Hi Team,
Can you walk me through what needs to be changed to adapt the IWR6843ISK-ODS EVM Fall Detection Demo to be used with the IWR6843AOP EVM?
Please be more specific
Hi Team,
Please see the fall detection software available with the people counting visualzier. You can use LRPD, but change the compile settings to work with AOP antenna pattern instead of the ISK antenna pattern. To do this, compare the standard OOB for 6843 with the 6843 AOP out of box demo.
Justin
Hi Team,
now I have a new question ,Can you walk me through what needs to be done to adapt the IWR6843ISK-ODS ES2.0 to finish Fall Detection Demo
The LRPD is the OOB signal chain with the tracker built on it. You want to modify the OOB signal chain to work with the ODS instead of the ISK. You will need to modfiy the objectDetection.c file to use the 2D_AOA DPU instead of the current AOA DPU. You can compare the objectDetection.c file for the ODS OOB with the standard objectDetection.c file for the ISK OOB to get started.
Justin
