My customer require an alternative solution for below 4 direction detectors. Can you please suggest if TI has a similar solution? thanks.
Hey Yue,
Honestly, from that datasheet I can't even tell what a 4 direction detector sensor is. What is the application?
JD
Hey Yue,
After some searching, I was able to find this page that explains what a 4 direction sensor does: https://www.parallax.com/product/28036 Basically, it just detects what side is "Up."
I don't think TI makes anything like this, but I'll try and loop the sensing groups in to confirm.
JD
Hello Yue,
Its a bot unclear on what is needed here. Based on the little information if the requirement is for a vacuum cleaner. I am not sure if you are talking about a robotic vacuum cleaner. If its yes then I recommend a technote on using ultrasonics http://www.ti.com/lit/an/slaa909/slaa909.pdf?ts=1587959566069 for object detection.
but on the previous research I would be more inclined towards an optical solution.
