Hi AWR Team,
This is Khai from Metawave. I am creating a ticket here after our call with your team on 5/26/2020, The purpose is that Normal Frame Configuration of the AWR took too long of a latency. During the call, it was suggested to use Advanced Frame Config which we heard of but is a new concept to us. I would like to provide our radar mode configuration here from the Processor SDK perspective and hopefully someone on the AWR team can help translate that into Advance Frame Config. If a Call is needed to get to the bottom of this issue, We will set that up then. I will attached the source code that I have for AWR configuration here.
--Khai
/****************************************************************************** Copyright (c) [2018] Texas Instruments Incorporated All rights reserved not granted herein. Limited License. Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive license under copyrights and patents it now or hereafter owns or controls to make, have made, use, import, offer to sell and sell ("Utilize") this software subject to the terms herein. With respect to the foregoing patent license, such license is granted solely to the extent that any such patent is necessary to Utilize the software alone. The patent license shall not apply to any combinations which include this software, other than combinations with devices manufactured by or for TI ("TI Devices"). No hardware patent is licensed hereunder. Redistributions must preserve existing copyright notices and reproduce this license (including the above copyright notice and the disclaimer and (if applicable) source code license limitations below) in the documentation and/or other materials provided with the distribution Redistribution and use in binary form, without modification, are permitted provided that the following conditions are met: * No reverse engineering, decompilation, or disassembly of this software is permitted with respect to any software provided in binary form. * Any redistribution and use are licensed by TI for use only with TI Devices. * Nothing shall obligate TI to provide you with source code for the software licensed and provided to you in object code. If software source code is provided to you, modification and redistribution of the source code are permitted provided that the following conditions are met: * Any redistribution and use of the source code, including any resulting derivative works, are licensed by TI for use only with TI Devices. * Any redistribution and use of any object code compiled from the source code and any resulting derivative works, are licensed by TI for use only with TI Devices. Neither the name of Texas Instruments Incorporated nor the names of its suppliers may be used to endorse or promote products derived from this software without specific prior written permission. DISCLAIMER. THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ******************************************************************************/ /** * \file chains_common_cascade_ar12xx.c * * \brief Cascade Radar sample application AR12xx configuration. */ /******************************************************************************* * INCLUDE FILES ******************************************************************************* */ #include <include/common/chains_radar.h> /* ========================================================================== */ /* Macros & Typedefs */ /* ========================================================================== */ #define APP_NAME "CHAINS_COMMON_CASCADE" /* Maximum Number of profiles which is possible from the AR device */ #define CHAINS_CASCADE_RADAR_MAX_PROFILES (4U) #define CHAINS_CASCADE_RADAR_MAX_MODES CHAINS_CASCADE_RADAR_MAX_PROFILES /* Name of the configuration used */ #define CHAINS_CASCADE_RADAR_CONFIG_NAME "CASCADE_CONFIG" #define CHAINS_CASCADE_RADAR_NUM_RX_ANTENNA (4U) // Khai: used to enable all 4 RX in a sensor /* Total number of Txs across sensors that are chirped as part of TDM-MIMO */ #define CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA (1U) // Khai: use in Advanced Frame Config only /** \brief Radar Sensor Height or Number of Chirps */ #define CHAINS_CASCADE_RADAR_RADAR_HEIGHT_64 (64U) // Khai: use 128 doppler #define CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128 (128U) // Khai: use 128 doppler #define CHAINS_CASCADE_RADAR_NUM_FRAMES (0U) // 0 = infinity Frames #define CHAINS_CASCADE_RADAR_FRAME_PERIODICITY_MS (10U) // Khai: rel - 10ms, dbg - 20ms #define CHAINS_CASCADE_RADAR_WIDTH_128 (128U) // Khai: set range bin to 256 #define CHAINS_CASCADE_RADAR_WIDTH_256 (256U) // Khai: set range bin to 256 // Khai: LRR Profile Config same as FUJI //#define CHAINS_CASCADE_RADAR_SAMPLING_RATE_KSPS (18750U) //#define CHAINS_CASCADE_RADAR_ADC_START_TIME_IN_US (4U) //#define CHAINS_CASCADE_RADAR_IDLE_TIME_IN_US (2U) //#define CHAINS_CASCADE_RADAR_RAMP_END_TIME_IN_US (30U) //#define