotonic
NOTE (line 71437) - Pullup Typical data is non-monotonic
NOTE (line 71444) - Pullup Minimum data is non-monotonic
WARNING - Model Model_76: POWER Clamp : Typical value never becomes zero
WARNING - Model Model_76: POWER Clamp : Minimum value never becomes zero
WARNING - Model Model_76: POWER Clamp : Maximum value never becomes zero
NOTE (line 73667) - Pulldown Maximum data is non-monotonic
NOTE (line 73668) - Pulldown Typical data is non-monotonic
NOTE (line 73671) - Pulldown Minimum data is non-monotonic
NOTE (line 73754) - Pullup Maximum data is non-monotonic
NOTE (line 73760) - Pullup Typical data is non-monotonic
NOTE (line 73767) - Pullup Minimum data is non-monotonic
NOTE (line 75995) - Pulldown Maximum data is non-monotonic
NOTE (line 75996) - Pulldown Typical data is non-monotonic
NOTE (line 75999) - Pulldown Minimum data is non-monotonic
NOTE (line 76082) - Pullup Maximum data is non-monotonic
NOTE (line 76088) - Pullup Typical data is non-monotonic
NOTE (line 76095) - Pullup Minimum data is non-monotonic
WARNING - Model Model_78: The [Rising Waveform]
 with [R_fixture]=50 Ohms and [V_fixture]=0.199084V
 has TYP column DC endpoints of 0.10V and 0.31v, but
 an equivalent load applied to the model's I-V tables yields
 different voltages ( 0.10V and 0.30V),
 a difference of 0.06% and 3.11%, respectively.
WARNING - Combined Pulldown for Model: Model_77 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_77 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_77 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_76 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_76 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_75 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_75 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_75 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_74 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_74 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_74 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_73 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_73 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_73 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_72 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_72 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_65 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_65 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_65 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_64 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_64 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_63 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_63 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_63 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_62 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_62 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_62 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_61 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_61 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_61 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_60 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_60 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_53 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_53 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_53 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_52 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_52 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_51 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_51 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_51 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_50 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_50 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_50 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_49 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_49 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_49 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_48 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_48 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_41 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_41 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_41 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_40 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_40 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_39 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_39 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_39 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_38 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_38 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_38 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_37 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_37 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_37 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_36 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_36 Maximum data is non-monotonic
WARNING - Model Model_25: The [Rising Waveform]
WARNING - Combined Pulldown for Model: Model_24 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_24 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_24 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_23 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_23 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_23 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_22 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_22 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_22 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_21 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_21 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_21 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_20 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_20 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_20 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_19 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_19 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_19 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_12 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_12 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_12 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_11 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_11 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_11 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_10 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_10 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_10 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_9 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_9 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_9 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_8 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_8 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_8 Maximum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_7 Typical data is non-monotonic
WARNING - Combined Pulldown for Model: Model_7 Minimum data is non-monotonic
WARNING - Combined Pulldown for Model: Model_7 Maximum data is non-monotonic
WARNING - CMPT 'awr12csi3v3_fcbga161': Cpkg MIN value -0.0450383pF not within expected range (0pF, 1000pF)
Errors : 2
Warnings: 128
File Failed
Hi Jack,
Using IBIS check 4 it looks like the 2 errors were due to:
Can you please try the attached ibs file? The warnings will still pop up when you apply the model, but you can press escape once to ignore that window. awr1243_csi_3v3_fcbga161.ibs
Thank you,
-Randy
Hi Randy
It works for me. Thanks !
However, it takes like 5 hours to get things done. Is it correct ?
BR
Jack Ho
Hi Jack,
Glad it is functional for you now. I have not utilized these IBIS models within the Altium Designer environment yet or other IBIS modeling environments. But based on previous processor IBIS model simulations, some signal integrity simulations can take a while depending on the waveform and other variable iterations you run with. That might be another Altium support question. If you have any other questions on the IBIS model please open up a new e2e ticket.
Thank you,
-Randy
