OPT3001: OPT3001 SCH review
Part Number: OPT3001
Hi TI:
Could you help check attached OPT3001 SCH is ok or not?
Thank you~~
BR/Poki
ALS OPT3001.pdf
  • Hi Poki,
    From OPT3001 side looks mostly good. You have checked the pull up resistance for I2C against bus capacitance to choose the value used? Where is pull up for the INT pin? What are the 0 ohm resistors for - is this in case you want to disconnect the OPT3001 from the bus?
    Alex