CHAINS_CASCADE_RADAR_SLOPE_MHZ_PER_US (8.52) //#define CHAINS_CASCADE_RADAR_TX_START_TIME (1U) // Khai: MRR Profile Config same as FUJI //#define CHAINS_CASCADE_RADAR_SAMPLING_RATE_KSPS (15000U) //#define CHAINS_CASCADE_RADAR_ADC_START_TIME_IN_US (5U) //#define CHAINS_CASCADE_RADAR_IDLE_TIME_IN_US (4U) //#define CHAINS_CASCADE_RADAR_RAMP_END_TIME_IN_US (23U) //#define CHAINS_CASCADE_RADAR_SLOPE_MHZ_PER_US (15U) //#define CHAINS_CASCADE_RADAR_TX_START_TIME (1U) // Khai: SRR Profile Config same as FUJI #define CHAINS_CASCADE_RADAR_SAMPLING_RATE_KSPS (8000U) #define CHAINS_CASCADE_RADAR_ADC_START_TIME_IN_US (6U) #define CHAINS_CASCADE_RADAR_IDLE_TIME_IN_US (5U) #define CHAINS_CASCADE_RADAR_RAMP_END_TIME_IN_US (40U) #define CHAINS_CASCADE_RADAR_SLOPE_MHZ_PER_US (79U) #define CHAINS_CASCADE_RADAR_TX_START_TIME (1U) /* check if frame periodicity too low with 2 ms margin */ #define TOTAL_CHIRP_TIME_US ( /* number of chirps */ \ (CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA * \ CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128) * \ /* time of one chirp */ \ (CHAINS_CASCADE_RADAR_RAMP_END_TIME_IN_US + \ CHAINS_CASCADE_RADAR_IDLE_TIME_IN_US) \ ) #if ((CHAINS_CASCADE_RADAR_FRAME_PERIODICITY_MS * 1000) < (TOTAL_CHIRP_TIME_US + 2000U)) #error frame periodicity too low #endif /** \brief CSI Data Rate for data transfer from AR12xx * Valid Values are * 150 (for 150 Mbps) * 300 (for 300 Mbps) * 400 (for 400 Mbps) * 450 (for 450 Mbps) * 600 (for 600 Mbps) */ #define CHAINS_AR1243_CSI_DATA_RATE (600U) #if (CHAINS_AR1243_CSI_DATA_RATE == (150U)) /** \brief CSI Data rate value set in the AR12 parameters */ #define CHAINS_AR1243_CSI_DATA_RATE_VALUE (6) /* 150 Mbps */ /** \brief CSI High speed clock set in the AR12 parameters */ #define CHAINS_CASCADE_RADAR_DDR_HSI_CLK (0xB) /* 150 Mbps */ /** \brief ISS CSI clock paramter set */ #define CHAINS_CASCADE_RADAR_ISS_CSI_CLK (75U) /* 150 Mbps */ #elif (CHAINS_AR1243_CSI_DATA_RATE == (300U)) /** \brief CSI Data rate value set in the AR12 parameters */ #define CHAINS_AR1243_CSI_DATA_RATE_VALUE (4) /* 300 Mbps */ /** \brief CSI High speed clock set in the AR12 parameters */ #define CHAINS_CASCADE_RADAR_DDR_HSI_CLK (0xA) /* 300 Mbps */ /** \brief ISS CSI clock paramter set */ #define CHAINS_CASCADE_RADAR_ISS_CSI_CLK (150U) /* 300 Mbps */ #elif (CHAINS_AR1243_CSI_DATA_RATE == (400U)) /** \brief CSI Data rate value set in the AR12 parameters */ #define CHAINS_AR1243_CSI_DATA_RATE_VALUE (3) /* 400 Mbps */ /** \brief CSI High speed clock set in the AR12 parameters */ #define CHAINS_CASCADE_RADAR_DDR_HSI_CLK (0x1) /* 400 Mbps */ /** \brief ISS CSI clock paramter set */ #define CHAINS_CASCADE_RADAR_ISS_CSI_CLK (200U) /* 400 Mbps */ #elif (CHAINS_AR1243_CSI_DATA_RATE == (450U)) /** \brief CSI Data rate value set in the AR12 parameters */ #define CHAINS_AR1243_CSI_DATA_RATE_VALUE (2) /* 450 Mbps */ /** \brief CSI High speed clock set in the AR12 parameters */ #define CHAINS_CASCADE_RADAR_DDR_HSI_CLK (0x5) /* 450 Mbps */ /** \brief ISS CSI clock paramter set */ #define CHAINS_CASCADE_RADAR_ISS_CSI_CLK (225U) /* 450 Mbps */ #elif (CHAINS_AR1243_CSI_DATA_RATE == (600U)) /** \brief CSI Data rate value set in the AR12 parameters */ #define CHAINS_AR1243_CSI_DATA_RATE_VALUE (1) /* 600 Mbps */ /** \brief CSI High speed clock set in the AR12 parameters */ #define CHAINS_CASCADE_RADAR_DDR_HSI_CLK (0x9) /* 600 Mbps */ /** \brief ISS CSI clock paramter set */ #define CHAINS_CASCADE_RADAR_ISS_CSI_CLK (300U) /* 600 Mbps */ #else #warn "CHAINS_CASCADE_RADAR: No valid data rate specified!!" #endif /** \brief ADC Data Format for AR12 * Valid Values are * 12 (for 12 bit ADC) * 14 (for 14 bit ADC) * 16 (for 16 bit ADC) */ #define CHAINS_CASCADE_RADAR_ADC_DATA_FORMAT (16U) #if (CHAINS_CASCADE_RADAR_ADC_DATA_FORMAT == (12U)) /** \brief AR12 data format value set in the configuration */ #define CHAINS_CASCADE_RADAR_DATA_FORMAT_CONFIG (RL_ADC_DATA_12_BIT) /* 12 bit */ #elif (CHAINS_CASCADE_RADAR_ADC_DATA_FORMAT == (14U)) /** \brief AR12 data format value set in the configuration */ #define CHAINS_CASCADE_RADAR_DATA_FORMAT_CONFIG (RL_ADC_DATA_14_BIT) /* 14 bit */ #elif (CHAINS_CASCADE_RADAR_ADC_DATA_FORMAT == (16U)) /** \brief AR12 data format value set in the configuration */ #define CHAINS_CASCADE_RADAR_DATA_FORMAT_CONFIG (RL_ADC_DATA_16_BIT) /* 16 bit */ #else #warn "CHAINS_CASCADE_RADAR: No valid ADC data format specified!!" #endif /** \brief Advanced Frame Configurations */ #define CHAINS_CASCADE_RADAR_NUM_SUBFRAMES (2U) #define CHAINS_CASCADE_RADAR_NUM_BURSTS (1U) #define CHAINS_CASCADE_RADAR_NUM_BURST_LOOPS (1U) #define CHAINS_CASCADE_CHIRP_START_IDX 0 #define CHAINS_CASCADE_CHIRP_END_IDX 0 // Khai: Set this to number of chirp used on all sensors /* When Advanced frame configuration is set this is ignored */ //==============================================================// // ASSUMPTION: THERE IS EQUAL NUMBER OF FRAME CFG AS NUMBER OF // // OF PROFILES IN THIS CODE BASE. THIS IS BECAUSE WE ASSOCIATE // // PROFILE TO RADAR MODE. EACH RADAR MODE HAS PARAMETER DEPEDENT// // IN BOTH FRAME CFG AND PROFILE CFG. THEREFORE, THERE MUST BE // // EQUAL NUMBER OF FRAME CFG AND PROFILE CFG // //==============================================================// rlFrameCfg_t gChains_cascadeRadarFrmArgsMaster[CHAINS_CASCADE_RADAR_MAX_MODES] = { { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_API_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 }, { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_128 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_API_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 }, { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_128 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_API_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 }, { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_API_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 } }; rlFrameCfg_t gChains_cascadeRadarFrmArgsSlave[CHAINS_CASCADE_RADAR_MAX_MODES] = { { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_SYNCIN_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 }, { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_128 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_SYNCIN_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 }, { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_128 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_SYNCIN_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 }, { .chirpStartIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_START_IDX, .chirpEndIdx = (rlUInt16_t) CHAINS_CASCADE_CHIRP_END_IDX, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .numFrames = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_FRAMES, .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256 * (rlUInt16_t)2, .framePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(10), .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_SYNCIN_TRIGGER, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .frameTriggerDelay = (rlUInt32_t) 0 } }; rlProfileCfg_t gChains_cascadeRadarProfileArgs[CHAINS_CASCADE_RADAR_MAX_MODES] = { // POC: radar mode 1 - Vmax = 37, Vres = .58 m/s, Rmax = 330, Rres = 1.29 m { .profileId = (rlUInt16_t) 0, .pfVcoSelect = (rlUInt8_t) 0, .pfCalLutUpdate = (rlUInt8_t) 0, .startFreqConst = (rlUInt32_t) CHAINS_AR1243_FREQ_GHZ_CONV(77), .idleTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(2), .adcStartTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(4), .rampEndTime = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(30), .txOutPowerBackoffCode = (rlUInt32_t) 14, .txPhaseShifter = (rlUInt32_t) 0, .freqSlopeConst = (rlInt16_t) CHAINS_AR1243_FREQ_MHZ_PER_MICRO_S_SLOPE_CONV(8.52), .txStartTime = (rlInt16_t) CHAINS_AR1243_TIME_US_TO_10NS(1U), .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256, .digOutSampleRate = (rlUInt16_t) 18750, // Kilo Samples per second .hpfCornerFreq1 = (rlUInt8_t) RL_RX_HPF1_175_KHz, // Khai: change this to eliminate the range wrap around .hpfCornerFreq2 = (rlUInt8_t) RL_RX_HPF2_350_KHz, // Khai: change this to eliminate the range wrap around .rxGain = (rlUInt16_t) 30 // Khai: This is same as 9dB VGA gain }, // POC: radar mode 2 - Vmax = 60, Vres = .94 m/s, Rmax = 330, Rres = 2.58 m { .profileId = (rlUInt16_t) 1, .pfVcoSelect = (rlUInt8_t) 0, .pfCalLutUpdate = (rlUInt8_t) 0, .startFreqConst = (rlUInt32_t) CHAINS_AR1243_FREQ_GHZ_CONV(77), .idleTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(2), .adcStartTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(4), .rampEndTime = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(14.22), .txOutPowerBackoffCode = (rlUInt32_t) 14, .txPhaseShifter = (rlUInt32_t) 0, .freqSlopeConst = (rlInt16_t) CHAINS_AR1243_FREQ_MHZ_PER_MICRO_S_SLOPE_CONV(8.49), .txStartTime = (rlInt16_t) CHAINS_AR1243_TIME_US_TO_10NS(1U), .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_128, .digOutSampleRate = (rlUInt16_t) 18750, // Kilo Samples per second .hpfCornerFreq1 = (rlUInt8_t) RL_RX_HPF1_175_KHz, // Khai: change this to eliminate the range wrap around .hpfCornerFreq2 = (rlUInt8_t) RL_RX_HPF2_350_KHz, // Khai: change this to eliminate the range wrap around .rxGain = (rlUInt16_t) 30, // Khai: This is same as 9dB VGA gain }, // POC: radar mode 4 - Vmax = 60, Vres = .94 m/s, Rmax = 250, Rres = 2 m { .profileId = (rlUInt16_t) 2, .pfVcoSelect = (rlUInt8_t) 0, .pfCalLutUpdate = (rlUInt8_t) 0, .startFreqConst = (rlUInt32_t) CHAINS_AR1243_FREQ_GHZ_CONV(77), .idleTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(2), .adcStartTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(4), .rampEndTime = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(14.22), .txOutPowerBackoffCode = (rlUInt32_t) 14, .txPhaseShifter = (rlUInt32_t) 0, .freqSlopeConst = (rlInt16_t) CHAINS_AR1243_FREQ_MHZ_PER_MICRO_S_SLOPE_CONV(11.27), .txStartTime = (rlInt16_t) CHAINS_AR1243_TIME_US_TO_10NS(1U), .