AWR1642BOOST-ODS: Obstacle detection change range
Part Number: AWR1642BOOST-ODS
Hallo,
I wanted to know how to change the maximum range for obstacle detection. Our example in obstacle detection Gui is limited to 3m, but I want to change the maximum range and tried the following:
I made a change to the cfg file and read the mmwave_sdk_user_guide under section 3.4 (C: \ ti \ mmwave_sdk_02_01_00_04 \ docs) and could not change this. and then searched with mmWaveSensingEstimator and unfortunately it didn't work.
Where can you change that in ods_default_config?
Could you please give me a tip on where I can change the maximum range?
Thanks in advance
Walid
    There are many threads in this forum related to changing the range. Once you understand how to compute the range you will be able to modify the parameters in the command line.
    Please use following google site search
    "site e2e.ti.com maximum range"
    Thank you
    Cesar
