"Justin Curewitz "<bounce-5118664@mail.e2e.ti.com>;
2020 5 18 11:28
Sensors forum: CCS/IWR1443: About the EKF in pplcount demo
Hi Jie,
In the future, please make sure to reply to the thread that has already been started (no worries though, we will continue on this thread :) ).
Please see the pplcounting demo (lab11). See task_app.c - this file has the gtrack initialization (gtrack_create) and the gtrack_step() call.
Justin
Hi Justin,
I would like to confirm whether my understanding is right. I should follow the example from people counting to add the gtrack call to the zone occupancy firmware. But, I found two .bin files (xwr14xx_mmw_demo_mss.bin and xwr12xx_xwr14xx_radarss.bin) instead of .c files in zone occupancy demo (lab16) and I want to ask where I can find the .c files or how I can directly make changes on xwr14xx_mmw_demo_mss.bin files.
Thanks!
Jie
Hi Jie,
Zone Occupancy demo uses the OOB demo. Please see the user's guide included with the lab to understand how to compile it.
Justin
Hi Justin,
I tried to add gtrack calls in OOB demo of xWR14XX. I found that in addition to the three steps you told me, the format of TLV also should be changed, which should contain the target list information. Am I right ? Are there other simple approaches that can add the tracking function to the zone occupancy demo?
Thanks!
Jie
Hi Jie,
Apologies, you would need to add some TLV to output data. You can copy the ones we already use in people counting, see TLV 7 and TLV 8. You can see the current Area Scanner demo for an example of OOB demo chain plus tracker.
Justin
Hi Justin,
I would like to ask another question. I watched video of 'Detecting Human Falls and Stance" experiment using IWR6843 ODS. I found that the demo can detected many points in one frame. I tried to use zone occupancy demo on IWR6843ISK with its default config file but the detected point is up to 40. But the document says the maximum number of points that IWR6843 can detected is 1000. I want to know how to increase the number of detected points of IWR6843ISK? Can I obtain more points by changing the config file or using other demo or some other ways?
Thanks!
Jie
Hi Jie,
The people counting demo (3D Wall) could return up to 1000 points (however even at tradeshows I have not seen more than ~500 detections). The Zone occupancy demo is based on an older version of the OOB demo, which is limited to much fewer points, 100 - 200. For a person, with fine Range resolution and fine doppler resolution, you will typically get about 40 points.
I believe the original question in this thread has been answered. Please open another thread if you want to continue discussing your last question.
Justin
Hi Justin,
Thanks for your quick reply!
I will create another thread to continue the last question.
I'm still trying adding the gtrack call to the firmware of zone occupancy demo. Maybe I will ask some questions related to this thread in the following weeks. So should I close this thread of just continue it?
Jie
Hi Jie,
Typically, we want to keep a thread open until the question is resolved. I believe we have answered your initial question, so I will close this thread. If you have another question, you can open a new thread, where you will continue until your issue is resolved.
Justin