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_128, .digOutSampleRate = (rlUInt16_t) 18750, // Kilo Samples per second .hpfCornerFreq1 = (rlUInt8_t) RL_RX_HPF1_175_KHz, // Khai: change this to eliminate the range wrap around .hpfCornerFreq2 = (rlUInt8_t) RL_RX_HPF2_350_KHz, // Khai: change this to eliminate the range wrap around .rxGain = (rlUInt16_t) 30 // Khai: This is same as 9dB VGA gain }, // POC: radar mode 5 - Vmax = 37 m/s, Vres = .6 m/s, Rmax = 100, Rres = .4 m { .profileId = (rlUInt16_t) 3, .pfVcoSelect = (rlUInt8_t) 0, .pfCalLutUpdate = (rlUInt8_t) 0, .startFreqConst = (rlUInt32_t) CHAINS_AR1243_FREQ_GHZ_CONV(77), .idleTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(2), .adcStartTimeConst = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(4), .rampEndTime = (rlUInt32_t) CHAINS_AR1243_TIME_US_TO_10NS(24.22), .txOutPowerBackoffCode = (rlUInt32_t) 14, .txPhaseShifter = (rlUInt32_t) 0, .freqSlopeConst = (rlInt16_t) CHAINS_AR1243_FREQ_MHZ_PER_MICRO_S_SLOPE_CONV(28.16), .txStartTime = (rlInt16_t) CHAINS_AR1243_TIME_US_TO_10NS(1U), .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256, .digOutSampleRate = (rlUInt16_t) 18750, // Kilo Samples per second .hpfCornerFreq1 = (rlUInt8_t) RL_RX_HPF1_175_KHz, // Khai: change this to eliminate the range wrap around .hpfCornerFreq2 = (rlUInt8_t) RL_RX_HPF2_350_KHz, // Khai: change this to eliminate the range wrap around .rxGain = (rlUInt16_t) 30 // Khai: This is same as 9dB VGA gain } }; rlChirpCfg_t gChains_cascadeRadarChirpCfgArgsMaster[CHAINS_CASCADE_RADAR_MAX_MODES] = { { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x0, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x1, // Khai: enable transmit only on Master TX0 .reserved = (rlUInt16_t) 0x0 }, { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x1, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x1, // Khai: enable transmit only on Master TX0 .reserved = (rlUInt16_t) 0x0 }, { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x2, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x1, // Khai: enable transmit only on Master TX0 .reserved = (rlUInt16_t) 0x0 }, { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x3, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x1, // Khai: enable transmit only on Master TX0 .reserved = (rlUInt16_t) 0x0 } }; rlChirpCfg_t gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap2[CHAINS_CASCADE_RADAR_MAX_MODES] = { { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x0, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x0, .reserved = (rlUInt16_t) 0x0 }, { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x1, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x0, .reserved = (rlUInt16_t) 0x0 }, { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x2, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x0, .reserved = (rlUInt16_t) 0x0 }, { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .profileId = (rlUInt16_t) 0x3, .startFreqVar = (rlUInt32_t) 0x0, .freqSlopeVar = (rlUInt16_t) 0x0, .idleTimeVar = (rlUInt16_t) 0x0, .adcStartTimeVar = (rlUInt16_t) 0x0, .txEnable = (rlUInt16_t) 0x0, .reserved = (rlUInt16_t) 0x0 } }; rlChirpCfg_t gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap4[CHAINS_CASCADE_RADAR_MAX_MODES]; rlChirpCfg_t gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap8[CHAINS_CASCADE_RADAR_MAX_MODES]; //rlRfPhaseShiftCfg_t gCascade_mimo_master[CHAINS_RADAR_MAX_NUM_CHIRP_CFG]; //rlRfPhaseShiftCfg_t gCascade_mimo_slave2[CHAINS_RADAR_MAX_NUM_CHIRP_CFG]; //rlRfPhaseShiftCfg_t gCascade_mimo_slave4[CHAINS_RADAR_MAX_NUM_CHIRP_CFG]; //rlRfPhaseShiftCfg_t gCascade_mimo_slave8[CHAINS_RADAR_MAX_NUM_CHIRP_CFG]; rlBpmChirpCfg_t gChains_cascadeRadarBpmChirpCfgArgs[] = { { .chirpStartIdx = (rlUInt16_t) 0x0, .chirpEndIdx = (rlUInt16_t) 0x0, .constBpmVal = (rlUInt16_t) 0x0, .reserved = (rlUInt16_t) 0x0 } }; /**< \brief Sensor configuration for the CHAINS_CASCADE_RADAR Radar Sensor */ Bsp_Ar12xxConfigObj gAr12xx_config_master = { .rfChanCfgArgs = { .rxChannelEn = (rlUInt16_t) ((1U << CHAINS_CASCADE_RADAR_NUM_RX_ANTENNA) - 1), // This dictates nRX/sensor .txChannelEn = (rlUInt16_t) ((1U << RL_TX_CNT) - 1), // This does not dictate nTx/sensor .cascading = (rlUInt16_t) RL_FRAME_SYNC_MODE_MULT_CHIP_MASTER, .cascadingPinoutCfg = (rlUInt16_t) 0x0 }, .adcOutCfgArgs = { .fmt = { .b2AdcBits = CHAINS_CASCADE_RADAR_DATA_FORMAT_CONFIG, .b6Reserved0 = (rlUInt32_t) 0x0, .b8FullScaleReducFctr = (rlUInt32_t) 0x0, .b2AdcOutFmt = RL_ADC_FORMAT_COMPLEX_1X, .b14Reserved1 = (rlUInt32_t) 0x0 }, .reserved0 = (rlUInt16_t) 0x0 }, .dataFmtCfgArgs = { .rxChannelEn = (rlUInt16_t) (1<<CHAINS_CASCADE_RADAR_NUM_RX_ANTENNA) - 1, .adcBits = (rlUInt16_t) CHAINS_CASCADE_RADAR_DATA_FORMAT_CONFIG, .adcFmt = (rlUInt16_t) RL_ADC_FORMAT_COMPLEX_1X, .iqSwapSel = (rlUInt8_t) RL_DEV_I_FIRST, .chInterleave = (rlUInt8_t) RL_DEV_CH_NON_INTERLEAVED, .reserved = (rlUInt32_t) 0x0 }, .rfLpModeCfgArgs = { .reserved = (rlUInt16_t) 0, .lpAdcMode = (rlUInt16_t) RL_ADC_MODE_REGULAR }, .chirpCfgArgs = &gChains_cascadeRadarChirpCfgArgsMaster[0], .numChirpCfgArgs = (CHAINS_CASCADE_CHIRP_END_IDX+1U), .profileCfgArgs = gChains_cascadeRadarProfileArgs, .numProfileCfgArgs = sizeof(gChains_cascadeRadarProfileArgs)/sizeof(rlProfileCfg_t), .frameCfgArgs = &gChains_cascadeRadarFrmArgsMaster[0], .dataPathCfgArgs = { .intfSel = (rlUInt8_t) 0, .transferFmtPkt0 = (rlUInt8_t) 1, /**< Data out Format, \n b5:0 Packet 0 content selection\n 000001 - ADC_DATA_ONLY \n 000110 - CP_ADC_DATA \n 001001 - ADC_CP_DATA \n 110110 - CP_ADC_CQ_DATA b7:6 Packet 0 virtual channel number (valid only for CSI2)\n 00 Virtual channel number 0 (Default)\n 01 Virtual channel number 1\n 02 Virtual channel number 2\n 03 Virtual channel number 3 \n*/ .transferFmtPkt1 = (rlUInt8_t) 0,/**< Data out Format, \n b5:0 Packet 0 content selection\n 000000 - Suppress Packet 1 \n 001110 - CP_CQ_DATA \n 001011 - CQ_CP_DATA \n b7:6 Packet 1 virtual channel number (valid only for CSI2)\n 00 Virtual channel number 0 (Default)\n 01 Virtual channel number 1\n 02 Virtual channel number 2\n 03 Virtual channel number 3\n*/ .cqConfig = (rlUInt8_t) 2, .cq0TransSize = (rlUInt8_t) 64, .cq1TransSize = (rlUInt8_t) 64, .cq2TransSize = (rlUInt8_t) 64, .reserved = (rlUInt8_t) 0 }, .dataPathClkCfgArgs = { .laneClkCfg = (rlUInt8_t) 1, .dataRate = (rlUInt8_t) CHAINS_AR1243_CSI_DATA_RATE_VALUE, .reserved = (rlUInt16_t) 0 }, .hsiClkgs = { .hsiClk = (rlUInt16_t) CHAINS_CASCADE_RADAR_DDR_HSI_CLK, .reserved = (rlUInt16_t) 0x0 }, .laneEnCfgArgs = { .laneEn = (rlUInt16_t) #if CHAINS_AR1243_CSI_DATA1LANE_POS ((rlUInt16_t) 0x1) | #endif #if CHAINS_AR1243_CSI_DATA2LANE_POS ((rlUInt16_t) 0x2) | #endif #if CHAINS_AR1243_CSI_DATA3LANE_POS ((rlUInt16_t) 0x4) | #endif #if CHAINS_AR1243_CSI_DATA4LANE_POS ((rlUInt16_t) 0x8) | #endif ((rlUInt16_t) 0x0), .reserved = (rlUInt16_t) 0x0 }, .ldoBypassCfgArgs = {3, 0}, .bpmCommnCfgArgs = { .mode.b2SrcSel = 0, .mode.b1Reserved0 = 0, .mode.b13Reserved1 = 0, .reserved0 = (rlUInt16_t) 0, .reserved1 = (rlUInt16_t) 0, .reserved2 = (rlUInt16_t) 0, .reserved3 = (rlUInt32_t) 0, .reserved4 = (rlUInt32_t) 0 }, .bpmChirpCfgArgs = gChains_cascadeRadarBpmChirpCfgArgs, .numBpmChirpCfgArgs = sizeof(gChains_cascadeRadarBpmChirpCfgArgs)/sizeof(rlBpmChirpCfg_t), .csiConfigArgs = { .lanePosPolSel = ((CHAINS_AR1243_CSI_CLOCKLANE_POS << 16U) | /* Polarity Always */ (CHAINS_AR1243_CSI_DATA4LANE_POS << 12U) | /* assumed to be 0 */ (CHAINS_AR1243_CSI_DATA3LANE_POS << 8U) | (CHAINS_AR1243_CSI_DATA2LANE_POS << 4U) | (CHAINS_AR1243_CSI_DATA1LANE_POS)), .reserved1 = (rlUInt32_t) 0U, }, // Khai: MIMO use case does NOT use Advanced Frame at the moment .advFrameCfgArgs = { .frameSeq = { .numOfSubFrames = (rlUInt8_t) CHAINS_CASCADE_RADAR_NUM_SUBFRAMES, .forceProfile = (rlUInt8_t) 1, .loopBackCfg = (rlUInt8_t) 0, .subFrameTrigger = (rlUInt8_t) 0, .subFrameCfg = { { .forceProfileIdx = (rlUInt16_t) 0, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .burstPeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(33U), /* burstPeriodicity >= * (numLoops)* (numOfChirps) * chirpTime + InterBurstBlankTime, * where InterBurstBlankTime is primarily for sensor * calibration / monitoring, thermal control, and some minimum * time needed for triggering next burst. * NOTE: Across bursts, if the value numOfChirps, is not a * constant, then the actual available blank time can vary and * needs to be accounted for 1 LSB = 5 ns */ .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURSTS, .numOfBurstLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURST_LOOPS, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(66U), .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 }, { .forceProfileIdx = (rlUInt16_t) 1, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .burstPeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(33U), .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURSTS, .numOfBurstLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURST_LOOPS, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(66U), .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 }, { .forceProfileIdx = (rlUInt16_t) 0, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) 0, .numLoops = (rlUInt16_t) 0, .burstPeriodicity = (rlUInt32_t) 0, .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) 0, .numOfBurstLoops = (rlUInt16_t) 0, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 }, { .forceProfileIdx = (rlUInt16_t) 0, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) 0, .numLoops = (rlUInt16_t) 0, .burstPeriodicity = (rlUInt32_t) 0, .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) 0, .numOfBurstLoops = (rlUInt16_t) 0, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 } }, .numFrames = (rlUInt16_t) 0, .