CCS/AWR1843: Disable Cloud Point Info question
Part Number: AWR1843
Dear TI
               If we only disable cloud point information  to uart interface could down the buadrate ? and system performance could be improved ?
Best Regards
  • HI,
    Which demo are you referring to?
    What are you trying to achieve by disabling the point cloud information?
    Disabling the point cloud information does not have an impact on the performance of most demos because the demo processing chain usually runs on DSP or HWA and sending the point cloud information runs on the R4F ARM
    thank you
    Cesar
  • Dear TI
        Our customers and application level customers (> 2/3) don't need any point could information .
                They only request more accuracy location information ( x y z) and lower power consumption only .
                If we disable cloud point info output to uart with lab sample code . Which we can be improved ?
                1. 921K buad rate can lower to ?  How to calculation output data vs max buad rate setting ?
                2. Power consumption can improved ?
                3. Memory usage can be improved ? we want to gain more range resolution and frame rate .
    BR
