Other Parts Discussed in Thread: BOOSTXL-TUSS4440, , TUSS4470
Hi Team,
A customer is requesting for the physical dimensions of BOOSTXL-TUSS4470 and BOOSTXL-TUSS4440.
Danilo
Hi Team,
Danilo
Can you please clarify with more information here ? Are you asking about the TUSS4470 device dimensions ? If yes this is available in the datasheet in the orderable section.
If your question is in regards to EVM dimensions its 2000 mil by 1800 mil. The EVM is designed to fit the booster pack and the solution size can be significantly smaller in size.
Let me know if this helps.
Hi Arjun,
Thank you for your quick response. The customer is requesting for the dimension (LxWxH) of the EVM. I would assume the BOOSTXL-TUSS4470 and BOOSTXL-TUSS4440 have the same dimensions, is this correct?
Danilo