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_API_TRIGGER, .frameTrigDelay = (rlUInt32_t) 0, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0 }, .frameData = { .numSubFrames = (rlUInt8_t) CHAINS_CASCADE_RADAR_NUM_SUBFRAMES, .reserved0 = (rlUInt8_t) 0, .reserved1 = (rlUInt16_t) 0, .subframeDataCfg = { { .totalChirps = (rlUInt32_t) CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA * CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128 * CHAINS_CASCADE_RADAR_NUM_BURSTS, /* Number of Chirps in Sub-Frame = * numOfChirps * numLoops * numOfBurst */ .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256 * (rlUInt16_t) 2, .numChirpsInDataPacket = (rlUInt8_t) 1, /* In AR12xx: Program this as 1 */ .reserved = (rlUInt8_t) 0, }, { .totalChirps = (rlUInt32_t) 0, .numAdcSamples = (rlUInt16_t) 0, .numChirpsInDataPacket = (rlUInt8_t) 1, .reserved = (rlUInt8_t) 0, }, { .totalChirps = (rlUInt32_t) 0, .numAdcSamples = (rlUInt16_t) 0, .numChirpsInDataPacket = (rlUInt8_t) 1, .reserved = (rlUInt8_t) 0, }, { .totalChirps = (rlUInt32_t) 0, .numAdcSamples = (rlUInt16_t) 0, .numChirpsInDataPacket = (rlUInt8_t) 1, .reserved = (rlUInt8_t) 0, } } } }, // Khai: Here is where to specify Normal or Advanced Frame COnfig .frameType = BSP_AR12XX_FRAME_TYPE_NORMAL, .calibEnArgs = { .calibEnMask = (rlUInt32_t) 0x17f0, // 600 - enable tx rx, //200 - enable tx bk only, //0x17f0, .reserved0 = (rlUInt8_t) 0x0, .reserved1 = (rlUInt8_t) 0x0, .reserved2 = (rlUInt16_t) 0x0, .reserved3 = (rlUInt32_t) 0x0 } }; /**< \brief Sensor configuration for the CHAINS_CASCADE_RADAR Radar Sensor */ Bsp_Ar12xxConfigObj gAr12xx_config_slave_DevIdxMap2 = { .rfChanCfgArgs = { .rxChannelEn = (rlUInt16_t) (1 << CHAINS_CASCADE_RADAR_NUM_RX_ANTENNA) - 1, // This dictates nRX/sensor .txChannelEn = (rlUInt16_t) (1 << RL_TX_CNT) - 1, // This does not dictate nTx/sensor .cascading = (rlUInt16_t) RL_FRAME_SYNC_MODE_MULT_CHIP_SLAVE, .cascadingPinoutCfg = (rlUInt16_t) 0x0 }, .adcOutCfgArgs = { .fmt = { .b2AdcBits = CHAINS_CASCADE_RADAR_DATA_FORMAT_CONFIG, .b6Reserved0 = (rlUInt32_t) 0x0, .b8FullScaleReducFctr = (rlUInt32_t) 0x0, .b2AdcOutFmt = RL_ADC_FORMAT_COMPLEX_1X, .b14Reserved1 = (rlUInt32_t) 0x0 }, .reserved0 = (rlUInt16_t) 0x0 }, .dataFmtCfgArgs = { .rxChannelEn = (rlUInt16_t) (1<<CHAINS_CASCADE_RADAR_NUM_RX_ANTENNA) - 1, .adcBits = (rlUInt16_t) CHAINS_CASCADE_RADAR_DATA_FORMAT_CONFIG, .adcFmt = (rlUInt16_t) RL_ADC_FORMAT_COMPLEX_1X, .iqSwapSel = (rlUInt8_t) RL_DEV_I_FIRST, .chInterleave = (rlUInt8_t) RL_DEV_CH_NON_INTERLEAVED, .reserved = (rlUInt32_t) 0x0 }, .rfLpModeCfgArgs = { .reserved = (rlUInt16_t) 0, .lpAdcMode = (rlUInt16_t) RL_ADC_MODE_REGULAR }, .chirpCfgArgs = &gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap2[0], .numChirpCfgArgs = (CHAINS_CASCADE_CHIRP_END_IDX+1U), .profileCfgArgs = gChains_cascadeRadarProfileArgs, .numProfileCfgArgs = sizeof(gChains_cascadeRadarProfileArgs)/sizeof(rlProfileCfg_t), .frameCfgArgs = &gChains_cascadeRadarFrmArgsSlave[0], .dataPathCfgArgs = { .intfSel = (rlUInt8_t) 0, .transferFmtPkt0 = (rlUInt8_t) 1, /**< Data out Format, \n b5:0 Packet 0 content selection\n 000001 - ADC_DATA_ONLY \n 000110 - CP_ADC_DATA \n 001001 - ADC_CP_DATA \n 110110 - CP_ADC_CQ_DATA b7:6 Packet 0 virtual channel number (valid only for CSI2)\n 00 Virtual channel number 0 (Default)\n 01 Virtual channel number 1\n 02 Virtual channel number 2\n 03 Virtual channel number 3 \n*/ .transferFmtPkt1 = (rlUInt8_t) 0,/**< Data out Format, \n b5:0 Packet 0 content selection\n 000000 - Suppress Packet 1 \n 001110 - CP_CQ_DATA \n 001011 - CQ_CP_DATA \n b7:6 Packet 1 virtual channel number (valid only for CSI2)\n 00 Virtual channel number 0 (Default)\n 01 Virtual channel number 1\n 02 Virtual channel number 2\n 03 Virtual channel number 3\n*/ .cqConfig = (rlUInt8_t) 2, .cq0TransSize = (rlUInt8_t) 64, .cq1TransSize = (rlUInt8_t) 64, .cq2TransSize = (rlUInt8_t) 64, .reserved = (rlUInt8_t) 0 }, .dataPathClkCfgArgs = { .laneClkCfg = (rlUInt8_t) 1, .dataRate = (rlUInt8_t) CHAINS_AR1243_CSI_DATA_RATE_VALUE, .reserved = (rlUInt16_t) 0 }, .hsiClkgs = { .hsiClk = (rlUInt16_t) CHAINS_CASCADE_RADAR_DDR_HSI_CLK, .reserved = (rlUInt16_t) 0x0 }, .laneEnCfgArgs = { .laneEn = (rlUInt16_t) #if CHAINS_AR1243_CSI_DATA1LANE_POS ((rlUInt16_t) 0x1) | #endif #if CHAINS_AR1243_CSI_DATA2LANE_POS ((rlUInt16_t) 0x2) | #endif #if CHAINS_AR1243_CSI_DATA3LANE_POS ((rlUInt16_t) 0x4) | #endif #if CHAINS_AR1243_CSI_DATA4LANE_POS ((rlUInt16_t) 0x8) | #endif ((rlUInt16_t) 0x0), .reserved = (rlUInt16_t) 0x0 }, .ldoBypassCfgArgs = {3, 0}, .bpmCommnCfgArgs = { .mode.b2SrcSel = 0, .mode.b1Reserved0 = 0, .mode.b13Reserved1 = 0, .reserved0 = (rlUInt16_t) 0, .reserved1 = (rlUInt16_t) 0, .reserved2 = (rlUInt16_t) 0, .reserved3 = (rlUInt32_t) 0, .reserved4 = (rlUInt32_t) 0 }, .bpmChirpCfgArgs = gChains_cascadeRadarBpmChirpCfgArgs, .numBpmChirpCfgArgs = sizeof(gChains_cascadeRadarBpmChirpCfgArgs)/sizeof(rlBpmChirpCfg_t), .csiConfigArgs = { .lanePosPolSel = ((CHAINS_AR1243_CSI_CLOCKLANE_POS << 16U) | /* Polarity Always */ (CHAINS_AR1243_CSI_DATA4LANE_POS << 12U) | /* assumed to be 0 */ (CHAINS_AR1243_CSI_DATA3LANE_POS << 8U) | (CHAINS_AR1243_CSI_DATA2LANE_POS << 4U) | (CHAINS_AR1243_CSI_DATA1LANE_POS)), .reserved1 = (rlUInt32_t) 0U, }, .advFrameCfgArgs = { .frameSeq = { .numOfSubFrames = (rlUInt8_t) CHAINS_CASCADE_RADAR_NUM_SUBFRAMES, .forceProfile = (rlUInt8_t) 1, .loopBackCfg = (rlUInt8_t) 0, .subFrameTrigger = (rlUInt8_t) 0, .subFrameCfg = { { .forceProfileIdx = (rlUInt16_t) 0, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .burstPeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(33U), /* burstPeriodicity >= * (numLoops)* (numOfChirps) * chirpTime + InterBurstBlankTime, * where InterBurstBlankTime is primarily for sensor * calibration / monitoring, thermal control, and some minimum * time needed for triggering next burst. * NOTE: Across bursts, if the value numOfChirps, is not a * constant, then the actual available blank time can vary and * needs to be accounted for 1 LSB = 5 ns */ .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURSTS, .numOfBurstLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURST_LOOPS, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(66U), .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 }, { .forceProfileIdx = (rlUInt16_t) 1, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA, .numLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128, .burstPeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(33U), .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURSTS, .numOfBurstLoops = (rlUInt16_t) CHAINS_CASCADE_RADAR_NUM_BURST_LOOPS, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) CHAINS_AR1243_TIME_MS_TO_5NS(66U), .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 }, { .forceProfileIdx = (rlUInt16_t) 0, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) 0, .numLoops = (rlUInt16_t) 0, .burstPeriodicity = (rlUInt32_t) 0, .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) 0, .numOfBurstLoops = (rlUInt16_t) 0, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 }, { .forceProfileIdx = (rlUInt16_t) 0, .chirpStartIdx = (rlUInt16_t) 0, .numOfChirps = (rlUInt16_t) 0, .numLoops = (rlUInt16_t) 0, .burstPeriodicity = (rlUInt32_t) 0, .chirpStartIdxOffset = (rlUInt16_t) 0, .numOfBurst = (rlUInt16_t) 0, .numOfBurstLoops = (rlUInt16_t) 0, .reserved0 = (rlUInt16_t) 0, .subFramePeriodicity = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0, .reserved2 = (rlUInt32_t) 0 } }, .numFrames = (rlUInt16_t) 0, .triggerSelect = (rlUInt16_t) RL_FRAMESTRT_API_TRIGGER, .frameTrigDelay = (rlUInt32_t) 0, .reserved0 = (rlUInt32_t) 0, .reserved1 = (rlUInt32_t) 0 }, .frameData = { .numSubFrames = (rlUInt8_t) CHAINS_CASCADE_RADAR_NUM_SUBFRAMES, .reserved0 = (rlUInt8_t) 0, .reserved1 = (rlUInt16_t) 0, .subframeDataCfg = { { .totalChirps = (rlUInt32_t) CHAINS_CASCADE_RADAR_NUM_TX_ANTENNA * CHAINS_CASCADE_RADAR_RADAR_HEIGHT_128 * CHAINS_CASCADE_RADAR_NUM_BURSTS, /* Number of Chirps in Sub-Frame = * numOfChirps * numLoops * numOfBurst */ .numAdcSamples = (rlUInt16_t) CHAINS_CASCADE_RADAR_WIDTH_256 * (rlUInt16_t) 2, .numChirpsInDataPacket = (rlUInt8_t) 1, /* In AR12xx: Program this as 1 */ .reserved = (rlUInt8_t) 0, }, { .totalChirps = (rlUInt32_t) 0, .numAdcSamples = (rlUInt16_t) 0, .numChirpsInDataPacket = (rlUInt8_t) 1, .reserved = (rlUInt8_t) 0, }, { .totalChirps = (rlUInt32_t) 0, .numAdcSamples = (rlUInt16_t) 0, .numChirpsInDataPacket = (rlUInt8_t) 1, .reserved = (rlUInt8_t) 0, }, { .totalChirps = (rlUInt32_t) 0, .numAdcSamples = (rlUInt16_t) 0, .numChirpsInDataPacket = (rlUInt8_t) 1, .reserved = (rlUInt8_t) 0, } } } }, .frameType = BSP_AR12XX_FRAME_TYPE_NORMAL, .calibEnArgs = { .calibEnMask = (rlUInt32_t) 0x17f0, // 600 - enable tx rx, //200 - enable tx bk only, //0x17f0, .reserved0 = (rlUInt8_t) 0x0, .reserved1 = (rlUInt8_t) 0x0, .reserved2 = (rlUInt16_t) 0x0, .reserved3 = (rlUInt32_t) 0x0 } }; /* These two will be filled at run-time using DevIdxMap2 as base, because all parameters except * chirp configurations are same. */ Bsp_Ar12xxConfigObj gAr12xx_config_slave_DevIdxMap4; Bsp_Ar12xxConfigObj gAr12xx_config_slave_DevIdxMap8; // POC: There will be equal number of AWR config objects as radar modes. // Upon radar mode change, this function will be called and return the // corresponding AWR config param for that radar mode. Void Chains_ar12xxGetNewCascadeConfig(ChainsCommon_Ar12xxConfigOut *pCfgOut) { int id = pCfgOut->radarParams[0].currProfileId; // Change to Master Profile and Frame Config // pCfgOut->radarParams[0].ar12xxConfig.profileCfgArgs = gAr12xx_config_master.profileCfgArgs = // &gChains_cascadeRadarProfileArgs [id]; pCfgOut->radarParams[0].ar12xxConfig.frameCfgArgs = &gChains_cascadeRadarFrmArgsMaster[id]; pCfgOut->radarParams[0].ar12xxConfig.chirpCfgArgs = &gChains_cascadeRadarChirpCfgArgsMaster[id]; // Change to Slave2 Profile and Frame Config // pCfgOut->radarParams[1].ar12xxConfig.profileCfgArgs = gAr12xx_config_slave_DevIdxMap2.profileCfgArgs = // &gChains_cascadeRadarProfileArgs [id]; pCfgOut->radarParams[1].ar12xxConfig.frameCfgArgs = &gChains_cascadeRadarFrmArgsSlave[id]; pCfgOut->radarParams[1].ar12xxConfig.chirpCfgArgs = &gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap2[id]; // Change to Slave4 Profile and Frame Config // pCfgOut->radarParams[2].ar12xxConfig.profileCfgArgs = gAr12xx_config_slave_DevIdxMap4.profileCfgArgs = // &gChains_cascadeRadarProfileArgs [id]; pCfgOut->radarParams[2].ar12xxConfig.frameCfgArgs = &gChains_cascadeRadarFrmArgsSlave[id]; pCfgOut->radarParams[2].ar12xxConfig.chirpCfgArgs = &gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap4[id]; // Change to Slave8 Profile and Frame Config // pCfgOut->radarParams[3].ar12xxConfig.profileCfgArgs = gAr12xx_config_slave_DevIdxMap8.profileCfgArgs = // &gChains_cascadeRadarProfileArgs [id]; pCfgOut->radarParams[3].ar12xxConfig.frameCfgArgs = &gChains_cascadeRadarFrmArgsSlave[id]; pCfgOut->radarParams[3].ar12xxConfig.chirpCfgArgs = &gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap8[id]; } Int32 Chains_ar12xxGetSampleCascadeConfig(ChainsCommon_Ar12xxConfigOut *pCfgOut) { Int32 retVal = BSP_SOK; UInt32 i = 0; memset(pCfgOut, 0, sizeof(ChainsCommon_Ar12xxConfigOut)); /* 4 Chip Cascade Configuration */ pCfgOut->numRadars = CHAINS_RADAR_CASCADE_NUMSENSORS; Vps_printf( APP_NAME " AR12xx Initializing FPGA ...\n\r"); if (Bsp_boardGetBaseBoardRev() < BSP_BOARD_REV_E) { /* On Rev A, only one GPIO to lift the CRESET and power on ALL FPGA */ retVal = ChainsCommon_fpgaPowerUp(0); UTILS_assert(BSP_SOK == retVal); } // Khai: number of radar counter loops from 0->3 for (i = 0; i < pCfgOut->numRadars; i++) { /* Lift the CRESET and power on each FPGA */ if (Bsp_boardGetBaseBoardRev() >= BSP_BOARD_REV_E) { retVal = ChainsCommon_fpgaPowerUp(i); UTILS_assert(BSP_SOK == retVal); } /* Lift the Logic reset for each FPGA. FPGA will now be ready to accept * CSI Data. */ // Khai: There is a problem in this routine if we use numRadars < 4. // The switch case statement for 3 - initializes FPGA0 and for 0 - init 1 // and so on... If we use numRadars = 4, we are OK. anything else will // need code revision or talk to TI first retVal = ChainsCommon_fpgaStart(i); UTILS_assert(BSP_SOK == retVal); } Vps_printf( APP_NAME " AR12xx Initializing FPGA Done...\n\r"); /* Check for certain size limitations. This will show up as compile time * issues. */ COMPILE_TIME_ASSERT( sizeof(gChains_cascadeRadarProfileArgs)/sizeof(rlProfileCfg_t) > CHAINS_CASCADE_RADAR_MAX_PROFILES); for (i = 0; i < pCfgOut->numRadars; i++) { /* Defaulting to macro as this not captured in the ar12xxConfig parameter */ pCfgOut->radarParams[i].numValidBits = CHAINS_CASCADE_RADAR_ADC_DATA_FORMAT; pCfgOut->radarParams[i].bpmEnabled = 0U; pCfgOut->radarParams[i].numProfiles = sizeof(gChains_cascadeRadarProfileArgs)/sizeof(rlProfileCfg_t); sprintf(pCfgOut->radarParams[i].configName, "%s_%d", CHAINS_CASCADE_RADAR_CONFIG_NAME, i); pCfgOut->radarParams[i].chirpRow = NULL; pCfgOut->radarParams[i].numChirpRow = 0; // Khai: This indicates we are not using AWR TX phase shift pCfgOut->radarParams[i].numTxPhaseShifterCfg = 0; } // pCfgOut->radarParams[0].txPhaseShifterCfg = gCascade_mimo_master; // pCfgOut->radarParams[1].txPhaseShifterCfg = gCascade_mimo_slave2; // pCfgOut->radarParams[2].txPhaseShifterCfg = gCascade_mimo_slave4; // pCfgOut->radarParams[3].txPhaseShifterCfg = gCascade_mimo_slave8; /* Use DevIdxMap2 config as reference, everything is same except chirp configs */ memcpy((void*)&gAr12xx_config_slave_DevIdxMap4, (const void *)&gAr12xx_config_slave_DevIdxMap2, sizeof(gAr12xx_config_slave_DevIdxMap2)); // gAr12xx_config_slave_DevIdxMap4.chirpCfgArgs = gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap4; // gAr12xx_config_slave_DevIdxMap4.numChirpCfgArgs = (CHAINS_CASCADE_CHIRP_END_IDX+1U); // gAr12xx_config_slave_DevIdxMap4.rfChanCfgArgs.rxChannelEn = 0; // gAr12xx_config_slave_DevIdxMap4.dataFmtCfgArgs.rxChannelEn = 0; memcpy((void*)&gAr12xx_config_slave_DevIdxMap8, (const void *)&gAr12xx_config_slave_DevIdxMap2, sizeof(gAr12xx_config_slave_DevIdxMap2)); // gAr12xx_config_slave_DevIdxMap8.chirpCfgArgs = gChains_cascadeRadarChirpCfgArgsSlave_DevIdxMap8; // gAr12xx_config_slave_DevIdxMap8.numChirpCfgArgs = (CHAINS_CASCADE_CHIRP_END_IDX+1U); memcpy(&pCfgOut->radarParams[0].ar12xxConfig, &gAr12xx_config_master, sizeof (gAr12xx_config_master)); memcpy(&pCfgOut->radarParams[1].ar12xxConfig, &gAr12xx_config_slave_DevIdxMap2, sizeof(gAr12xx_config_slave_DevIdxMap2)); memcpy(&pCfgOut->radarParams[2].ar12xxConfig, &gAr12xx_config_slave_DevIdxMap4, sizeof(gAr12xx_config_slave_DevIdxMap4)); memcpy(&pCfgOut->radarParams[3].ar12xxConfig, &gAr12xx_config_slave_DevIdxMap8, sizeof(gAr12xx_config_slave_DevIdxMap8)); /* Default to normal frame */ pCfgOut->frameType = 0U; return retVal; }
